Old 10-25-2011, 04:51 PM   #1
Jobe72
Jobe72's Avatar
Help, truck just died on me...
My 1972 GMC just died on me on the way back to the office today from a job site. It's getting fuel, cranks over but won't start. I checked all the wires, hoses, etc that I could see and nothing out of place. I'm guessing ignition issues since it just died while driving. It's a 350/350 combo and converted to HEI. I just replaced the cap, coil, rotor, wires, etc back in March or so.
Thoughts?
Thanks, had to leave it on the side of the road and get a ride back to the office (had 2 coworkers with me) and waiting for the tow truck to bring it home.
Thanks!
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline   Reply With Quote
Old 10-25-2011, 04:55 PM   #2
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: Help, truck just died on me...
Get it back home and pull a spark plug wire and see if it's getting spark.
Then go from there.
Good luck.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 10-25-2011, 05:00 PM   #3
Gene
Gene's Avatar
Check batt. Wire that plugs into hei cap. Mine came loose did the same thing.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 10-25-2011, 05:52 PM   #4
Jobe72
Jobe72's Avatar
I'll check spark when I get home, and checked the hei wires when I was there but you never know...can't wait to get home and get busy diagnosing so I can get to work in the morning!
Old 10-26-2011, 12:58 PM   #5
Jobe72
Jobe72's Avatar
Ended up being a fried HEI coil...as in the actual wires were burned! Don't know how that happened...back on the road!
Old 10-26-2011, 01:08 PM   #6
splehigh
splehigh's Avatar
I was going to say the module. Glad you got it fixed
splehigh is offline   Reply With Quote
Old 10-26-2011, 02:44 PM   #7
cdowns
cdowns's Avatar
poor connections and poor gounding cause heat and wires melting
Old 10-26-2011, 03:01 PM   #8
Jobe72
Jobe72's Avatar
Tonight I'm going through all of my connections when I can get my truck out in my shop.
Old 10-26-2011, 06:20 PM   #9
cleszkie
cleszkie's Avatar
Make sure you are sending a full 12 volts to the HEI. If you use the factory power lead that your truck came with, you will be sending less than 12 volts since the factory wire was a resistance wire designed for use with the points system/ballast resistor. The HEI will run for a while with the lower voltage, but will eventually fry the module and/or the cap and rotor itself. Ask me how I know...
cleszkie is offline   Reply With Quote
Old 10-26-2011, 11:03 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Make sure you use the heat sink compound that transfers heat from the module to the breaker plate. If you don't, it will cook the module.
Member Nr. 2770
