Old 02-27-2011, 02:20 AM   #1
fredscarryall
fredscarryall's Avatar
slamburban
1950 suburban carryall
here are some pic of my 1950 carryall (suburban) when i bought in may of 2010. it hardly had any rust and when i put the gas tank in. it ran and drove. the worst part of the whole suburban was someone in the 80s decided to put in a pop up sun roof. so i am planning on getting it filled back in with a patch panel from a truck roof.
fredscarryall is offline   Reply With Quote
Old 02-27-2011, 02:51 AM   #2
fredscarryall
slamburban
i had the the interior and frame sandblasted. the outside body will come in a couple years when i can save enough money to to the body work and paint. someone cut a sunroof into the top before i had it. my plan is to get it welded up
Old 02-27-2011, 02:58 AM   #3
fredscarryall
slamburban
removed engine and stock suspension. charleys drop shop in portland oregon 503-780-2155 is donig all the suspension,frame and floorboard work.here charley installed a j w rod garage ifs with air bags and 2" drop spindles.he had to notch the frame 1 3/4 inches in the front for the ifs. now the running board to lay an inch off the ground
Old 02-27-2011, 03:09 AM   #4
fredscarryall
slamburban
i didnt like the ribs on the firewall. so i cut them out but left a 1" lip around each side. so i could cut out an 18 gauge steel template and weld it in
Old 02-27-2011, 03:18 AM   #5
fredscarryall
slamburban
some people will think i crazy. but charley at charleys drop shop removed the back half of the frame and welded in a 2004 lincocn mark viii independent rear suspension (irs). the nice part is comes with disk brakes and it was only $250. i could have had the stock frame notched but i would have had to raise the floor about 9 inches and i didnt think that would look very good.
Old 02-27-2011, 03:19 AM   #6
fredscarryall
slamburban
here it is roughly a couple inches above ride height. then we removed the body from the frame. it needs a little finish welding. then is it goes to the sandblaster and powdercoater next week. i also changed the color to a patina look. most may think i am nuts but it was all done with $100 in rattle can paint. it has 4 colors. clarit wine/dark gray/aqua blue/light blue.i then took 180 grit and brought out the layers. now i just have to finish the roof
Old 02-27-2011, 08:44 AM   #7
entourageguy
Yellow truck club
entourageguy's Avatar
Re: slamburban
good progress.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-27-2011, 10:25 PM   #8
mr48chev
mr48chev's Avatar
Re: slamburban
looks good and what a slick setup on the rear end install.
Old 02-27-2011, 11:08 PM   #9
BigJock
Re: slamburban
I'll bet your 'burb will drive real nice with the IFS/IRS combo, keep up the good work.
Nice job on the 'patina' too.
BigJock is offline   Reply With Quote
Old 03-18-2011, 02:28 AM   #10
fredscarryall
Re: slamburban
i finally got my frame back from the powdercoater. it took 5 coats of mirror blue and was brought back out of the over and coated with another 5 coats and baked again.the frame looks flawless.
Old 03-18-2011, 04:41 AM   #11
Ratical
Ratical's Avatar
Re: slamburban
Man that looks awesome! I would love to see more pics of the rear end!
Ratical is offline   Reply With Quote
Old 03-18-2011, 05:54 AM   #12
55dude
55dude's Avatar
Re: slamburban
i like the choice for the rear suspension but having owned ones with M2 the front they fell short of my ride expectations, gotta be beter choices out there. great burb otherwise!
55dude is offline   Reply With Quote
Old 03-19-2011, 05:26 AM   #13
AceX
>130dB Moderator
AceX's Avatar
Re: slamburban
Nice
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 03-21-2011, 10:09 PM   #14
fredscarryall
Re: slamburban
installed rear crossmemeber for the irs
Old 03-21-2011, 10:12 PM   #15
fredscarryall
Re: slamburban
installed the motor.i believe its a 1987 350.but it was stroked 383 with 400 horse at the rear wheels.its a stock roller motor with scat crank,eagle rods,speed pro 11 to 1 forged pistons,540 lift roller cam,roller rockers,trick flow heads,protronics electronis distributor conversion,quite timing gears,patriot headers,edelbrock air gap manifold and a 750 edelbrock carb.it also has a rebuilt turbo 350 with a stage one shift kit,a superior 2800 stall converter and lokar 23 inch swan neck shifter.
Old 03-21-2011, 10:19 PM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: slamburban
Lookin' good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-22-2011, 03:04 AM   #17
drivea55
drivea55's Avatar
Re: slamburban
Let's hear it that you are going to redo the side pipes?
I love that look and not many do it...
great progress! keep it up!!
Brian
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 03-22-2011, 07:45 AM   #18
chev3600
chev3600's Avatar
Re: slamburban
That's a sharp ride. Love the color!
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 03-22-2011, 11:24 AM   #19
ratrodmiller
ratrodmiller's Avatar
Re: slamburban
good looking project man!I love those burbs.That rear subframe looks awesome also good work.
ratrodmiller is offline   Reply With Quote
Old 03-22-2011, 12:29 PM   #20
hotrodhomi
hotrodhomi's Avatar
Re: slamburban
love it. keep up the progress.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-22-2011, 04:47 PM   #21
ejn74
ejn74's Avatar
Re: slamburban
Nice Man!! Lookin Real Good So Far!!
ejn74 is offline   Reply With Quote
Old 04-07-2011, 06:34 PM   #22
fredscarryall
Re: slamburban
finished cleaning and painting the rear end today. tomorrow i am going to get the rest of the suspension,plumbing,and gas tank back on the frame
Old 04-07-2011, 06:43 PM   #23
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: slamburban
That is one really nice project you have there. It looks great.
Kabwe is offline   Reply With Quote
Old 04-07-2011, 07:03 PM   #24
Number 9
Re: slamburban
Nice job. Will be watching for more.
Number 9 is offline   Reply With Quote
Old 04-07-2011, 07:07 PM   #25
50adrod
50adrod's Avatar
Re: slamburban
like the paint. I did the same on my 50 ford. people love it and one person has hired me to do their truck. I steped my paper up from 1000 to 2000 then finished it off with 3000, my primer actually shines
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
