04-11-2011, 11:57 AM | #1 |
Stock Horn or Aftermarket?
I've tried searching for this, but haven't found anything definitive.
Question 1 answered1. I'm a little confused by what is stock because LMC Truck lists a high and a low. Is the high and low contained in the same component or are there two horns in your engine compartment? If two, where are they located?Answered 2. Are you using the stock horn(s) or aftermarket? If aftermarket, where did you get it and was it simple to install? I don't really need anything fancy, just effective and easy to install. My Painless wiring kit has one wire that goes to the horn. I want to make my solution as simple as possible so your thoughts, opinions, and pictures if you have them! 3. I have an aftermarket steering wheel with a tab and wire. How do I hook up an aftermarket steering wheel to a stock tilt column (van tilt in my case)? Any help you can provide with any of these three would be appreciated!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 Last edited by es67chevy; 04-11-2011 at 03:28 PM. |
04-11-2011, 12:13 PM | #2 |
Re: Stock Horn or Aftermarket?
two horns one hi one lo
the easy way is to fabricate a jumper wire on the horn wire in your harness// thats the way the factory did it very important is the mounting of the horn on the core support as the connection there is your ground for the horns
04-11-2011, 03:08 PM | #3 |
Thanks, cdowns! Do you have any pics showing the stock setup (where mounted)?
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
04-11-2011, 03:11 PM | #4 |
20' Daredevil (Ret)
Here's a pic from a recent thread, showing one horn & the wiring going from it to the other horn. Not everything you asked for but I hope it helps.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-11-2011, 03:16 PM | #5 |
Thanks Stocker! Do you know if the other horn is in the same place on the passenger side or is it elsewhere?
04-11-2011, 03:21 PM | #6 |
20' Daredevil (Ret)
Actually they are both on the drivers side.... the green wire going to the left is heading towards the drivers fender. It goes to the horn which is mounted a few inches from the one pictured.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 04-11-2011 at 03:22 PM. |
04-11-2011, 03:29 PM | #7 |
Thanks again. For anyone else, I'm still looking for answers to question 2 and 3. I may have to separate into individual threads, but thought I'd try this way first.
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 Last edited by es67chevy; 04-11-2011 at 03:29 PM. |
04-11-2011, 03:36 PM | #8 |
20' Daredevil (Ret)
I have an old Grant wheel on my truck... it came with an adapter which is needed to mount the wheel and for horn operation. If you don't already have an adapter, you will probably need one.
Horn operation is fairly simple. When the wire at the steering wheel is grounded, it operates a relay under the dash (you can hear it click as you ground the wire). When that relay operates, it sends -12vdc to the horns via the green wire. The circuit is completed by the horns being grounded through their mounting bolts to the core support, which is why Cliff said it needs to be properly grounded.
04-11-2011, 04:01 PM | #9 | |
04-11-2011, 04:13 PM | #10 |
I bought one from a modern chevy truck and installed it indise the left fender it is pretty loud and it is concealed.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-11-2011, 05:40 PM | #11 |
Was it difficult to wire up? Was it just the one wire with body as ground like the older units? Any idea about what year? Thanks!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 Last edited by es67chevy; 04-11-2011 at 05:40 PM. |
04-18-2011, 10:57 AM | #12 |
Still looking for horn pics and details on how easy it was to install what you have. Also, here are pics of my horn button. I'm not sure how I make a button that works by wire work with the stock turn signal switch to operate the horn. It looks like in the stock column the horn is activated by pushing the brass? pin. Not sure if that is what operates the stock horn or not.
04-18-2011, 01:29 PM | #13 |
On both of my trucks, I have the OEM horns hooked up via the horn button on the steering wheel. I also have air horns on both trucks with a horn button mounted under the dash. On my CST I also have a wolf whistle and a cable operated horn that sounds like a cow/bull. I guess I like horns.
I bought all the aftermarket horns from WOLO. http://www.wolo-mfg.com/
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
04-18-2011, 01:53 PM | #14 | |
04-18-2011, 02:00 PM | #15 | |
04-18-2011, 02:10 PM | #16 |
Eric,
My CST has an aftermarket wheel and my C20 has a stock type wheel. Maybe someone can post up a picture of the stock setup. Both of my horn hookups in the wheels were simple....sorry I don't recall the details, I'm old and it has been a while since I messed with them.
04-18-2011, 07:20 PM | #17 | |
Tags |
aftermarket horn, horn |
