Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-03-2012, 10:26 PM   #51
madkmart
Re: Project OBS (Orange Blossom Special)
awesome start
madkmart is offline   Reply With Quote
Old 03-06-2012, 08:47 AM   #52
502ms
502ms's Avatar
Subscribed...keep it up
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 03-14-2012, 06:28 PM   #53
dujobu
Axle housings are at the powder coater. Had my wagon wheels powder coated a while back, then planned to sell them and use my rally wheels, then changed my mind back. So just got my 33" BFG ATs mounted up…
And just received the white gauge bezel in the mail…
dujobu is offline   Reply With Quote
Old 03-29-2012, 08:54 PM   #54
dujobu
Frame is powder coated and reassembled using new hardware. It's is a bit dusty, which is why it doesn't look so great in the pics. Now as soon as I get the axles finished I can build up the rolling chassis. Some pics…
Old 03-29-2012, 08:58 PM   #55
dujobu
A big thanks to Jeff (Rochlow) from Vermont for the replacement rear body mount bracket (1st pic below). And though I took tons of pics, I can't for the life of me figure out where the two remaining parts in the 2nd photo below came from. Anyone know where they go? …no seriously, I can't figure it out. Please help!
Old 03-29-2012, 09:14 PM   #56
warbucket
warbucket's Avatar
The one on the right is the spring safety stop. It goes under the driver side frame rail behind the leaf spring.
warbucket is offline   Reply With Quote
Old 03-30-2012, 02:10 PM   #57
jaros44sr
jaros44sr's Avatar
Sure John, you picked the easy one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-30-2012, 10:15 PM   #58
boonedogs72
boonedogs72's Avatar
looking good bud! its going to be better than new when you get done with it.
boonedogs72 is offline   Reply With Quote
Old 03-30-2012, 11:09 PM   #59
2003 silverado
2003 silverado's Avatar
The other bracket is for the transfer case /the transfercase has a bracket that comes off it then theres some gromet/bushings in there . It goes on pass side mid way down frame You could say there the top mounts for the bushings for tranfercase. Hope that helps
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 03-31-2012, 09:02 PM   #60
dujobu
THanks for the input on those two brackets guys. I really appreciate it.
Old 03-31-2012, 09:04 PM   #61
dujobu
All my time lately is going into restoring the axles, differentials, etc. Just got the brake backing plates and diff covers back from the powder coater (pics below). I'll post pics on the axle restoration process in a few days once they're finished.
Old 04-04-2012, 09:18 PM   #62
Rochlow
Glad you could use the body mounts. Frame looks really good
Rochlow is offline   Reply With Quote
Old 04-04-2012, 09:23 PM   #63
dujobu
Thanks Jeff. Do you still need that part on my firewall? I never did figure out exactly what part you were talking about, so I never did anything about it. I was planning on selling the whole firewall, windshield frame, etc as a whole. But depending on what part you need, I might be able to get it off of there. Let me know.
Old 04-04-2012, 09:39 PM   #64
dujobu
Had my original axles disassembled and spent the past few weeks restoring and/or replacing all the parts. Here are some pics of the housings before and after. I was going to take them to the powder coater, but long story short that didn't work out so I got some Extreme Chassis Black and ECB Primer and painted them myself. They turned out pretty great. Just hope the finish holds up. To clean the housings I used a putty knife to scrape much of the old oil and sand (she was a beach buggy!) off, then used a grinder with a wire wheel to clean them up. I then used a toothbrush with degreaser to clean the oil out of the corners I couldn't get them wire wheel into. Then cleaned the entire housings with Eastwood's Pre (paint prep solvent). Then onto the primer and paint. It went pretty smoothly, but was a lot of work.
After I cleaned up the front axle…
After one coat of primer on the front axle…
After two coats of primer and two coats of Extreme Chassis Black…
I did have the diff covers powder coated. They turned out great…
Old 04-06-2012, 10:47 AM   #65
boonedogs72
looks good dusty. For being a newbie your doing an excellant job!
Old 04-09-2012, 08:38 PM   #66
dujobu
Thanks Danny!
Old 04-09-2012, 08:41 PM   #67
dujobu
Spent the past few days building the body cart to hold the tub and transport it to the paint shop. Never thought there'd be some much carpentry involved in restoring a truck! It worked out pretty well, but I got a little sloppy in the end. Patience was wearing thin. Planning to get the tub off the 'new' truck and onto the cart this weekend. Here are some pics…
Old 04-09-2012, 08:53 PM   #68
warbucket
warbucket's Avatar
Looks good Dusty, I was thinking if your tub had door latches so you can shut the door to help support the tub. I won't be around on Sat, I have to go to Assateague MD with the boyscouts till Sat afternoon but I'll be around on Sun.
Old 04-15-2012, 08:27 PM   #69
dujobu
Making some progress… pulled the motor and lifted the tub from Kurt's frame today with the help of some good friends. It took 4 of us with the help of an engine hoist to get the tub off, roll the frame out, and roll the body cart underneath and sit the tub on the cart. It was pretty painless for the most part. Next up…rebuilding the axles and assembling the rolling chassie, while the tub heads to the body shop for repairs and paint. Some pics from today…
Old 04-25-2012, 09:10 PM   #70
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Any Progress? Looking good so far
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 04-25-2012, 09:26 PM   #71
dujobu
Tub going off to the paint shop tomorrow 8am. Axles being rebuilt this week and next. As soon as I get them back I'll be able to build the rolling chassis. Then onto the engine, exhaust, etc. Will post some pics soon.
Old 04-25-2012, 11:07 PM   #72
dujobu
Any of you guys know where to find the paint code for our Blazers? I was told to look on the inside of the glove box door, but there are a few codes that could be it. Not sure which it is. I thought my original color was Hugger Orange, but in one of items it says 'Light Red'. Wondering if that's it. Can anyone help?
Old 04-25-2012, 11:12 PM   #73
VA72C10
VA72C10
VA72C10's Avatar
In the glovebox would be the code. Light red commonly faded to look orange.
Old 04-25-2012, 11:25 PM   #74
dujobu
Any of you local boys have (or know where I can get) an original or OEM tailgate with CHEVROLET stamped in it?
Old 04-26-2012, 06:32 AM   #75
richard2717
There was a couple of them in the for sale section. I think Heavy Metal Chevy(Duane) had one as well as VA72C10. Not sure what you are wanting to spend. I have one off the blue blazer I parted out but it needs rust repair and I robbed the hatch seal strip off the top of it. It is fixable but probably no better than what you have
Richard
Members I have met.
