Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-09-2011, 10:02 PM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Got some jewelry today...
Thanks to everyone'e favorite 'man in brown', I received my new Morel Sportsman roller lifters this afternoon for my 468 BBC. Before you ask, yes it is a hyd roller (aka squishy roller, or 'girlie cam' as they refer to them at Team Chevelle). Got these from Chris Straub @ Straub Technologies. He's also cutting me a custom roller cam to make these babies go up and down in a big way. I had my heads flowed, sent him the #'s and my combo down to the last little detail and bit the bullet.
I had my heart set on running a solid roller, since hyd rollers and big blocks usually mean valve float before 6k, but these lifters are supposed to be good to 7k with the right springs (which I'll be getting from him) - he's cutting me a cam for peak power around 6200-6400rpm with a torque curve that hopefully looks like a Duramax diesel . Now I won't have to worry about running valves or inspecting/rebuilding lifters every few months.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-10-2011, 01:09 AM   #2
Robertjust777
Re: Got some jewelry today...
very nice its alwasy a good feeling when you get something in the mail for your truck..
Robertjust777 is offline   Reply With Quote
Old 03-10-2011, 10:48 AM   #3
Wild83C10
Wild83C10's Avatar
With the right spring you shouldn't experience valve float. I have a SBC with hyd roller lifters and had my N/A setup running 7k+ a few times with no issues. Lighter valvetrain components would probably help as well.
Good luck with the combo, a BB runing 6500+ rpms will be nice.
Have you done any work to the TKO 500? That's going to be a lot of weight and torque for that trans.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-10-2011, 02:14 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
Taking it to Standard Transmission in Ft Worth, TX this coming Tuesday along with my 12 bolt rearend. They're gonna rework the TKO a bit and put some carbon fiber synchro's in it to clean up the high rpm shifting.
I already had the TKO behind the motor before I took it out for this rebuild and it did fine. Supposedly, that 500ft-lb rating is the continuous torque rating, it will handle a peak of 700lb-ft. Same for the TKO600, it is rated at 600 continous, 800 peak. I don't know if all that is bs or not. I do know the guts are the same, just that the 500 has the lower 1st, which I knew would help me get out of the hole a little better with the 3.73's.
Adam
Old 03-10-2011, 04:05 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
...looks like it would complement my recent jewelry purchase...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-10-2011, 04:10 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Wow, TD Machine!!!!
Those are the goods!
Adam
Old 03-11-2011, 02:38 AM   #7
ripdog28
ripdog28's Avatar
Im Jelous. May be in a few months ill start working on it. Should get my heads ported first.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 03-11-2011, 08:50 AM   #8
djracer
djracer's Avatar
Nice pieces good luck with the build.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-11-2011, 11:58 AM   #9
vin63
vin63's Avatar
Originally Posted by BossHogg69 View Post
...I had my heart set on running a solid roller, since hyd rollers and big blocks usually mean valve float before 6k, but these lifters are supposed to be good to 7k with the right springs (which I'll be getting from him) - he's cutting me a cam for peak power around 6200-6400rpm with a torque curve that hopefully looks like a Duramax diesel . Now I won't have to worry about running valves or inspecting/rebuilding lifters every few months.
I went the hydraulic rollers for exactly the same reason, and I was also shooting for power numbers similar to my Duramax, but with a little more horsepower. Here are my lifters, and I made 525bhp @ 5500 rpm and 585 ft/lb at 3900 rpm. on a 462 ci platform. I figured I would rarely be over 5000 rpm on the street anyway.
Old 03-11-2011, 02:36 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
Those Lunati's are probably the same type lifters I have, since Morel makes the higher end Lunati HR lifters. Those numbers aren't too far off what Chris Straub said I'd be making. I'm mainly just looking for big, broad torque with a nice little kick upstairs. I'll probably be shifting at 6500rpm on the track, so there was really no point in getting a SR cam other than the bragging rights. Of course all that bragging goes away when you lose a lifter and needle bearings get friendly with the rest of your motor
I did order my springs yesterday, a set of Crowers with 200# on the seat and 560# open. Hopefully I can get this baby up and moving soon, I'm tired of tripping over parts laying in my garage!
Adam
454, 468, bbc, roller cam
