Old 12-24-2011, 11:28 PM   #1
Dano51
Gas Tank
What gas tank will fit under the bed with a rear fill. for the 55-59 pickup.
Dano51 is offline   Reply With Quote
Old 12-25-2011, 12:43 AM   #2
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: Gas Tank
many people have used a chevelle tank.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 12-25-2011, 01:43 AM   #3
OrrieG
OrrieG's Avatar
Re: Gas Tank
I had a 68 Chevelle or Impala under mine as an auxillary tank before. Filler fit right between the Fleetside bumper and rear sill, I did it with a flip down license plate from the donor car. It was 16 gallons. It hung lower than the one in my build thread (aftermarket aluminum).
Old 12-25-2011, 05:28 AM   #4
Daze57
Daze57's Avatar
Re: Gas Tank
i believe 69-70 mustang tanks fit quite well also
Daze57 is offline   Reply With Quote
Old 12-25-2011, 02:58 PM   #5
meter swinger
meter swinger's Avatar
Re: Gas Tank
That sounds nice, then you could avoid the filler cap in the bed floor.
meter swinger is offline   Reply With Quote
Old 12-25-2011, 04:56 PM   #6
OrrieG
OrrieG's Avatar
Re: Gas Tank
Any 60's GM car plate assy will work, my 64 Chevelle has the same bracket, matches the Fleetside bolt pattern too. I used 1.5 x 1/8" strap bolted to the rear and shock cross sills. I would have kept it but had already patched two rust holes in the bottom.
Old 12-25-2011, 07:46 PM   #7
renegade6
Re: Gas Tank
You can also use from a tank from a Blazer.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 12-25-2011, 08:48 PM   #8
hotrodsbyray
Re: Gas Tank
Lots good ideas on the site for a tank. Do a search for "mustang tank" or "cougar tank."
hotrodsbyray is offline   Reply With Quote
Old 12-25-2011, 10:02 PM   #9
justplainray
justplainray's Avatar
Re: Gas Tank
this tank belongs in a 1959-60 Chevy passenger car.
the best part is that the fuel sending units works in the correct resistance range to match the stock truck gauge.
You will have to shorten the fill neck and use a non-vented cap.
I ran the vent hose up under the right rear fender and connected it to a fluid separator, the round cannister laying on the bumper in the photo below.
also note the Nova flip license plate bracket.
justplainray
justplainray is offline   Reply With Quote
Old 12-25-2011, 11:14 PM   #10
meter swinger
Re: Gas Tank
Thanks for the pics justplainray. With the filler behind the plate, that is a great alternative to having it in the bed.
Old 12-26-2011, 09:50 AM   #11
beanyard
Re: Gas Tank
justplainray
It looks as though you had to change the crossmember is that the case?
1959 Fleetside Big Window Long Box
Standard Trim soon to be Deluxe
1953 GMC Carryall Suburban
beanyard is offline   Reply With Quote
Old 12-26-2011, 09:58 AM   #12
Aedan
Re: Gas Tank
well
it is good i think it is best
59' SWB fleet
thanks
Aedan is offline   Reply With Quote
Old 12-27-2011, 10:25 AM   #13
justplainray
Re: Gas Tank
thanks guys.
No change to the cross member required. (short bed 56)
Made straps out of 1/16 x 1 inch steel, nylon webbing and rubber sheeting for cushions.
Front mounts to frame cross member, rear mounts to bed rearmost cross sill.
Be sure to use non-vented cap to avoid spillage on accelaration.
And vent hose will need to go to a fluid separator (radiator overflow bottle) so as not to spit fuel out.
Another view
justplainray
Old 12-27-2011, 03:23 PM   #14
Daze57
Daze57's Avatar
Re: Gas Tank
nice 56
Old 12-30-2011, 07:06 PM   #15
oldcouple
oldcouple's Avatar
Re: Gas Tank
I used a Blazer tank, but do not like the way it hangs so low.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 12-30-2011, 09:14 PM   #16
justplainray
Re: Gas Tank
and here is another view of the tank.
justjplainray
Old 04-20-2021, 01:51 AM   #17
Scampos
justjplainray
I know this thread is old but I’m trying to do this same tank relocation but am unable to see any of your pics would you be able to post on feed?
Scampos is offline   Reply With Quote
Old 04-20-2021, 12:47 PM   #18
mr48chev
mr48chev's Avatar
Re: Gas Tank
The last post I can find from Ray is from 2012.
http://www.67-72chevytrucks.com/vboa...archid=6900937
Meter swinger is down in your area and he still is on here somewhat regularly.
My ongoing truck projects:
Old 04-20-2021, 09:47 PM   #19
vintovka
vintovka's Avatar
Re: Gas Tank
Any tank that's not in the cab!! Mine is on an 84K10 frame so choice was easy and filler in on left rear fender where it should be.
vintovka is offline   Reply With Quote
Old 04-20-2021, 09:53 PM   #20
mr48chev
mr48chev's Avatar
Re: Gas Tank
37-1/4 wide seems a bit wide for fitting inside a TF frame. Starting with about the most expensive oem style 64/67 Chevelle tank https://www.tanksinc.com/index.cfm/p...rod/prd305.htm
Old 05-16-2021, 08:42 PM   #21
SARBlade
Junior Member
SARBlade's Avatar
Re: Gas Tank
I'm surprised there's not a sticky on fuel tanks as the question seems to come up quite often. I know I will be looking for one soon enough. What I have that came with the purchase of the truck is an all aluminum one that is mounted in the bed?? Anyway, since I'm going 5.3 LS swap, I have been researching and there is not many people mentioning a tank with the EFI baffle in it. Tanks Inc will sell you one, but then you need which one to buy. I'm looking for a side fill, not out the back nor in the bed floor, so that limits me. I see many choosing the Mustang tank, not or a Blazer tank, not sure what years, nor do I know if these have the baffle or sump for EFI. Anyway, I'm not in a hurry yet, just researching, gotta finish the triangulated link set up with coil overs first lol.
Kick the tires, light the fires!
My Build: 1956 Chevy 1/2 SB
SARBlade is offline   Reply With Quote
Old 05-17-2021, 02:28 PM   #22
mr48chev
mr48chev's Avatar
Re: Gas Tank
Blazer tank has a left side of the truck fill. They do work great if you can figure out how to route the filler pipe/
The only other rub is that they hang down further than some guys like.
I've got a 78 F 150 tank that came with the last nine inch I bought that fits great but has the side fill hose. Sending unit ohm rating on the Ford tanks could be an issue unless you are running aftermarket gauges.
Old 05-18-2021, 12:27 PM   #23
bosco
bosco's Avatar
Re: Gas Tank
Same here. I have a late 60's mustang tank.
bosco is offline   Reply With Quote
Old 05-18-2021, 12:49 PM   #24
BBPanel
Re: Gas Tank
I used the 25-gal Blazer tank in my '56 Panel. Removed the vapor dome and welded in a flat piece both to mount fuel pump and sender but also allowed tank to sit higher in frame ~2". It comes with a tray in the tank for EFI pump to sit in.
BBPanel is offline   Reply With Quote
Old 05-18-2021, 12:53 PM   #25
mr48chev
mr48chev's Avatar
Re: Gas Tank
Thinking back to the impala and another car that I owned that had rear fill gas tanks if you filled the tank and then parked with it nose up on a slope soon after gas would sometimes run out.
