06-12-2011, 12:46 PM | #1 |
New vendor for you wiring needs!
Well, sort of new. I've been around awhile but have been so busy setting the new shop up that I didn't get much time to be on here. Now that I have working internet at the shop it's a lot easier
Downriver Motorsports Wiring is a michigan based company. We handle everyhting from basic repair to full vehicle wiring. If you need a custom wiring harness built from scratch to fit a LS engine in you truck we do that. If you have a factory harness that you want modified to work in your truck we do that too. I started the company after building prototype harnesses for 10 years for a supplier for the Big 3. While I was doing that I started wiring drag cars, hot rods, and such on the side. We only use top quality parts and never skimp on quality. If you have us modify a stock harness for you it won't come back without new coverings on it, profesionally taped using correct tape, not just cheap vinyl tape, and any unused circuits will not just be taped inside the harness, we remove the circuits properly. If we have to remove a wire from a splice we redo the splice so that one wire isn't hanging out. When the harness is done it will be bundled with the smallest diameter covering that will fit. I know not everyone can bring thier truck to us to have it wired, but if you can give dimensions of what you need built for harnesses we can build it. I also have a 1986 GMC Sierra standard cab long bed that's getting a 6.0 and a 4L80E setup and a 1991 Chevy Suburban that's rusty as heck, but still hauls like the day it came out of Flint, keep your eyes on the forums for updates on these two. |
06-13-2011, 01:24 AM | #2 |
Garage wrench
Re: New vendor for you wiring needs!
very cool, welcome
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
06-13-2011, 04:13 PM | #3 |
PM sent
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-13-2011, 05:55 PM | #4 |
could i geta idea on price for a harness for a 5.3/ 4l60e. that the wires are routed towards the rear of the engine...wiht the fuses and relays..
06-19-2011, 12:47 AM | #5 |
06-19-2011, 10:03 AM | #6 |
Whats up with the website?
07-21-2011, 09:49 PM | #7 |
PM sent.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
07-21-2011, 10:58 PM | #8 |
6>8 Plugless........
Welcome to the board as a vendor! Do you ever get into the diesel swap harnesses?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-09-2011, 02:48 PM | #9 |
Location: Sunny, Florida, some might call it South Alabama
Could I get this also?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
08-09-2011, 02:59 PM | #10 |
website still not working
