05-17-2008, 07:19 PM | #1 |
need help finding rear carpet holddown.
Like the title says, I need a rear carpet hold down. This is the piece in the back that also has a strip of rubber on it that presses against the tailgate. I'm getting all new interior in my blazer and my old hold down is not nice enough.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
05-17-2008, 11:44 PM | #2 |
Re: need help finding rear carpet holddown.
HotRod, I have an option for you to consider.........
To the best of my knowledge, nobody makes reproduction carpet holddown strips. But, here is something that looks almost exactly like them and you can find without too much trouble......... A friend of mine at YEAR ONE in Braselton, GA brought me an UNDRILLED STAINLESS STEEL bed-strip that is used for pickup truck beds in CHEVYs through the mid-sixties. This bed-strip is made to go between the WOOD SLATS in the truck bed ( MOST of the time you see these , they are PRE-DRILLED---BUT, they can be found UN-DRILLED) They are about 6 ft. long , so you would cut them down to size and drill holes using your old one as a template. They look SO CLOSE to the original MOST people would not know that they NOT original style !!! I found the ruibber gasket at OBSOLETE CHEVROLET PARTS in Nashville, GA. They even have the raised "rib" to allow the rubber gasket to stay in place under the rib. I don't have a picture to share, but, possibly in a few days I'll get one posted here...... Good luck, Blazester |
05-18-2008, 03:25 AM | #3 |
I'm having a hard time picturing how the rubber attaches to the trim. I look forward to pictures.
05-18-2008, 06:11 PM | #4 |
PROJECT 7DEUCE
I may have an extra one but I dont know if its nicer than the 1 you have now...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-18-2008, 07:45 PM | #5 |
pm sent
05-19-2008, 06:17 PM | #6 |
Here are some pics of the "alternative" strip you can use if you can't find a good used original. Again these are being made for mid-sixties wood pick-up truck beds and are available UNDRILLED. I got mine thru YEAR ONE , but, I'm sure there are many places to find them. They are 8 ft. long .
They are also about 1/4" wider, but, only Blazer fanatics would possibly see a difference once they are installed !! As for the rubber gasket.......just glue it up under the ridge of the trim....no problem Hope you like the option...... Blazester Dave |
05-19-2008, 08:07 PM | #7 |
Thanks for the pictures, I think I'll give them a call on Monday since I don't think I will be able to find anything original that nice. Do you know the approximate cost? Were you able to order only one strip?
05-19-2008, 08:18 PM | #8 |
PROJECT 7DEUCE
Hotrod I only have 2 I thought I had a 3rd but it was the tailgate upper piece.. Looks like year one will be getting a call from ....
05-19-2008, 08:27 PM | #9 |
Thanks for looking.
05-19-2008, 11:09 PM | #10 |
I just jumped on to www.lmctruck.com and located the strips you are looking for...............
Click on the '60-'66 Chevy truck catalog and go page 20...........there's a good picture of the bed strips there. Make sure you see figure 3 . Below in the details you will see figure 3 says " no bolt holes, cut to fit" !!! They sell them by individual strips and the polished stainless steel in 77" is only $20.00 !!! What a deal !!! LMC Part # is 38-7555 My friend at YEAR ONE special ordered them for me ( I'm NOT 100% sure they normally stock them) I know other truck parts suppliers must have them too. Keep truckin' Blazester Dave |
05-19-2008, 11:25 PM | #11 |
Thanks Blazester
05-19-2008, 11:38 PM | #12 |
I'm a poor spectator
This is a great find, definitely not a bad deal.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
05-20-2008, 05:21 AM | #13 |
Also you can get one from a 91 down suburban and cut it to fit, that is what I did to mine back when it had carpet.
05-20-2008, 05:51 AM | #14 |
Thanks, I ordered mine today.. that and about $180 worth of other interior stuff.
03-29-2011, 07:59 PM | #15 |
Please forgive me for stirring up a nearly 3 year old thread but I know most of you guys are still on the site. I was able to locate LMC part #38-7555 (now on pg. 22 of the 60-66 GM Truck catalog). Still $20 for a 77" long strip. Great!
My question is about the seal. Do you use LMC part #38-6963, Tailgate Seal - Lower, priced at $25, on pg. 15 of the 67-72 catalog? HotRodHomi - did you glue it in place? Or was it another seal? Second question - Can you use the same bed strip (#38-7555) to hold down the front of the carpet where it steps down, just behind the front seats? Thanks guys! When I moved I tossed my trim in the garbage assuming someone repopped them. |
03-29-2011, 08:45 PM | #16 |
I bought one but I didn't end up using it. I went with a custom interior instead. it's still in the garage somewhere. It looked great.
03-29-2011, 09:05 PM | #17 |
get a piece of rubber made for a garage door. it will have a 45 bend in the front edge. you can play with. If you search older posts. I told another member about it and he posted some good pics. probably a better seal than the OEM
04-05-2011, 01:22 AM | #18 |
To All: A Big Thanks for the clever solution to an obsolete part. I am finishing up on the interior in my 71 2WD Jimmy & I was agonizing about what to do for my rear carpet hold downs.
Just another testimonial to the power of this awesome resource!
Big Jim- 1972 Chevy 3/4 Ton 71 GMC Jimmy- Factory 2wd |
