04-06-2011, 05:35 PM | #1 |
Got a coil spring question for you guys
I got some coil spring spacers and when I went to put them on today I realized my springs didn't look right? I got the best pics I could, are these lowering springs or have they been heated up? Or did the 1/2 tons come stock with these?
Thanks |
04-06-2011, 05:39 PM | #2 |
Re: Got a coil spring question for you guys
i cant see the pics ?
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
04-06-2011, 05:46 PM | #3 |
Yea it might help if I upload them huh? lol my bad
04-06-2011, 06:03 PM | #4 |
Nope they are just fine. Stock springs im sure. I believe they are a multi rate spring. Someone correct me if im wrong on that. But your springs are fine
04-06-2011, 06:20 PM | #5 |
Hollister, CA.
No sir, those springs have met the heat from a torch....
I seen and heated plenty in my time !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
04-06-2011, 06:23 PM | #6 |
Not trying the argue, But I can honestly say that every 60-66 coil spring rear truck I can remember seeing, the springs have looked like that. Im pretty sure mine haven't been heated and they have the same set of coils that are close just like the OP's
04-06-2011, 06:27 PM | #7 |
Well stock or not, you guys think I should put my spacers in these or try and find some others?
04-06-2011, 06:28 PM | #8 | |
They have been heated. Once an individual coil touchs an adjacent coil it no longer has any "spring rate". I'd go ahead and try the spacers but I am betting it will ride very rough though. Once you put in the spacer you will only have 1 wrap of coil acting as the entire spring, all the other wraps of coils are already collapsed. Last edited by lakeroadster; 04-06-2011 at 06:34 PM. |
04-06-2011, 06:30 PM | #9 |
What exactly do you mean by spacers? The things that go in between the coils to give the springs some lift?
04-06-2011, 06:31 PM | #10 |
Yes sir. I've got some coil spring spacers to raise the rear end up 2.5".
04-06-2011, 06:33 PM | #11 | |
Hollister, CA.
04-06-2011, 06:33 PM | #12 |
Well im beginning to think ive been wrong about the springs, but it cant hurt to try the spacers. Worst case scenario, they dont do what you want, and maybe a new set of stock springs will get you where you want.
04-06-2011, 06:35 PM | #13 |
Hollister, CA.
If you cant find some truck springs ... try some G-body ones.
Not sure what the height would be.
04-06-2011, 06:39 PM | #14 |
How would I lift it by the frame? I just thought the spacers would be best for me cause right now I'm still in high school and am low budget.
04-06-2011, 06:41 PM | #15 |
Hes saying to undo one side of your rear shocks to give you some spring travel and jack the truck up by the frame to stretch the springs out, and put the spacers in between two of the coils that are closed up
04-06-2011, 06:45 PM | #16 |
And you will never get a 2-1/2" spacer between the collapsed coils in the center. The only place the spacer will fit is either near the upper coils, or the lower coils.
And with only a couple coils really doing all the work the ride will be harsh. How does the truck ride now, without the spacer? Last edited by lakeroadster; 04-06-2011 at 06:46 PM. |
04-06-2011, 06:48 PM | #17 |
Thanks for the info guys, I appreciate it a ton!
04-06-2011, 08:28 PM | #18 |
He has the (variable)rate springs under his truck,they were used on the heavy half tons and the c-20's.they have the 3 coils almost touching each other in the center versus the (normal) or standard coils.the heavier coils are also thicker by quite a bit over the standard rate springs,and much heavier to lift.i tried a set like those and they sit the same but are much stiffer.i have 2 pairs if anyone needs them.
04-06-2011, 08:28 PM | #19 |
Those springs are "sprung" the coils are not designed to touch each other. If not a torch that truck was used for many years hauling something of significant weight to break em down like that. New ones are cheap, you need em for sure !
Billy 65 C10 ............................... ____ ................ ________-|___\____ .;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________ P.S. Send truck money ! |
04-06-2011, 08:42 PM | #20 | |
04-06-2011, 08:48 PM | #21 |
CLASSIX Truck Club
I have cut the springs on 4 different trucks, and all the springs have looked like that. Definitely not heated but could be collapsed. These trucks are old.
04-06-2011, 09:01 PM | #22 |
Here are some pictures of the springs that miller has now there is a larger gap in these between the center coils but these of course are unladen being out of the truck.there was 1/8" or just a hair more of clearance between the center coils when they were mounted.check out the thickness of the coils.
04-06-2011, 11:43 PM | #23 |
my c 20 has these springs but the do not touch . you cannot get these springs from any spring company they say the sell them, but they are completely different . not the tight coil setup
04-07-2011, 12:28 AM | #24 |
yes your right, 20-30 years ago you would see these quite a bit when 3/4 tons were seen daily.miller92's springs have sagged and compressed over the years.when i bought my 62 they had standard 1/2 t springs that someone did a piss poor job of heating and lowering so i put a pair of the heavy duty springs under it and it was a little to stiff for me anymore so i opted for a (light duty) standard set.i just figured i would keep these around in case i change my mind.
04-07-2011, 02:29 PM | #25 |
Thanks for all the info guys, yall have been a big help!
I'm currently trying to find some springs that went under the 2wd 3/4 ton pickups and hopefully that'll raise it a bit. I knew the truck looked lower than normal but never did check it out. Now I know why. The front is a lil lower than I like but I can't change them myself so those will have to wait a while. Only 3/4 ton springs I've found so far are in LMC for $70. Didn't seem too bad to me but imma try to find some for cheaper first. You guys know what year springs will work for these pickups? |
