Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-28-2011, 01:39 AM   #1
53GMC
53GMC's Avatar
Fuel pump runs after shut off- help needed!
Just recently I noticed that after I turn off the engine the fuel pump used to stay on for 3-5 seconds but it started staying on longer.
Here's what I know - check if I'm right... The fuel pump receives its power from the fuel pump relay or the oil pressure switch (they are connected in parallel so that power can be provided from either source). The oil pressure switch provides power to the pump when the oil pressure reaches 4 PSI. The Fuel Pump relay supplies power to the pump when it receives a signal from the ignition switch. They are no other switches or interupts in the circuit
Couldn't I just unplug the oil sending unit and if the fuel pump doesn't run after I shut the truck off, then I will know it's the sending unit that needs to be replaced correct? I replaced the pump only a year ago and do not think it's that. I changed the oil yesterday. Could that have changed oil pressure reading any now?
Thanks for your help!!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 12-30-2011, 08:53 PM   #2
gmclowsierra
Re: Fuel pump runs after shut off- help needed!
the fuel pump runs after the key is off is normal. the ecm is what commands the fuel pump on and off.
gmclowsierra is offline   Reply With Quote
Old 12-30-2011, 09:14 PM   #3
jayman68
Fun Stuff
jayman68's Avatar
If the oil is thicker that could affect the pressure and cause the pump to stay on longer. If you disconnect the wire to the oil switch the engine will start but shut off when you release the key, because the pump is not sensing oil pressure. Depending on the year and setup of the system there is different amounts of computer control.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 01-04-2012, 06:20 PM   #4
53GMC
53GMC's Avatar
changed the oil from 10W-40 to 10W-30 and the pump did shut off when i cut the key off like it used to ....this was the first time i had used 10w-40 and when i made the change it was back to normal...thanks guys!
1953 GMC/S 10 Swap
Old 01-04-2012, 09:48 PM   #5
jayman68
Fun Stuff
jayman68's Avatar
Glad it worked out.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 01-19-2012, 10:50 PM   #6
donkeypunch
What year was the truck you had this issue with? I have an 87 454 tbi that has a fuel pump relay (i think...below drivers exst manifold) that has always been disconnected and once i found the loose wire i hooked it up (ignition off) and pump turns on?....Does not seem to shut off? I should mention the wiring looks hacked and the truck idles like ****.
Any thoughts?
donkeypunch is offline   Reply With Quote
