Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-27-2011, 08:39 PM   #176
65chev
Re: Power Steering Adapter Plates
Thanks John
Got the parts today. Impressive welding. Very clean. Mike
65chev is offline   Reply With Quote
Old 10-28-2011, 01:03 AM   #177
Captainfab
60-66 Nut
Thanks for the compliment Mike
Old 11-08-2011, 10:43 PM   #178
bryankichler
bryankichler's Avatar
I got around to installing power steering on my truck your bracket was great and that pattern included really was awesome managed to change my front end to power disc brakes and power steering in less than 8 hours big thanks man ill get some pics soon and post them up
bryankichler is offline   Reply With Quote
Old 11-09-2011, 12:21 AM   #179
Captainfab
60-66 Nut
I'm glad to hear the conversion went well for you. Thanks for the compliment
Old 12-26-2011, 12:36 AM   #180
Captainfab
60-66 Nut
I found this thread that gives a source for an inexpensive quicker ratio steering box.
http://www.67-72chevytrucks.com/vboa...d.php?t=499058
Old 12-30-2011, 10:12 PM   #181
niterider65
niterider65's Avatar
Cool Re: Power Steering Adapter Plates
Hi Captain fab ..I im needing one of your world famous power steering mount for 65 short step build that im doing please sir.
Thanks Billw
niterider65 is offline   Reply With Quote
Old 12-31-2011, 12:19 AM   #182
Captainfab
60-66 Nut
I'll send you a PM Bill.....
Thanks Billw
Old 01-07-2012, 11:31 AM   #183
csa daddy
csa daddy's Avatar
Could you send me a pm with payment info
csa daddy is offline   Reply With Quote
Old 01-07-2012, 11:59 PM   #184
Captainfab
60-66 Nut
PM sent
Old 01-22-2012, 12:47 AM   #185
jmlcolorado
Captin,
Do you make a plate for a 68 or 69 c10!?
jmlcolorado is offline   Reply With Quote
Old 01-22-2012, 02:55 AM   #186
Captainfab
60-66 Nut
You do not need an adapter plate for those years. Your frame should already have the 4 holes in the correct location, and the frame should be contoured so you can just bolt up a power steering box. That is unless yours happens to be different than the ones I have worked on here.
Originally Posted by jmlcolorado View Post
Captin,
Old 01-22-2012, 03:09 AM   #187
jmlcolorado
Well then
The current box only has 3 bolts mounting it, but there is a fourth at the top of the frame at the rear.
Guess that saves me 1 more step.
Sorry I couldn't drum up more business for ya but thanks for the input.
Old 02-01-2012, 07:03 PM   #188
csa daddy
csa daddy's Avatar
Pm sent
Old 02-02-2012, 12:38 AM   #189
Captainfab
60-66 Nut
Payment received.....thank you csa daddy
Pm sent
Old 02-10-2012, 03:01 AM   #190
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Is the 73-87 power steering box for a c20 the same as for a c10?
thanks
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-11-2012, 12:48 AM   #191
Captainfab
60-66 Nut
Yes the steering box is the same for C10, C20 and C30.
Old 02-28-2012, 08:06 PM   #192
LostMy65
LostMy65's Avatar
If I'm looking for a 2wd power steering box for my 65, what years newer than 73-87 can I use? or is 87 the last year that works with the 60-66 trucks?
Old 02-29-2012, 12:46 AM   #193
Captainfab
60-66 Nut
The compatable power steering boxes are from '68-'87 for the C10, C20 and C30 pickups, Suburbans and 2wd K5 Blazers. The only newer boxes that will work would be from the '88-'91 R1500, R2500 Crewcabs, Suburbans, and possibly Blazers. I just don't know for sure if there were any 2wd Blazers in those years.
Old 02-29-2012, 12:38 PM   #194
Summabish
Cap if you could send me the info for purchasing one of these PS adapter plates that would be great, I plan on purchasing one here in the next few weeks. Thanks in advance.
Summabish is offline   Reply With Quote
Old 03-01-2012, 12:11 AM   #195
Captainfab
60-66 Nut
PM sent.......
Old 03-10-2012, 12:05 PM   #196
jlsanborn
jlsanborn's Avatar
Help me out here. I've been searching for the best solution for brakes and steering and keep winding up looking at John's cool stuff! I've got a '67 C10 with a front disc conversion. I for sure want to do PS/PB and use the Hydra-Boost set up. Problem is, I've got the 292 L6, which I'll have to run until I can fund the small block swap, probably next winter. Seems that pump brackets for this in-line engine are rare and expensive. Anyone fab a pump mount for this?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 03-10-2012, 12:25 PM   #197
HOTFUN
HOTFUN's Avatar
Cap
Please pm ordering info for a ps mount bracket. Thanks, Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 03-11-2012, 01:33 AM   #198
Captainfab
60-66 Nut
On a '67 you shouldn't need this power steering adapter plate. The '67's I've seen/worked on, just need four 1/4" spacers. As for the 292 PS pump brackets, there was an ebay seller that was making some nice ones.
Old 03-11-2012, 01:34 AM   #199
Captainfab
60-66 Nut
A PM coming your way...
Originally Posted by HOTFUN View Post
Cap
Old 04-24-2012, 03:04 AM   #200
LostMy65
LostMy65's Avatar
I need to purchase another power steering bracket. This one is going on my 65.
