Old 09-02-2011, 01:37 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: my first post/pics
WELCOME!!!!
The HEI is an easy swap.Search the "Truck FAQ's thread and look for 6 cyl HEI by member shifty.It will walk you thru the process step by step.I spent about 2-3 hours gathering Plug wires,terminal ends and etc.But only about 45 min from hood up to leaving the drive for a test (and I regapped the plugs and wasn't in a rush,it just fell together that easy).Well worth the read and one of the best mods to my 6.
1&2 I don't know.
3 Make sure you get all brackets,pulleys and the pump when you buy the PS.There seem to be dozens of combinations but some of it doesn't mix well.If you don't get it all you may have alignment problems with the pump pulley and others.The gearbox and pump can usually be bought at any parts store,IIRC there is a core charge.Pump pulleys can be spaced differently from the front flange to the center of the pulleys,so watch for that on a new one.The Rag Joint (AKA STEERING COUPLER) IS ALSO DIFFERENT FROM THE MANUAL BOX TO THE ps BOX SO YOU WILL NEED ONE THAT FITS BOTH SHAFTS.
4. I would get the inner and outter rockers since the inners are about $7-8.00 each,well worth the price to have on hand.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
