Old 04-06-2011, 07:00 PM   #1
72gmcshorty
72gmcshorty's Avatar
Any vendors do body bolts?
Do any vendors offer just the 2wd blazer body bolts as a kit? I bought one of those body mount kits and cheaped out on hardware thinking i could easily find it. Unfortunately, these things are just not easy to find. I tried one of those trailer places but nothing long enough. Can anyone maybe think of somewhere else to look?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-06-2011, 10:07 PM   #2
SeventyOne
Re: Any vendors do body bolts?
LMC or probably any of the vendors. I just bought a set of bolts and the necessary washers/nuts to go with a poly body mount set I got from Energy Suspension.
SeventyOne is offline   Reply With Quote
Old 04-06-2011, 11:06 PM   #3
72gmcshorty
Problem solved. My local home depot had all the bolts, washers, locknuts, and posi-lock nuts i needed.
1992 Gmc 2wd
Old 04-07-2011, 01:31 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
I hope they are at least grade 5, if not grade 8.... think about the force needed to keep the body mounted to the frame... there have been discussions about this....
Rich
1972 K5 Blazer CST Click HERE
Old 04-07-2011, 07:07 AM   #5
rsavage
rsavage's Avatar
Originally Posted by 72truckman View Post
beware LMC kit comes with hex bolts, not carriage like stock
I just bought (within the past three weeks) and installed an LMC rubber body mount kit on my Blazer and it had the correct carriage bolts. Mount position #2 (front floor area) does use hex head from the factory.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-07-2011, 12:14 PM   #6
dubds10
Stalker Nate
Typically Carraige bolts are made in Grade 2 strength, unless otherwise noted on them. I used to sell industrial supplies and many people thought Carraige bolts and hex head bolts were all the same strength. They aren't and there's no need for a grade 8 bolt from body to chassis. There are certain strengths you look at in bolts for certain reasons, and how the body is mounted I don't see a need for grade 8 bolts. I tend to put grade 8 in most everything I do just because, and not always because it's required.
Too bad you already got the bolts, I probably have body bolts sitting around and I know forsure I'll have a few blazer sets of bolts in a little while here.
Nate
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 04-07-2011, 08:27 PM   #7
72truckman
72truckman's Avatar
My bad, forgot i bought the ORD 1" body lift and had to use their bolts
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 04-07-2011, 11:26 PM   #8
SeventyOne
I just received all the body mount kit hardware from LMC. Everything seems as it should.
TruckMan - how do you like the body lift? Are your bumpers hanging 1" low now?
Old 04-09-2011, 12:38 AM   #9
72truckman
72truckman's Avatar
I like it, didnt plan on needing it but i mounted my NV4500 about 1/2" too high. only con is the bolts all being standard hex heads and not carriage bolts. the bumbers are an inch low, but its not really noticable on the rear and the only noticable part on the front is that the gap between the grille and the bumper is almost non existent
Work in Progress
Old 04-09-2011, 01:54 AM   #10
mcmlxix
mcmlxix's Avatar
now?
I have the 1" ORD body lift as well. In the pic you can see where the bumper ends up in relation to the front grill surround. The fan shroud had to be lowered to clear the mechanical fan and the shift linkage on the column is a little off now.
Rich
