Old 02-14-2012, 09:52 PM   #101
rollinrooster
rollinrooster's Avatar
Re: '49 chevy with s-10
Got some more time to work on the brake lines. Finally finished the frame part. fixn to start on the accuair for the chassis.
rollinrooster is offline   Reply With Quote
Old 02-14-2012, 10:04 PM   #102
youngrodder
youngrodder's Avatar
Looks very nice. Straight as an arrow......
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-15-2012, 11:03 PM   #103
BlueJeep
BlueJeep's Avatar
Looking great!
What paint did you use on the chassis and components?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-16-2012, 09:53 AM   #104
rollinrooster
Originally Posted by BlueJeep View Post
Looking great!
Thanks man, its POR15 with the chassis coat as a top coat (for uv protection)
Old 02-16-2012, 11:44 AM   #105
Scottshotrods
looking good
Justin
Scottshotrods is offline   Reply With Quote
Old 02-16-2012, 11:47 AM   #106
daverod
SSN 706
daverod's Avatar
I guess you'll have to rasie the front and drop the rear to drain your tank? Build is coming along nice.
daverod is offline   Reply With Quote
Old 02-16-2012, 06:54 PM   #107
rollinrooster
You know, i didnt even think about the drain on the tanks when i mounted them, just thought they looked cool there and gave me lots of room for exhaust. Thanks for pointing that out i will fix that little problem.
Old 02-16-2012, 08:02 PM   #108
daverod
SSN 706
daverod's Avatar
I'll bet you could get it level just by messing with the air in your bags. Or you could do some welding and grinding and stuff and stuff. Your right it does look cool.
Old 02-19-2012, 03:21 AM   #109
sleepertruck72
sleepertruck72's Avatar
Rollinrooster , you have some serious skills my man This is an awesome build !!! Im curious as to the throttle and brake pedals and how they end up. I will patiently wait to see I guess Again, Awesome job
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 02-19-2012, 08:23 AM   #110
Love2Fab1
Rollinrooster,
Very nice and accurate install on those brake lines. They couldn't be mistaken for a novice install, that's for sure. Keep up the excellent work! Fab1
Love2Fab1 is offline   Reply With Quote
Old 02-19-2012, 09:39 AM   #111
rollinrooster
Thanks alot, this is my first time doing a frame swap. As for the throttle / brakes im going to use lokar lakester gas and brake pedals and a scottshotrods 90 degree under dash brake set up.
Old 02-19-2012, 09:49 AM   #112
rollinrooster
Originally Posted by Love2Fab1 View Post
Rollinrooster,
You know, that was my first time ever doing brake lines. A very good friend of mine ownes a hotrod shop (PrecisionRod and Custom). He let me borrow some brake line tools and gave me some advice to get started with. Youre not to far away in Kingsport, and are welcome to stop by anytime just pm me.
Old 02-19-2012, 06:12 PM   #113
RootBeer 6117
RootBeer 6117's Avatar
Rollinrooster;
I just went through brakes in my class, part of it the students had to make brake lines. I had them do mine I only wish they had turned out as good as yours, you get and At in my book, excellent job.
Joe
RootBeer 6117 is offline   Reply With Quote
Old 02-19-2012, 07:56 PM   #114
not2oldchevy
Super sharp truck!!! If you would like to do some more brake lines I am about 30 miles away and I will bring it to you in a heartbeat. My method seems to be a big hammer and low IQ!
not2oldchevy is offline   Reply With Quote
Old 02-22-2012, 01:09 PM   #115
rollinrooster
Originally Posted by RootBeer 6117 View Post
Rollinrooster;
Joe
Thanks for the kind words, i wish i had someone to do mine.
Old 02-23-2012, 10:14 PM   #116
rollinrooster
Talking Re: '49 chevy with s-10
Got some front shocks on the cheap!! thanks to daverod. Just need to finish mounting them.
Old 02-23-2012, 10:43 PM   #117
xpickup
xpickup's Avatar
rollinrooster, Chassis looks great. I am glad to see how someone is mounting there shocks when they are bagged. I figured it would look something like that. Keep up the great work.
Shannon
xpickup is offline   Reply With Quote
Old 02-24-2012, 11:58 AM   #118
daverod
SSN 706
daverod's Avatar
Very nice. Did you see how the bottom of mine mounted? Kinda of a u shaped thing that the shock stud mounts into. Made it alittle easier to get in the right spot. Had to move mine a few times. I got them to fit without wheels spacers but I think I will buy some spacers anyways. Kinda depends on what wheels I get.
Old 02-26-2012, 09:56 AM   #119
rollinrooster
Yep, i looked at the way you set yours up and then decided to start on mine. I have spacers on the front of mine, so i have good clearance on everything. I'm still trying to figure out how i want the top mount to be.
Old 02-26-2012, 12:52 PM   #120
daverod
SSN 706
daverod's Avatar
Are the spacers 1". Where did you buy them? I think I'll get some.
Old 02-26-2012, 01:09 PM   #121
Chevette
Chevette's Avatar
Absolutely beautiful. Kudos on the super clean details. I've seen a lot of AD's on S10's and yours is one of the best I've ever seen. When viewed from the side the wheel base is perfect for the fender openings (rare on an AD/S10). Also, the wheels suit it perfect. Love it.
Chevette is offline   Reply With Quote
Old 02-26-2012, 11:09 PM   #122
rollinrooster
the spacers are 1.5". I found them on ebay.
Old 02-26-2012, 11:13 PM   #123
FiddyRidinFowler
Are you running your air lines down the inside of your frame from your front?
FiddyRidinFowler is offline   Reply With Quote
Old 02-27-2012, 09:07 AM   #124
rollinrooster
Yeap. I'm just begining to start laying out the air ride. I'm going with accuair.
Old 02-27-2012, 10:44 AM   #125
daverod
SSN 706
daverod's Avatar
You'll love it. Best thing is it so easy. Remember to plug in one intake if you don't use it. Make sure your grounds are good. Did you get the switch too.
