Wheel wells for 67-72
Check out these wheel wells for a slammed 67-72. They are in the process of being made from fiberglass and the first ones will be ready for sale in a month. Both front and rear wheel wells look like a factory GM set, but raised enough to make a low stance. The blazer below is at ride height and has lots of suspension travel! I have been surfing this site for years and enjoy the information and vendors I have found. When these become available I'm going to become a vender on this site. I welcome any feed back you might have.
Last edited by Hill's Rod & Custom; 05-18-2011 at 12:04 AM. Reason: more pictures |
Re: Wheel wells for 67-72
I want a set of those front ones! Please keep us informed as to your progress
![]() Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
GM Addicted
any future plans for the 73-87 chevy trucks??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
I'm happy to see you guys on here all of your trucks are amazing.67-72 and 73-87 parts will sell easy on here good luck hope to see parts from you.
can you the stock hood hinge with the front inners?
A guy with a truck
My first instinct is 'no'. There's maybe an inch clearance with stock tubs, looks like these are more than that.
Man, when it rains, it pours. These will be cool. Should be able to build a completely bolt-on, frame-laying show truck soon... Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
A guy with a truck
This is the truck with the 'touring' dropmember, correct? So, these will clear the upper a-arms and steering shaft? If so, cool
these wheel wells will not work with stock hood hinges. I am using the hinges in the cowl from porterbuilt street rods. I set the front up with the drop member from them to. The wheel wells cover the upper control arms and mounts for a clean look.
Posted via Mobile Device |
awesome!!! how much are the fronts gonna be? also whats the biggest diameter tire you can use to still lay frame? Thanks
#10 | |
#11 | |
interested??? Prices?
wasn't a member working on this exact thing just a few weeks ago? is this a joint deal or something brand new?
low n' slo
![]() Join Date: Mar 2009
67cheby?
i think he made a set too, not sure if its this same one though...they sure do look cool though
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#15 |
Hey guys I have seen these wheel wells in person, these pictures do them no justice. They look like they are factory wheel wells but will allow you to lay out. Also that blazer in the above pic is at ride height.
#16 |
67cheby
![]() Join Date: Sep 2008
no this is not a group effort, not the same as mine
#17 |
What on the firewall and fenders needs to be modified to make these fit?
#18 |
Garage wrench
^^ also interested in this
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#19 |
The firewall does not need any modification,they bolt in to the stock mount on the firewall. The fenders need to be trimmed to the new wheel well opening, and the outside flange needs to be rolled up for more tire clearance. I made a sheet metal piece to fit the top of the wheel wells that is welded to the fender and has additional bolts to help secure the top of the well, like the stock ones. The two bolts are screwed from the bottom and are not seen from the engine bay. More pictures will follow to help show what I'm talking about.
#20 |
how much?
#21 |
The front pair are going to run 750 and the rear will run 650. I'm going to sell front and rear with a discounted package deal. Also thinking of a group rate with discounts as well. I'm going to wait to take orders till the fiberglass ones are in my hand.
#22 |
Blazerologist
I seen these in person. They look so true to the originals - as if laying frame was an option . . . . Just ordered mine (2 sets). Cant wait!!
![]() Last edited by K5 Blazer; 05-20-2011 at 12:23 AM. |
#23 |
Any new info?
#24 |
are they available now? any more detailed pics?
Doug Looking for a 67-72 short bed driver..... |
#25 |
Anything new on these?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Tags |
blazer, dropmember, suspension, wheel wells, wheelwells |
