02-13-2011, 01:37 PM | #1 |
PCM programming in Phoenix, AZ
Can anyone recommend a reputable shop/person that can assist us with reprogramming our PCM?
We have a 72 K-10 with a Vortech SC'd 6.0/4L65E/NP205 combo. We used the Painless 60221 powertrain harness. Painless states that the PCM needs reprogramming prior to successful startup. At this point the engine cranks and all systems appear nominal, however it will not run. Unless I missed something, which is quite possible, I probably should have the PCM done. Any ideas, comments, suggestions? Thanks |
02-13-2011, 01:39 PM | #2 |
Re: PCM programming in Phoenix, AZ
I thought that Painless included ECM tuning with the purchase of their harness. If not then I went with Speartech and have been happy so far.
67 5.3L Build |
02-13-2011, 03:13 PM | #3 |
Nelson Performance is who I am going with, they are in San Antonio.
http://www.nelsonperformance.com/NPTuneInfo.htm
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-13-2011, 05:32 PM | #4 | |
02-13-2011, 06:23 PM | #5 |
I don't know of anyone in AZ.
67 5.3L Build |
02-14-2011, 03:30 AM | #6 |
69' Chevy Stepside
Try this place, I believe a guy named zippy (Mike) works there, he's been tuning for a very long time and very good at it. He did the tune for my truck over the phone for the 5.3L with a cam and now for the modded 6.0L. I contacted him directly, via Silveradoss.com username zippy. Here's the link for the place he works: http://www.adsautorepair.com/hp_customtuning.htm
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 02-14-2011 at 03:31 AM. |
02-15-2011, 06:02 AM | #7 |
If you haven't found anybody go to arizona dyno chip and they'll hook you up.
Posted via Mobile Device |
02-18-2011, 11:42 PM | #8 | |
