Collector of Projects
Bed Rail Covers Caps
I did some looking around and didn't find anything... I just took the top off the Blazer and where the door meets the bed side, it looks incomplete. I was wondering if anyone ever made (or mass produced) some kind of cover the matched the height of the door. Something that could be bolted on from the bottom like a double wall top. It would have to include a piece for the tailgate as well to match the profile.
Quick Photo-Chop before/stock ![]() after/raised bed rail ![]() Last edited by mcmlxix; 04-06-2011 at 02:54 AM. |
Re: Bed Rail Covers Caps
Nothing ever made that I've seen but some shave/cut down the doors to match the bed rails when it matters that much to em.
I want to keep the truck functional... ie: remove bedrail caps and put the top back on....
SKINNY TIRES RULE!
If you add it to the bedrails, you'll nee to add it to the tailgate too or you'll have the same visual problem there.
I thought there was someone who was making bedrails that are tapered (angle down from the door height to the bed height over the distance of the side rail.) He made/was going to make them removable so he could still use the top, but I don't remember who that was...
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Do you want it made of metal or....? I would assume any decent upholstery shop could use maybe a red vinyl or leather and make what you want. It's basically a long skinny door panel to an upholsterer.
not upholstered... First choice would be metal, next would be something like Delrin, last thought would be wood wrapped in fiberglass and painted...
why the aversion to upholstered rails?
Actually fiberglass might give you the best result. Last edited by SeventyOne; 04-07-2011 at 07:09 PM. |
#8 | |
PS: the red truck I used for the photo chop is not mine. I just borrowed it from Pirate 4x because it was a good clean pic from the side... ![]() Last edited by mcmlxix; 04-07-2011 at 08:43 PM. |
I see. Well if you are looking to spend the coin try a body/resto shop. Probably going to be expensive to craft them out of metal though.
