Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Closed Thread
Old 04-26-2009, 08:51 PM   #1
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: door handle replacement HELP!
I got the 2 bolts removed easily but can't figure out how to get the rod detached so I can swap out the handles.
The verticle rod has to be disconnected from the latch mechanism at the bottom in order to fully remove the handle from the door
Here the retainer clip has been removed and the rod removed from the latch mechanism. You can see the retainer clip sitting below the rod here just before it dropped to the bottom of the door.
In oder to remove the handle from the door you have to depress the thumb button while pulling the handle away from the door. This alows the linkage at the top to rotate enough to clear the opening in the door.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline
Closed Thread
