Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-15-2011, 01:43 PM   #1
72SWBURG
Dynamat the Cab......
Has anyone put dynamat in the cab of their 67-72 c10's?? If so, where?? and did it make that big of difference??
Brett
72SWBURG is offline   Reply With Quote
Old 08-15-2011, 05:17 PM   #2
jimmydean
jimmydean's Avatar
Re: Dynamat the Cab......
It makes a huge difference. As for "where" that is debatable. What do you want it for? If it is to quiet the cab, put it everywhere basically. If you want to quiet rattles, I just ran a strip on the inside of the door panel.
I used Peel and Seal. Not as good for sure, but it works well enough for me.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-15-2011, 05:29 PM   #3
72SWBURG
I want to quiet the cab mainly... This pickup doesn't have any rattles (believe it or not).... I was thinking headliner, door panels, from back window to firewall...
Old 08-15-2011, 11:21 PM   #4
funkytechmonkey
funkytechmonkey's Avatar
You can never over-do dynomat... I havent done my C10 yet but I plan on doing everything possible. If you have the cash.... do it ALL.
I have an 08 tundra crewmax that I put 2 12"s in and I took the time to dynomat everything. All 4 doors, floor, roof, back wall, and anything else I could cover. I use-to work for a car stereo place a while back and I got hooked on dynomat.... Im a firm believer in it. Its worth taking the time and cash to do it right.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 08-15-2011, 11:41 PM   #5
72SWBURG
Thanks for the info
Old 08-15-2011, 11:50 PM   #6
bigwheel15
bigwheel15's Avatar
If youre wanting to get the inside of the cab quiet dont just do layer after layer of peel n seal/dynamat or the like. What you wanna do is use a mass loading vinyl. Read a little over this website www.sounddeadenershowdown.com, layers upon layers of sound deadener to reduce noise is really an outdated idea as well as expensive.
bigwheel15 is offline   Reply With Quote
Old 08-16-2011, 01:13 PM   #7
jimmydean
jimmydean's Avatar
Over my peel and seal, I used some industrial rubber foam mat (almost a 1/2" thick) then carpet. The inside of my truck is so quiet, you almost don't know it's running.
I got the mat from a carpet store in town. I called them looking for something, he asked what it was for and was excited to help (he has a '55 Chevy truck). He gave me enough to cover everything and because it wasn't enough for anything he does, he just gave it to me.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-16-2011, 05:53 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
Jealous....
Super Jealous....
Haha...your cab look great, jimmydean!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 08-17-2011, 01:49 PM   #9
jimmydean
jimmydean's Avatar
Originally Posted by tubbedII View Post
Jealous....
Super Jealous....
Thanks! I hope to get my wheel this week, repaint the dash (didn't like the first color), paint the rest of the cab to match and get ready to install some speakers.
Still fighting with myself on the amp(s) and subs. I change my mind daily at this rate. I think it will come down to what is on the market when I have the cash available. Had I pulled the trigger on a pair of old school Planet Audio tube amps a few weeks ago, this would not be an issue today.
The other issue is NOBODY has shallow mount subs mounted to hear in person. The Kenwoods got the best overall review and the price is right. But I want to hear them first.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-17-2011, 06:44 PM   #10
jimmydean
jimmydean's Avatar
My steering wheel should be on the way, I'm stoked. I have a feeling it is going to be as much work (if not more) than the seats were, but if it works, oh man...
Still need to locate a horn button, but I've been looking for one of those almost as long as I was looking for the wheel.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-17-2011, 07:22 PM   #11
Dunenutt
Newbee
Dunenutt's Avatar
Apply Dynamat to everything that wont be visible! Inside doors, firewall, back wall, if you can reach it stick it on. Dont leave gaps, and tape the seams. If you dont tape it, it will deposit gooey black nasty on everything it touches.
I shot mine with Al's liner, then dyna mat. Next truck I do will be shot with lizard skin then dyna mat, for better insulation.
The stuff is not cheap, but well worth it.
Dunenutt is offline   Reply With Quote
Old 08-17-2011, 07:34 PM   #12
jimmydean
jimmydean's Avatar
Damn, I learned that the hard way. Good thing I will be pulling it all back apart when I swap the cab to the new frame.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-27-2011, 08:37 PM   #13
cableguy0
Dynamat everywhere. Especially use it on the single layer steel. The inside of a truck cab is like a hollow drum. The aluminum tape home depot sells works great for the dynamat seam. Just be careful with the tape. Once its stuck down dont plan on taking it off without tearing stuff up.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-07-2011, 08:32 AM   #14
OJ1988
Just a car guy
OJ1988's Avatar
I used 50 sq ft of FatMat in the cab of my 69.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-18-2011, 08:04 PM   #15
66GTO66C10
66GTO66C10's Avatar
Fat Mat is the way to go. 1/2 the cost of Dynamat and performs great!
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 09-21-2011, 08:22 PM   #16
Blake_H
Blake_H's Avatar
So, if you used 50 square feet for a regular cab then I will need a 100 square feet for my crew cab? Does that sound right? I want to cover it just like yours.
Thanks for the help!
Blake_H is offline   Reply With Quote
Old 09-22-2011, 10:18 AM   #17
66GTO66C10
66GTO66C10's Avatar
100 square feet will cover your crew cab and inside your doors.
Mike.....
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Old 09-23-2011, 12:04 AM   #18
Blake_H
Blake_H's Avatar
Mike.....
Thanks Mike! Just got it ordered up.
Old 09-23-2011, 11:42 AM   #19
66GTO66C10
66GTO66C10's Avatar
Good luck!
Mike......
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Old 11-08-2011, 10:11 AM   #20
kieth
kieth's Avatar
I went to Home Depot (in the roofing section) bought some butyl rubber backed with aluminum--it already had peel and stick adhesive on it, cost about $1.25 per sq foot then topped it off with closed cell foam insulation that had adhesive and aluminum backing, my truck is as quiet as a church mouse and it does not go dumb dumb dumb......cost $2.50 per sq ft total.
http://kieth.smugmug.com/Trucks/66-G...752_U7LmV-A-LB
The insulation was for duct work and the butyl rubber aluminum backed material was for roof repairs around vents.....it worked great and cost a whole lot less.
we even did the inside of the doors
http://kieth.smugmug.com/Trucks/66-G...8_gTsgqzj-A-LB
kieth is offline   Reply With Quote
Old 11-08-2011, 11:37 AM   #21
tubbedII
needs more $$$
tubbedII's Avatar
I've never used the stuff, but I've heard the smell is bad...
1970 2wd Blazer
Old 11-10-2011, 07:00 PM   #22
kieth
kieth's Avatar
It has no smell, it is the same stuff that they use in dynamat.....butyl rubber and aluminum....it really quieted things down. Kieth
Old 11-16-2011, 05:51 PM   #23
jimmydean
jimmydean's Avatar
Mine had a little smell when I first had it in the cab before I put anything on top, but it was right after I did it. My cab got hot (portland hot, not Phoenix hot) and I didn't notice an odor.
I have a mat and carpet in now and don't smell a thing. My cab is dead quiet now, it's awesome.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 12-04-2012, 10:56 PM   #24
Roman_Soldier1989
I planned to put down dynamat to improve the engine rattle and speakers sound. I am curious if you can put rhino liner down on top of dynamat or is there a better way to get the benefit of sound proofing and the muddy boots and floor protection you get from rhino liner?
Roman_Soldier1989 is offline   Reply With Quote
Old 12-05-2012, 02:39 PM   #25
tubbedII
needs more $$$
tubbedII's Avatar
If you're looking to spray something like a Rhino liner down, I'd try the lizard skin product...it looks just like rhino liner after sprayed and also sound deadens so there'd be no need for a matt product. They have a thermo one too I believe. You can paint over it as well after you're done...
1970 2wd Blazer
