Old 02-11-2012, 07:51 PM   #51
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Re: My first 67-72! (68 Burb)
Originally Posted by YBNORML View Post
Anything new to report?
Still prepping the motor to reinstall. I think I might throw an Edelbrock intake on it while the distributor is out. I gotta get a puller to remove the balancer so I can do the timing chain too and paint the cover.
I bought some high heat primer today which will be followed by Chevy orange.
I'd like to use my solid smoothie valve covers from an old 283 I have. Anybody know the best way to vent the crankcase with no PCV valve/breather in the valve covers? Also need to be able to add oil.. might have to see if Edelbrock sells a 283 specific intake with the fill tube..?
My son was helping me with the dirty work with a wire wheel..
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 02-11-2012, 07:53 PM   #52
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Originally Posted by olblue60@aol.com View Post
Nice ! Custom Cab. It looks really solid !
Hey thanks. Do you know if the Custom Cab was much better than a base model? More chrome maybe?
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-11-2012, 09:05 PM   #53
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Man, I should really stay off the Edelbrock site.. this is so cool! http://www.edelbrock.com/automotive_...o-barrel.shtml
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-12-2012, 07:51 AM   #54
olblue60@aol.com
member
Custom Cab on suburbans was like the CST package on pickups. I'm not sure of all it included, but here are a few of the parts included. Stainless windshield and vent window trim,padded interior door panels, dash knobs with the aluminum centers,chrome bumpers, aluminum headlight and grille moldings, fender and hood surround. Mine has tinted glass, I dont know if it was part of the package. Mine has carpet, and doesn't appear to ever have had the body moldings. The no body moldings has always seemed odd to me. Perhaps there is someone that knows more
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 02-12-2012, 10:22 AM   #55
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Good info, thanks.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-18-2012, 09:38 PM   #56
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Can board staff move this thread to the "Suburban Projects and Builds" section pls? Probably a better spot for it now..
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 09:49 PM   #57
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Well thanks to a couple of my favorite Burbs on this site (pictured below) and Dieselwrencher's 2wd to 4wd conversion thread, I was inspired to jump off the deep end and build this thing the way I actually want it to be.. 4x4!
I feel that this will not only look really sweet, but also be very useful as a versatile year round daily driver that will better suit my family/acreage lifestyle..
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 09:59 PM   #58
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Like Dieselwrencher's build, I'll be using a 73+ body style donor truck for springs, hangers, crossmember, steering box etc.. NOT A FRAME SWAP.
Here's my parts truck. It's a Frankenstein of the previous owners half done project. It's got a 1980 clip, doors and box, but the cab vin says it was built in 73.. Also, it's a 1 ton body with 10 bolt, 6 lug diffs. I'm hoping to find some 3/4 ton axles though.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 10:10 PM   #59
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Don't worry, I won't be using the hillbilly lift kit that the PO installed..
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 10:16 PM   #60
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Not going to grab the rear axle stuff till I get the front end done, so I chained it to my "tow truck" to get er out of my driveway..
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 10:38 PM   #61
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Yoink! got the crossmember out this morning and "towed" it down to the field with my "tow truck"
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 11:00 PM   #62
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
My son wandered into the garage, so I got him to bolt the leafs to the axle.. The 10 bolt diff from my donor truck was pretty crusty so I'm using a different 10 bolt I had kickin around from an 89 Suburban. (at least to mock everything up) I haven't checked to see what the gear ratio is yet, if I get lucky and it matches the rear, I might use this one till I find some 3/4 ton diffs.
I set the rad support in place to get an idea of the ride height. I realize it's going to sit higher right now with no drivetrain or front clip, but is it just me, or does it look like these leafs I used might have a few inches of lift??
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-20-2012, 11:11 PM   #63
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
I test fit the steering box from the donor truck and it's a direct bolt in. Next on the list is to weld in some flat metal where the E-brake cut outs would conflict with the shackle hangers sitting flat on the frame. I'll also have to fab some gussets for the front spring hangers.
I haven't decided if I'm going to modify the donor trucks motor mounts/crossmember to fit, or modify the 2wd motor mounts to work with a custom crossmember.. Unless somebody local has a 4x4 crossmember they want to part with?
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-21-2012, 09:06 AM   #64
olblue60@aol.com
member
Did you buy new front leaf springs or go with the longer Squarebody leafs? What kind of lift?
Old 02-21-2012, 10:25 PM   #65
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
I used the leafs that came on the 73 donor truck. Not sure if they're stock or not. They have a slight positive arch and I've seen lots of stock 4x4's with slight negative arch (more saggy) so the donor truck might have had a slight lift but I'm not sure.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-21-2012, 10:30 PM   #66
YBNORML
YBNORML's Avatar
It's been awhile since I poked my head in here, big changes!!! I like it.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-21-2012, 10:42 PM   #67
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Thanks, I'm pretty motivated now that I found one of my favorite vehicles. I'm just hoping I don't get in over my head with this conversion. So far so good though, nothing's stumped me so far..
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-22-2012, 01:48 AM   #68
Average Joe
Average Joe's Avatar
Cool! I like the 4x conversion builds. Have you looked at Dunenuts build? He recently did a 4x conversion on a C10 longbed and retained the rear coils. I think he also reused the crossmember from his donor 80's blazer with minimal fabrication. Woodright also has a conversion going utilizing a 2wd frame.
Average Joe is offline   Reply With Quote
Old 02-22-2012, 08:38 AM   #69
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Good info, thanks. If you could post a few links for those builds, that would be awesome. I'm planning on doing leaf springs in the back too. I have an 84 2wd half ton that I might steel the leafs out of. Depending on what my ride height is compared to the front, I may take the two downward facing hangers off both of my parts trucks and do a shackle flip for the rear leafs in order to get the height I need to match the front.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 02-22-2012, 09:04 AM   #70
lolife99
67-72 parts collector,…
lolife99's Avatar
Chevy 67-68 fenders are different from the 69-72 chevy fenders.
The core support and hood are also different.
67-68 Chevy fenders are the same as 67-72 GMC fenders.
The only minor difference is that all 67 fenders have no side marker light.
Keith
Convert to disc brakes.
Old 02-22-2012, 11:13 AM   #71
PHAT TONY
PHAT TONY's Avatar
As a 4x4 'Burb liker, this is very interesting!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 02-22-2012, 11:42 PM   #72
Average Joe
Woodrights build:
http://67-72chevytrucks.com/vboard/s...d.php?t=446024
Dunenutts build:
http://67-72chevytrucks.com/vboard/s...d.php?t=444887
Old 02-23-2012, 09:04 AM   #73
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Cool thanks for the links, they will be useful.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 03-25-2012, 12:02 AM   #74
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Well I got sidetracked working on my Blazer and other stuff, but today I decided to start on some spring hanger gussets to replace the 73-87 style while not conflicting or moving the 68 style body mount. Spent about an hour in the garage before my little brother distracted me and we went out back to fire a 1918 Lee Enfield 303 that he hadn't fired since he bought it, and took it completely apart to clean.
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
Old 04-07-2012, 10:20 AM   #75
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
So my buddy bought brand new 68 fenders for his 72 Chevy not realizing they were different, so he sold them to me for $100 each!
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
1967-1972, 1968, 67-72, burb, suburban
