Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-16-2011, 12:44 AM   #151
chev-obsession
chev-obsession's Avatar
Re: Power Steering Adapter Plates
Whanks for the fast shipping! its a great product!
I bought the new steering coupler, What do i need to do for a rag joint?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 07-16-2011, 01:45 AM   #152
Captainfab
60-66 Nut
If your steering box doesn't have one on it, you will need the correct one for that box. There are 3 different sizes/splines on the input shaft. There are 2 different splines on a 3/4" shaft, and then a 13/16" diameter shaft. A Napa store might be your best bet at finding someone that can figure it out and get you what you need. If you happen to know what year your steering box is, that will be a big help.
Old 07-24-2011, 09:52 PM   #153
66 lwb cs
66 lwb cs's Avatar
Haven't had a chance to install yet but part looks great recieved it quick and nice directions. Thanks Captain.
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 07-29-2011, 05:42 PM   #154
gtonut1970
i would like one too, please pm me with purchase info, thanks
gtonut1970 is offline   Reply With Quote
Old 07-29-2011, 11:48 PM   #155
Captainfab
60-66 Nut
PM sent....thanks
Old 08-02-2011, 09:24 PM   #156
blitzen6965
blitzen6965's Avatar
Hey Cpt. Sent you a PM a little earlier today. New member and looking to get one of your ps adapters. Thanks
blitzen6965 is offline   Reply With Quote
Old 08-02-2011, 11:10 PM   #157
Captainfab
60-66 Nut
I replied to your PM.........
Old 08-02-2011, 11:56 PM   #158
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Welcome to the forums.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-29-2011, 06:53 PM   #159
pdxhall
pdxhall's Avatar
With so many different variations that guys are using for the conversion I'm still just a little confused. Can I use the the original 66 idler arm and steering linkage with a 79 pitman arm or do I need to make other changes. I will be ordering the adapter plate soon and I just want to know where I stand on this conversion. Thank, Brett
pdxhall is online now   Reply With Quote
Old 08-29-2011, 07:59 PM   #160
LostMy65
LostMy65's Avatar
You can keep everything and just install the powersteering box with its pitman arm:
All linkage and idler arm can remain.
Here is my conversion:
http://67-72chevytrucks.com/vboard/s...d.php?t=438509
The template I made is now included with Captain's Adapter Plate.
Old 08-29-2011, 11:47 PM   #161
Captainfab
60-66 Nut
If you are keeping the drum brakes, then you can keep the original draglink, idler arm, and tie rods. If you are converting to discs, then if you keep your original steering linkage, you will need to change at least the outter tie rods. There is an off the shelf tie rod that allows you to do this without the need for the expensive adapter sleeves, but I don't have that part number. You might try posting the question, here on the forum, Someont here posted the number not long ago. I wasn't concerned with it, as I always change all the steering linkage to the later model components. That requires locating and drilling new holes for the idler are though. It isn't difficult if you just take your time and use the original for a reference.
Old 08-30-2011, 12:15 AM   #162
pdxhall
pdxhall's Avatar
Thanks for the information. That's what I was hoping. I already have new 2 1/2" drop spindles, new tie rod ends and adjusters, and the idler arm and steering linkage installed. I temporarily put the stock manual gear on so I could manuver the truck to work on it. Right now I'm in the process of redoing the rear of the frame and suspension.
Capt., I'll be ordering your adapter as soon as I finish up the rear suspension upgrades. Thanks, Brett
Old 09-06-2011, 05:51 PM   #163
Slowtruk
Slowtruk's Avatar
Hey john, as you knowI bought this bracket from you a week ago (looks very high quality btw) and I was just wondering, will this fit 60-66? I originally bought it for 65 but I need another one fr 61. Thanks!
IBEW Electrician-Nick
1985 C20 Silverado
1965 C-10 short fleet
1961 c-10 Apache short fleet
2005 Chevy Suburban LT
2012 Hyundai Sonata
Slowtruk is offline   Reply With Quote
Old 09-06-2011, 08:23 PM   #164
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
I just sent payment! Maybe there outa be a cowbell every time one is sold!
Harley1650 is offline   Reply With Quote
Old 09-06-2011, 08:35 PM   #165
Slowtruk
Slowtruk's Avatar
1985 C20 Silverado
2012 Hyundai Sonata
Old 09-06-2011, 11:59 PM   #166
Captainfab
60-66 Nut
The current adapter plate works only on the '63-'66's. I have been wanting to design one for the '60-'62's but just haven't had time.
Old 09-14-2011, 08:49 PM   #167
bryankichler
bryankichler's Avatar
Received mine today super fast shipping and quality product
bryankichler is offline   Reply With Quote
Old 09-14-2011, 11:07 PM   #168
Captainfab
60-66 Nut
Thanks for the compliment Bryan
Old 09-15-2011, 08:30 AM   #169
bryankichler
Id feel better if that was the case I have all the time in the world right now. Going through demobilization trying to get back home lots planned once I get there. Build thread is coming.
Old 09-26-2011, 05:27 PM   #170
Harley1650
Harley1650's Avatar
Another satisfied customer of Captainfabs plate. The truck is at the shop getting aligned after completing power disc brakes, new suspension, and now POWER STEERING!!!! The only thing I would suggest is not messing with pre made hoses. That was the worst part of the job. I should have just had them made........
Old 09-27-2011, 12:50 AM   #171
Captainfab
60-66 Nut
Thanks for the kind words
Old 09-27-2011, 12:33 PM   #172
cepatterson84
Hey captainfab I need your power steering plate for a 64 Chevy truck
cepatterson84 is offline   Reply With Quote
Old 09-28-2011, 12:45 AM   #173
Captainfab
60-66 Nut
PM sent. Thanks
Old 10-08-2011, 11:39 AM   #174
66BowTieBoy
66BowTieBoy's Avatar
Hey John,
The steering bracket & brake adapter arrived ON TIME as you said it would. Thanks...
I must say, I have purchased a bunch of stuff from the likes of Classic & LMC, but your speedy service and packaging is the best.
Not only that, YOU ARE ONE FINE WIELDER.....!
Thanks again for your product & service.
Danny aka: 66BowTieBoy
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....!
66BowTieBoy is offline   Reply With Quote
Old 10-08-2011, 10:37 PM   #175
Captainfab
60-66 Nut
Thank you for the compliments Danny, I appreciate it
Originally Posted by 66BowTieBoy View Post
Hey John,
