Closed Thread
Old 08-14-2011, 06:55 PM   #101
Lazzardkng
Re: 100's of misc parts from the last 6 trucks parted out
I have a 70 c20 Camper Special that my dad was the original owner of. I just retired from the Marine Corps and will be fixing it up (its actually still in very good condition). However I want to convert it to 4WD. I'm looking for a rolling frame or a donor vehicle. If you can point me in the right direction that would be great.
Dale
Lazzardkng is offline
Old 08-15-2011, 06:06 PM   #102
Joe Blaze
Do you still have the "Blazer front top mount brackets 12.50" available? Also looking for a black steering wheel to fit a '71 Blazer.
Thanks.
Joe Blaze is offline
Old 08-15-2011, 07:32 PM   #103
Chris Bultman
Do you have the rod between the brake pedal and power booster? I have everthing else I need to convert my 67 to power brakes, just missing the rod.
Thanks, Chris
Chris Bultman is offline
Old 08-15-2011, 10:26 PM   #104
nightmare
nightmare's Avatar
I'll take the 71-72 gas pedal w/cable 27.50. PM your paypal info. Thanks
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline
Old 08-16-2011, 01:54 AM   #105
tll74
"Junkyard Dog"
tll74's Avatar
Lazzardknd, PM sent
Joe Blaze, yes on the mounts. No wheel at this time.
Chris Bultman, sorry I only have the rod with a booster.
nightmare, PM sent
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline
Old 08-16-2011, 02:14 PM   #106
rstrick
The fuel filler cover arrived today. Just what I needed.
Thanks much.
Roy
rstrick is offline
Old 08-17-2011, 08:15 PM   #107
2fast55
2fast55's Avatar
We need to talk about some blazer parts sometime. I need the latch reinforcement plates for sure, and it looks like I just missed out on the fuel filler cover. You may have some other parts I'll be needing to finish my blazer. I'm at the racetrack every weekend.
1972 Chevy K5 Blazer
1972 Chevy K20
1955 Chevy 3100
"If we knew what it was we were doing, it would not be called research, would it?"
- Albert Einstein
2fast55 is offline
Old 08-17-2011, 08:27 PM   #108
webfoot
I need the part of the window regulator the glass sits in, RH side.
(btw, i used to live in springfield!)
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline
Old 08-18-2011, 03:05 AM   #109
Micks72
Micks72's Avatar
PIC #1 ASHTRAY - DARK GREEN IF YOU HAVE. How much to send to Califonia?
Micks72 is offline
Old 08-19-2011, 02:07 AM   #110
tll74
"Junkyard Dog"
tll74's Avatar
rstrick, your welcome and Thanks
2fast55, PM sent
webfoot, 15.00 plus shipping for the run channel. I was in Hermiston just last weekend! LMK Thanks
Micks72, 17.50 shipped, thanks
tll74 is offline
Old 08-19-2011, 11:36 AM   #111
webfoot
Sounds good to me, please PM me know your payment info!
-me
webfoot is offline
Old 08-19-2011, 04:44 PM   #112
tll74
"Junkyard Dog"
tll74's Avatar
PM sent
tll74 is offline
Old 08-19-2011, 05:04 PM   #113
Joe Blaze
PM me the payment info
thanks.
Old 08-19-2011, 06:30 PM   #114
68steppsidee
hey im needing the underdash wiring and possily cab to bumper wiring as well does it matter if i have gauges ... is the one you have idiotlights.. if you still have it i'll take it thanks..
68steppsidee is offline
Old 08-19-2011, 11:13 PM   #115
Chewievette
Chewievette's Avatar
I'm interested in the following if they are still available:
-Black sunvisors
-Inside mirror (not sure if any listed will fit my 68?)
-Dome lens w/ chrome housing
-Front and rear deluxe marker lenses (need set of four)
-Backup lens (need two)
-Tail lamp lens (need two)
-Washer res. cap w/ hose
-71-72 gas pedal w/ cable
I didnt see them listed but I am also looking for the following:
-Automatic shift position indicator (on top of steering column)
-Heater controls (interested in almost anything, mine is totally destroyed)
-67-68 park lamp lenses (the amber ones in the grill, need both)
-the "T" in chevrolet on the hood
-68 outside mirrors
-brake and clutch pedal unit (and several other conversion parts if you have a donor available)
1968 C-10 Long Bed 307ci Automatic
Chewievette is offline
Old 08-21-2011, 01:35 PM   #116
Joe Blaze
do you still have the "K5Blazer" emblems available?
I am also looking for this rubber piece that goes on the rear top of the driver's door:
Old 08-22-2011, 04:33 PM   #117
tll74
"Junkyard Dog"
tll74's Avatar
I have the 68 dash wiring for gauges and the cab to bumper tail lamp harness. 90.00 plus shipping
tll74 is offline
Old 08-22-2011, 04:41 PM   #118
mcbassin
Still Learning
mcbassin's Avatar
tll74,
Any chance you can update the first post to reflect what is sold and still available? thanks
mcbassin is offline
Old 08-22-2011, 05:15 PM   #119
webfoot
Hi there, just waiting on payment info & shipping charge for the glass run channel to zip 97838.
-me
webfoot is offline
Old 08-22-2011, 08:34 PM   #120
68steppsidee
yeah i'll take it man how do i go about buying it from you my zip is 37922
Old 08-22-2011, 08:41 PM   #121
68steppsidee
also my truck is a 69 with a 67 front end... how much diff is the 67,68 then 69-72
Old 08-22-2011, 10:21 PM   #122
tll74
"Junkyard Dog"
tll74's Avatar
Chewievette, PM sent
mcbassin, Yes I plan to later this evening. Thanks!
Joe Blaze, PM sent and the K5 emblems are sold.
webfoot, PM sent back.
68steppsidee, Yes they are different. I have the 69 wiring as well same cost. PM sent
Guys, sorry for the delay been on vac over the weekend.
tll74 is offline
Old 08-23-2011, 12:37 AM   #123
mcbassin
Still Learning
mcbassin's Avatar
How much for the complete set of deluxe side markers shipped to 74851?
any fading on any of the lenses?
thanks
mcbassin is offline
Old 08-23-2011, 12:56 AM   #124
tll74
"Junkyard Dog"
tll74's Avatar
thanks
I just seconds ago replied to Chewievette on a PM regaurding these marker lens. I offered him a package deal so I would like to give him chance to reply back. I have another truck that may have them as a back up. Also the fronts have some fading.
Thanks, Tom
tll74 is offline
Old 08-23-2011, 08:29 AM   #125
mcbassin
Still Learning
mcbassin's Avatar
Thanks, Tom
Let me know.
mcbassin is offline
Closed Thread
