12-10-2010, 10:12 AM | #51 |
Happy to be here
Re: True C5 Rear Disc w/ internal parking brake in the works
Thanks for sharing the knowledge you have gained Boris. Your experience and advice is always appreciated here.
12-10-2010, 11:59 AM | #52 |
BMW & ASE Master Certified
Thanks for the sudgestions. They offered good pricing on 10 and 15 sets. As far as road testing them I haven't. I recon I will purchase the modified rotors and see if they fit a stock axle with no mods. If so I will go ahead and remove the current disc brakes on my 87 and install the c5 brakes. Price point even for the small run would at or less than 175. First batch would be a lower price just to get them moving. Next week I will order the rotors and some front hubs for the truck. Till ten keep the feedback comming
thanks clint Posted via Mobile Device
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
12-10-2010, 12:37 PM | #53 |
way2lo2
Can you tell me what the modified rotors are? Is it just a 5x5 bolt circle with 2.776" register and the backside milled for the axle O.D. size.? I might have something here that might work if that's all that the "modified rotors are.
Boris |
12-10-2010, 05:30 PM | #54 |
That is the exact mods to the rotors.
12-13-2010, 02:34 AM | #55 |
I would be interested as I am planning on the full c6 zo6 kit on my 72 c-10. I was excited to see the progress you have made on these ebrake components. Let me know if you move forward. I have been thinking spring time for my major brake expense if all goes well. I could spend the money on your brackets before then if you move forward. Looks great man Thanks. Phil
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
12-13-2010, 10:56 PM | #56 |
Closer to Xmas I plan to order the front hubs and c5 front brakes.. Then I will also order their modified rotors to see if they fit the non modified axle.
Clint Posted via Mobile Device
01-09-2011, 10:59 PM | #57 |
it's after Christmas, any new progress?
01-11-2011, 01:13 AM | #58 |
I have not started on the fronts. I finaly got an email back from moser on a set of the replacment 28spline axles... seems Its going to be a 2 step process on the machine work. They can do the facotry c-10 axles with the camaro (same as corvette) hub diameter, but they dont have the tooling to cut into the face of the flange to make the face of it 5.9"... they can cut the whole thing down to 5.9" but that doesnt leave a lot of meat on the outer edge of the lug hole. I will have the axles shipped to the place that mod'ed my 12 bolt axles for mock up. Maybe since he has to do less work the cost will be cheaper? probaly not though. All he will have to do is cut the face of the flange down to 5.9 and around .15 deep.
In the end, the axles are old, the truck see's WOT often enough... mine as well invest in a new pair of axles. Of course if your axles were not pitted on the bearing surface, you could just have yours modified. clint
01-18-2011, 02:48 PM | #59 |
Finaly ordered the axles to spec 275 shipped with the custom hub and flange mod strait from Moser. I'll take some pix when they arrive. As soon a I get em insalled I will do some road testing and make another post
01-19-2011, 06:54 PM | #60 |
I got a couple questions for you, sent you a PM
01-26-2011, 08:19 PM | #61 |
alrighty, axles have arrived from Moser. They look perdy.. they fit the rotor perfectly so I cant complain there, but he understood the request to step down the original diameter of 6 3/8 and step it down to 5.9 on the face of the flange.... they just buzzed it down to 5.9... theres .188" of meat between the edge of the flange and the edge of the hole. I contacted them and they said .125 is the mimimum. So on that front we are ok.
Autozone... geeze... a lesser man would have told this person to go back to the parts truck and wait till tomarrow before trying to help. And then the manager... "well....." got dang. I simply wanted rear axle bearings.. the ones at the end of the axle flange... I recall mine being cylinder like roller bearings, NOT tapered or ball bearing. 1st she said here ya go... and I open the box and its a tapered bearing, no race.. Are the rear axle bearings tapered? I'd rather have the bearings I need when I take the rear end apart... rather than take the bearing out, and then go to the store and then... clint
01-26-2011, 08:52 PM | #62 |
well after going to timken.com and doing a quick search, the bearings I need are 6408. I'll go back tomarrow and see if they can get that number... Its either autozone = timken, or Oreilly = national..... I never heard of national, but Timken is familair.
clint
01-29-2011, 12:42 AM | #63 |
I'm just glad to be here!
I will have to watch this one. My son and I are building a 82 for him. This might be what we want to do...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-29-2011, 11:53 PM | #64 |
update: photo illustration on how I redrilled the 5x5 pattern.
printed template trimmed timplate freehand to get rid of excess, have the butyl tape ready for next step 2 things happened in this step. 1st was to get a piece of cardboard and a pick. I placed the template on the cardboard and used the pick to punch through the center " X " of the 5x5 pattern. this will allow me to see where I need to place the center punch in the following step. 2nd thing that happened in this step was to apply a smear of the butyl tape. Its similar to sticky tack (the blue stuff) but its automotive grade and can be real sticky and messy when it gets real warm. I smeared 4 little spots on the tempate so it will stick to the front of the rotor. Placed the template with the butyl tape on the face of the rotor, and then aligned the center "hub" cirlce to the center hole of the rotor, then centered the 5x4.75 pattern through the lug holes Used a center punch and punced each of the 5x5 pattern on the dimples we made in the previous step with the pick and cardboard. A firm tap with a hammer does the trick. I will go back over it once all 5 have been done prior to drilling. I didnt take a photo of me drilling becuase thats just boring. I had a lot of worn out bits (forgot my decent set at work ). Basically went in steps, 1/8 so it could find the center punch mark real easy. then went up to 1/4, then 3/8, then I think i went strait to 1/2 then to 9/16. Due to my choice of wheel stud, Dorman 610-298, 2" long wheel stud, they have shoulder of 5/16, stock doesnt have one at all.... The shoulder requires you to put a chamfer on the inside of the 5x5 pattern so the rotor will sit on the axle flange rather than the stud. no big deal. I simply had a 5/8 drill bit and went down untill the drill bit made its full diameter into the rotor. Imagine when you are going from small drill bit to bigger... and when you first start drilling the beginning of the hole isnt 100% round, it takes a little bit of depth before its the diameter of the bit, thats how it looked. I did not finish the brakes, I kept on forgetting things at the parts store . I need to double check a few things, remove, take photos, paint, re assemble, bleed, fill axle fluid and bed the pads in. but heres a pic of them on 17" wheels... 1.8" smaller than what I had before, the caliper is a lot smaller than the one I had before but its a bit more proportionate.. either way, it looks great, parking brake is 2 cables away
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 01-30-2011 at 12:12 AM. |
01-30-2011, 10:09 PM | #65 |
test drove it today, feels good, truck still stops great. I dont know what to compare it to really. I pushed the brake as hard as I could and I could hear the tires start to break loose at 1500 rpm.... I didnt do that to the previous disc brake setup so thats just a number. I need to order a posi and a set of gears due to the fact I seen a few damaged teeth on the spider gears. I will order those 2 and a adjustable prop valve and gut the factory one and go from there. I would say I need some more pressure back there. I never bought one with the previous setup. Next weekend I will work on the ebrake cable length and hookup.
clint
01-30-2011, 10:12 PM | #66 |
Oh yeah, a factory 15" steel rally with tape weight will barely fit this setup. Only modification to get it to clear is sanding down the corner of the caliper and caliper mount. It rubbed the paint off of the inner rim. Either that or a thin shim, maybe 1/8 would suffice. The wheels I have now fit perfect with out my 1.5" adapter/spacer. The spacer is to push the wheel out to match the front track width.
clint
02-09-2011, 01:19 AM | #67 |
Finally sent the final drawing file over to the cutter to get quoted, it includes shims the required shims to center the factory caliper bracket/mount over the rotor. Based on the 12 bolt and the 10 bolt I have it takes between .110 - .130. So each set will have 4 12ga spacers and 24 18ga spacers... 12ga is .10460" and 18 gauge is .0478".
clint
02-24-2011, 07:08 PM | #68 |
Sweet, got the final quote today for all the brackets and shims. All in all there will be 2 main brackets, 4 e-brake plate spacers, 2 caliper adapters, 8 .10 shims and 24 .05 shims plus the nuts and botls. nuts and bolts allwould be grade 8: 3x 1/2 bolts , nuts and lock washers, 4x 3/8 fine thread bolts, lock washers and nuts 2 m14 caliper bolts.
Placed the order today for 10 sets, waiting to recieve the formal bill before they start and it will be about a 3-4 week lead time + shipping (another week). Once they arrive, I will gather the nuts bolts and washers to complete the install and then register with the site to become a subscribing member.. clint
02-28-2011, 01:19 AM | #69 |
cant wait to see what you come up with. I still am trying to follow ya on this one. Thanks Phil
03-04-2011, 06:18 PM | #70 |
well after a week of bad news, one good thing happened. The cutter called to let me know my order shipped yesterday... I was shocked becuase I was estimated 3-4 weeks not 5 days. When they get in, I will post up pic's.
Clint
03-10-2011, 09:34 PM | #71 |
Got the 10 sets of brackets in today.. man that was one heavy box... ups said 62 lbs. I need to run various drill bits through all of the holes to ensure no burrs or snags to prevent the brackets from being bolted up. Other than that everything lookes awesome!
clint
03-10-2011, 09:56 PM | #72 |
Oh yeah, High Octane member ... finally.
Price on these will be 160 shipped (US shipping) Price includes all grade 8 hardware, and caliper bracket shims. Parts required would be: and pakring brake cables such as lokar cables with C-5 ends. Rear brake lines, could go factory C5 with adapters to the silverado fittings of 3/8-24 inverted flare... or go aftermarket braided hoses like these: I purchased the 2pc kit and 14" length and I want to re route it to make it look better than its currently ran. an adjustable proportining valve to dial in the bias and finally modification of the stock rear axles or purchase new ones with camaro spec center register and a flange OD of 5.90. Orders can be placed via paypal or money order. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 03-11-2011 at 10:42 AM. |
03-11-2011, 05:38 PM | #73 |
Cool!
Do you have part numbers for the parking brakes and caliper/cages pictured above so that we can get local pricing?
03-11-2011, 08:16 PM | #74 |
I can get a quote from a local dealer and post up the part numbers. As far as best pricing, I'd say kore3.com has the best pricing. 225.00 for the calipers and cages w/ caliper to cage bolts. If I remember correctly the parking brake shoe/plate kit was 165.00 for both sides. They also have a selection of rotors that range from 41.50 (plain) and genuine GM performance drilled for 90.00. They also have the hoses too. Thats where I found the best deal... even cheaper than oriellys rotors....
clint
03-15-2011, 07:00 PM | #75 |
Laid out one set and snapped a photo. The E-brake holders are set up for Locar Ebrake cables.. they have a threaded rod that passes through the bracket and gets secured with a nut. If you want to use factory LS cables, you can drill out the small hole and use a 5/8 Drill bit and use the supplied holder (the small bracket to the far left) and secure it with the supplied 1/4 fastners.
9 sets left Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 03-15-2011 at 07:02 PM. |
