Old 10-19-2011, 08:14 PM   #76
FLcustom10
Re: Slowly I build a truck
I went with Painless wiring harness from Summit Racing. It was $287 after $100 rebate. I wasn't prepared for having to cut the firewall, but it was pretty easy with a dremel tool.
FLcustom10 is offline   Reply With Quote
Old 10-19-2011, 08:18 PM   #77
FLcustom10
Talking Re: Slowly I build a truck
Sorting the wires was kind of fun. It made me feel like I'm actually going to have a truck!
Old 10-20-2011, 07:08 PM   #78
FLcustom10
New speakers and radio:
Old 10-20-2011, 07:16 PM   #79
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Old 10-20-2011, 07:22 PM   #80
oldman3
oldman3's Avatar
Nice....Jim
oldman3 is offline   Reply With Quote
Old 10-20-2011, 10:37 PM   #81
heeroyue2002
fat old dude
heeroyue2002's Avatar
how come you covered the speaker? dust preventive?
looks good either way
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 10-21-2011, 07:29 AM   #82
FLcustom10
Thanks guys. I covered the speakers partly to prevent dust, but mostly because the old one was covered, and if someone looks through the grate I want it to look as original as possible. I realize I've already stepped away from original, but that's the thought process.
Old 10-21-2011, 10:59 PM   #83
FLcustom10
Hooking up wires for heater, washer, and wiper switch. It's starting to get crowded under here.
Old 10-21-2011, 11:02 PM   #84
FLcustom10
Glove box and light. That was hard. It's a good thing it will be mostly hidden.
Old 10-21-2011, 11:03 PM   #85
VA72C10
VA72C10
VA72C10's Avatar
Nice progress....yeah, those glove boxes are a pain to install!
Old 10-21-2011, 11:06 PM   #86
FLcustom10
cigarette lighter -- old and new:
Old 10-21-2011, 11:20 PM   #87
VA72C10
VA72C10
VA72C10's Avatar
Looks a little better And it's got the light!
Old 10-22-2011, 10:23 PM   #88
FLcustom10
New cab light and door switches:
Old 10-22-2011, 10:25 PM   #89
FLcustom10
New headlight switch:
Old 10-22-2011, 10:27 PM   #90
FLcustom10
Getting ready for ignition:
Old 10-22-2011, 10:35 PM   #91
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 10-22-2011, 10:43 PM   #92
FLcustom10
Thank you!
Old 10-23-2011, 06:58 PM   #93
FLcustom10
This looks a little bit better for the glove box:
Old 10-23-2011, 07:29 PM   #94
72cummins
72cummins's Avatar
Your build is coming along great. If this is a slow build I cannot think of what to call mine. I took three years from the purchase to getting it up and driving again. Keep up the good work.
Bryce
72cummins is offline   Reply With Quote
Old 10-29-2011, 05:31 PM   #95
FLcustom10
New Turn Signal Switch, Backup Light Switch, and column seal:
Old 10-29-2011, 05:34 PM   #96
FLcustom10
Putting it together:
Old 10-29-2011, 05:43 PM   #97
FLcustom10
New Shifter - I had to use a dremel tool to shave the ball on the end down a bit for it to fit. The painless wiring kit makes you re-use the original half moon connector. I never could make the old terminals release with a paper clip or small screwdriver, so I just pulled them through with needle nose pliers.
Old 10-29-2011, 05:53 PM   #98
FLcustom10
Wrapping wires:
Old 10-29-2011, 05:56 PM   #99
FLcustom10
Learning to solder and shrink-wrap :
Old 10-29-2011, 06:01 PM   #100
FLcustom10
Gauges are hooked up with new light bulbs.
