01-17-2012, 12:39 PM | #1 |
Scrapper 1
1967-72 Front ends drum to disc
there is a lot of talk Now days in the front end swaps I'm hearing you can just take off the old drum brakes and swap a set of upper and lower ball joints tie rods and brake hoses and spindles.No need to touch the A frame.Now others say different Lets put it to rest
I need all the detail of Why you can't On 1962--67 nova's all you have to do is swap out the spindles Camaro's as well There are a lof of us that have good straight no problem alinement front ends Tell us all why We must Change the A frame A arms is there a clearance problem . Are the A Arms made different from a 1964--69 This has been a big question In why If you have spec's on why the Drum front ends can't be converted to disc Just by using the Spindles and not touch the front A frame We all like to be tot a lesson. Last edited by stsalvage; 01-17-2012 at 12:46 PM. |
01-17-2012, 12:43 PM | #2 |
Re: 1967-72 Front ends drum to disc
all ears on this one.
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
01-17-2012, 12:51 PM | #3 |
Scrapper 1
its one that has bother the hell out of me.
Spindles cost enough but if you can swap out a set from a 1973--87 1/2 ton on 3/4 ton and use different tie rods and pitmen arm and bracket and different hoses size To me change out the Stock A frame is NUTT's. I know there are ton's of old Chevy trucks out there that don't eat up tires at all.and after you change you Have to keep going back to the alinement shop. I just like to have a fair and to the point answer Last edited by lolife99; 01-17-2012 at 02:50 PM. |
01-17-2012, 01:21 PM | #4 |
C/10 junkie
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-17-2012, 01:55 PM | #5 |
You can use "69-74 Chevelle Rotors" and "69-72 Camaro calipers" on our spindles, just change the master cylinder use a disc brake prop valve and these brackets $119.
http://www.classicperform.com/Store/.../6370DBK-5.htm or you can buy the whole kit without the booster and MC for $375 http://www.classicperform.com/Store/...s/4754CBK5.htm or with the booster $599 http://www.classicperform.com/Store/...k/6062CBK5.htm Downside is you are now on a 4.75" bolt circle. Just pop off your wheels and hubs...INSTALL! Dano
'69 Fleet It ain't yours, if you didn't build it! |
01-17-2012, 02:01 PM | #6 |
It would be nice if you could get the discs with the 6-lug or 5 on 5 lug pattern. Maybe a machine shop could redrill them badboys.
01-17-2012, 02:23 PM | #7 |
VA72C10
moved this to suspension where lolife99 will see this.
I believe that the time people modify a-arms are to allow clearance with smaller diameter wheels (certain 15's) when using disc brakes with drop spindles...and that is just removing a small section for clearance at lock to lock turn I believe? I've never heard of completely changing the a-arms to fit disc brake spindles so that's news to me.... He'll have better info than me though...
Looking for a 67-72 swb or blazer project in or around VA. |
01-17-2012, 02:44 PM | #8 |
67-72 parts collector,…
Go here:
http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Pick the thread that applies to you. Read. This topic is discussed here every day. If you still have questions feel free to ask. The bottom line,... the aftermarket industry NOW MAKES "direct bolt-on" spindles for any year truck from 1960-1987 (and more). No a-arm change. No ball joint change No tie rod change. Bolt the spindles on. Add 1/2-ton rotors, calipers, and hoses. Bolt a disc/drum master cylinder and prop valve to your truck. Plumb the steel lines. Bleed brakes. Done.
01-17-2012, 02:50 PM | #9 |
VA72C10
Thanks, knew you had something like this....bookmarked the link for the future...
YOU DA MAN!!!
01-17-2012, 02:50 PM | #10 | |
You mention 3/4 ton? Are you converting a 3/4 ton to 1/2 ton? ECE (www.earlyclassic.com) makes a 3/4 ton to 1/2 ton "conversion spindle",... that is bolt-on also
01-17-2012, 02:52 PM | #11 | |
(for everyone to see. Ha)
01-17-2012, 02:52 PM | #12 | |
VA72C10
At least I've read the site rules
01-17-2012, 02:54 PM | #13 |
3/4 ton to 1/2 ton conversion tech article.
This is on ECE's website. This is a suburban,... but it's the same thing. Buy the spindles from ECE. The rest you can get locally at your parts store. http://www.earlyclassic.com/tech.aspx?category=Dropping The Big Ship
01-17-2012, 03:02 PM | #14 | |
01-17-2012, 03:04 PM | #15 |
Scrapper 1
No what i'm asking why is all the Buzz about Changing the whole Dam front end why is every one going around the answer Can you switch the drum brakes from a 1/2 that has drum brakes with out changing anything but the Spindles tie rods and other little parts
Sam gose for the 3/4 ton Can you Just change the spindles from drum to disc with out changing the whole front end Never could understand why you had to take a perfectly good front end that GM installed on a 1964--70 truck just to put disc brakes on are the A arms different Is there a clearance issue on the disc brakes from the drum brake A arms Did i make it clear enough |
01-17-2012, 03:15 PM | #16 | |
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-17-2012 at 03:30 PM. |
01-17-2012, 03:56 PM | #17 |
I am a Referee of life.
One difference is in the Ball Joints.That seems to be because spindle taper are different.The later ball joints are cheaper and seem to be more readily available.There are several different ways to use a stock disc brake set-up on the earlier trucks.Most of them have been written up here on the BB.I'm running a 2 1/2 drop spindle and 6 lug disc on mine.The 5 lug was the same price but I wanted to stay with the 6 lug.I used factory Ball joints,tie rod ends,and only used spindles,rotors,calipers and hoses from the kit.IIRC the Ball joints are also different sizes where they press into the lower Ball Joint causing the problem of not being able to use early A-arms withdisc spindles from a stock set-up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
