02-17-2011, 01:25 AM | #1 |
dave
engine help please
ok,heres the deal as some of you know,i'm doing a engine swap in my burb,a 2005 lq4 6.0 litre....from a gmc savanna.... "project Dirty Burb" got power to the new fuel pump fuel line ran, no return line on this 1 all hooked up but it wont start unless sprayin carb cleaner into the intake.... only thing i can think of is vacuum lines need to be hooked up or .. the mass air flow hooked up to the throttle body....it hasnt been the last few times i tryed....my garage smells really really bad from the gas fumes, terrible like it's only tryin to run on fuel,,,,,thats y im thinking the mass air flow.....anybody a chevy expert...or really know your chit PLEASE HELP thx dave
check out my build "DIRTY BURB" |
02-17-2011, 02:55 AM | #2 |
What?
Re: engine help please
I'm gonna move this over to the Engine/drivetrain side of the house, where you will get the right eye's on it for ya.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
02-22-2011, 11:57 PM | #3 |
"Anti-theft devices may also be used to deactivate the fuel pump if the vehicle security or anti-theft system detects any type of tampering associated with vehicle theft. In the case of many General Motors vehicles, the engine will momentarily start and stall if the anti-theft system deactivates the fuel pump relay. Other anti-theft-related problems include defective ignition keys or key detection systems in the ignition switch" - Counterman Magazine
Read this: http://www.counterman.com/Article/82...y_systems.aspx It will help you understand the modern fuel system and hopefully point you in the right direction... or hint you of a possible cause. Good luck |
04-26-2011, 12:56 PM | #4 |
dave
ok i'm back, i think ok so here's the newest update eng/wiring wise....burb starts, runs....but wont turn off..has to run out of gas to stop OR disconnect battery and it shifts into gear but doesnt move...the newest info i hear is this: the eng/tranny are from a "05 express van, savanna...& my ecu is from a 03' !!!!!!!!!!!!! i'm hearin that it wont work...as far as the harness, everything hooks up perfect....but still havin these issues and no 1 seems to know how to fix it......HEEEEEEEELPP PLEASE thx dave
04-26-2011, 02:14 PM | #5 |
Has more rust than truck...
The not turning off is going to be a wiring issue. The trans control could be wiring or in the computer tune. Who did your harness and computer?
04-26-2011, 03:01 PM | #6 |
dave
fuel injection specialties in texas it's an o3" ecu i'm told they changed it in 04' so it won't work on my o5'.......i havent a clue....vats removed,,has to be reflashed, wheel size is wrong as is the gears....
04-26-2011, 03:46 PM | #7 |
it is all different since your engine came from a van, I think the vans were the same up to 06, so 99-05 was DBC I believe. VATS does need removed and then it should run, the tire size is for the PCM to be able to talk nice to the trans and the other way too. how much are they charging you if ya dont mind be asking?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-26-2011, 03:58 PM | #8 | |
dave
so you agree that my o3' pcm won't work with my 05' eng/tranny? the pcm was sold to me by a guy here on this forum who WAS my friend...i think he knew it wouldnt work because he disappeared soon after he sold it to me....so sounds like i need a oem pcm, then have it flashed to my specs, as long as it's a 05' 6.0/4l80e trans?
04-26-2011, 04:33 PM | #9 | |
04-26-2011, 04:38 PM | #10 |
dave
ok so what does that mean, or what does it do? & how 2 make it work...thx again
04-26-2011, 04:56 PM | #11 |
As long as your throttle uses a cable, you're good and it will work fine.
I would start by calling the people that did your harness and tell them whats going on. In order for your engine to stay running a relay has to be wired wrong. Then worry about the trans issue. |
04-26-2011, 07:45 PM | #12 |
I may be off base here but I think you need to have your ECM flashed to your engine VIN #. Then everything should mate up (once the VATS is removed).
(The old rule of engine swapping, make the engine think it is still in the car it came out of) Anyway, that is what worked for me. Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
04-27-2011, 11:23 AM | #13 |
Wiring harness needs to be reviewed and all the hook ups to that harness.
You can make a DBW wire PCM into a DBC but you have to change somethings on the harness; ie it will now need TPS and IAC inputs. is this a MAF or SD set up? do you have IAT input? ETC input?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
04-27-2011, 03:39 PM | #14 |
dave
wow shon.....WAY over my pea brained head.....i have no idea what u just said..sorry i have some1 checking it out now HOPE HE'S GOT IT, cause i don't obviously
