Gettin By on Gettin By
Seems to be a pretty common problem, but i'm stuck.
![]() ![]() ![]() ![]() It turns over, but won't start. New Parts: Water pump Lower Intake gasket set Crank Sensor Fuel Filter Starter Fuel PSI Is 62 when the key is turned and the relay is on and holds at 55 when turned off. PSI Jumps around from 62-68 while cranking. I did put a lower intake seal kit in, but got the motor started after i was done, after about an hour of the same symptoms that i have now but it just decided to start working right, but then decided to change the starter. I disconnected the battery, changed the starter, hooked the batt back up, and now its not starting. I have reinstalled the Dist with the correct timing procedure: Hit TDC, align the timing marks on the balancer with the timing cover, line up the dots and paint lines on the dizzy, drop it in and the rotor has hit the "8" stamped into the dizzy. So i'm getting spark at the plugs at the right time, fuel in at the right PSI, plenty of good cranking power, but still no start. Any ideas?? This thing is gonna test my patience yet. ![]() ![]()
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
Re: 99 Tahoe, 5.7 Not Starting.
Also i'm not showing and RPMs while cranking... is that correct? I assume the RPMs don't show up untill the thing is running, but i could be wrong.
I've heard of the ignition moduel causing a problem too, one symptom being that the Trany shift indicator doesn't light up, but mine does.
Nm... replaced the dizzy rotor and it fired right up.
forgot to KISS the ol girl.. Keep It Simple Stupid.
![]() Join Date: Jan 2011
Gotta love solving your own problems, Lol! Congrates btw!
Carbon Tracking is a new term i'm gonna tuck away.... Thanks btw..
Truck Enthusiast
man..my '99 would not start when I was supposed to leave from cali from vaca. had replace the fuel pump..... Glad your was easy
'85 swb |
