02-12-2012, 01:19 AM | #1 |
Need info on Longhorn 4x4 conversion
Can someone provide detailed info on the details of converting a Longhorn to 4x4? I have a 3/4 ton 4x4 donor truck and would like a heads up as to some of the pit falls of this conversion. By moving all of the spring brackets and springs does this make the stock stance of the truck correct? Does the carrier bearing crossmember have to be removed?
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
02-12-2012, 11:16 AM | #2 |
Grease Monkey
Re: Need info on Longhorn 4x4 conversion
Here is a link for someone on the forum doing this right now. Also you can find any thread on converting 2wd to 4wd to help you as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=310493
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
