Old 03-01-2012, 03:53 PM   #126
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Ultimate work truck/ 70 K10 diesel
Originally Posted by woodwright View Post
You might check into running a Chevy one. Might be easier.
I don't think the chevy one will have enough pressure to operate my heavier load pressure plate.
Ryan
1969 Chevy milk truck
Old 03-01-2012, 04:09 PM   #127
woodwright
Enjoying left field
woodwright's Avatar
I thought you were talking about the hydroboost.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-01-2012, 04:12 PM   #128
Dieselwrencher
I'm definitely using a chevy hydraboost.
Ryan
Old 03-07-2012, 03:14 AM   #129
woodwright
Enjoying left field
woodwright's Avatar
I cut out and patched the original mount location for the throttle peddle. After that, all I had to do is drill 3 holes and the 72 peddle assembly bolted right on.
I still have to file the cable hole square, and modify my cable a little, but the peddles are done.
The original heater assembly won't work with the turbo, so I've been looking for an alternate. I ran out to the local pick a part today, and stomped around looking at different heater setups. What I ended up bringing home was the non AC heater assembly from a mid 80's chevy truck. The airbox on the firewall is really small, and lines up with the factory outside air intake. The heater core is inside the inner heater assembly, which fits pretty well under the dash.
The firewall hump is a little deeper on the older trucks, so I need to bend the heater assembly a little where it runs over in front of the hump.
I took a pie cut section out of it. The back wall of it is tin so it bends real easy. Tomorrow, I'm gonna go rent a plastic welder and put it back together. I still need to patch the unused holes in the firewall, and build an extension for where the outside air comes in.
The controls from the square body truck won't work as is, because of how the cables need to go. But I'll figure something out. The later model heater assemblies don't use cable pulls, they use small electric solenoids. I've already got the covers off the rear heater in my suburban, so tomorrow I'm gonna see how those work and if I can adapt them. I don't really like the cable controls. They tend to get sticky over time, and then the levers are snapping off.
While I was at the yard I found a late 90's tahoe with a very nice 2nd row leather seat just like this one.
It will end up costing me $20. I think I'm gonna grab it.
Clint
Old 03-07-2012, 03:17 AM   #130
VA72C10
VA72C10
VA72C10's Avatar
Nice progress! And can't go wrong for $20...that's a steal...
Old 03-07-2012, 10:23 AM   #131
madcow75
madcow75's Avatar
I guess you can't go wrong with $20. I just spent $250 on the same set of sets for my 76CC.
madcow75 is offline   Reply With Quote
Old 03-08-2012, 05:34 PM   #132
woodwright
Enjoying left field
woodwright's Avatar
Nobody in town had a plastic welder, and I ended up not needing it. I just used my soldering iron and the pieces I cut off.
It was actually pretty easy and only took about 20 minutes. Once I got it braced together, I used the soldering iron to melt the two pieces together to "tack" it together in the corners and every 1 or so. After that I melted a furrow at the seam, and then melted the cut off material into the furrow. Then smoothed the seam with the iron as I went.
It worked surprisingly well.
Clint
Old 03-08-2012, 05:56 PM   #133
madcow75
madcow75's Avatar
Wow that actually looks good. Sometimes I guess you need to make do with what you have.
Old 03-11-2012, 02:23 PM   #134
mknittle
mknittle's Avatar
That looks good. I will have the same problem before long that looks like a good way to go!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-11-2012, 03:40 PM   #135
woodwright
Enjoying left field
woodwright's Avatar
The problem you're gonna run into, is the controls. the cables are too long, and the heater/defrost lever is right behind where the controls need to be. You can probably shorten the two longer cables, but you would need to work out a linkage setup for the defrost/heat lever. Personally, I don't like the cable slides. I am trying to adapt the dial controls from a late model. I'll post some pics.
Clint
Old 03-11-2012, 10:52 PM   #136
woodwright
Enjoying left field
woodwright's Avatar
I decided against the suburban 2nd row seat. Its not gonna work very well with my high hump floor. The center leg would have to be severely modified, and it probably wouldn't be able to roll forward. So I'm gonna keep my eyes open for a split bench front seat.
I've spent the last week learning how the later model HVAC controls work. They use electric servos to open and close the inner door instead of the cables. Since I'm not gonna have AC, all I need is fan, zone control, and temp. Heres the head unit I'm gonna use.
I'm gonna build a new face plate, and new dials if I can find them. Something that looks a little more period correct.
Today I worked on getting the servos mounted. I took some 12-24 capture nuts and used the soldering iron to melt them into the backside of the case.
Added some 3/4" nylon spacers and bolts.
I've still gotta build the linkage, and figure out how to mount the head unit.
Clint
Old 03-17-2012, 09:50 PM   #137
mknittle
mknittle's Avatar
Thanks Clint, the more info the better.
Mark
My GMC build.
Old 03-17-2012, 10:22 PM   #138
freakshow108
freakshow108's Avatar
I'm digging how you are making it all work how you want it. I can't wait to see this come together!
freakshow108 is offline   Reply With Quote
Old 03-17-2012, 11:03 PM   #139
woodwright
Enjoying left field
woodwright's Avatar
I think I'm gonna use these knobs.
I'm gonna cut a new face out of 1/8" aluminum with the waterjet. I'm thinking of making a plate that runs across the whole lower recessed area that includes the key and cig lighter. I'll probably throw in my glow plug button too. I just don't want it too blingy. maybe I'll powdercoat it black.
Clint
Old 04-05-2012, 06:31 PM   #140
mknittle
mknittle's Avatar
That would look nice. I am thinking about making a frame to adapt the dodge ones from my doner truck. I figure that I can make one from 1"X1/8" flat that fits the stock holes.Maybe Ill paint it hammered black.
Mark
My GMC build.
Old 04-12-2012, 02:08 AM   #141
woodwright
Enjoying left field
woodwright's Avatar
Haven't updated in a while. I've been focusing on getting the heater done. I got the servos mounted, the relay mount mounted, and all the linkage done. Then I took the harness all apart, and reran it how it needed to go. I had to cut and splice alot of wires, but I took my time and soldered and heat shrinked everything.
I've got the firewall patches tacked in, but I need to get some more Argon before I can final weld them.
I'm hoping I can get my faceplate cut this week. I've got the Cad file done, I just need time on the waterjet. And I got my knobs. They're gonna look sweet with the brushed aluminum face. I also ordered the twin stick shift boot for my TC from JB Custom Fab. It was only $20 without the metal ring. I'll make one out of 1/8" Aluminum.
Clint
Old 04-14-2012, 02:07 PM   #142
woodwright
Enjoying left field
woodwright's Avatar
Got my faceplate cut yesterday.
The space on the left is for my glowplug button. I'm gonna fill the holes and slots with liquid plastic. Red and blue for the temp knob, and probably smoked for the rest. Its backlit so it should shine in the dark. I'm trying to figure out the best fasteners to use. I would like to blind fasten it somehow. I'm gonna play with drilling shallow holes in the back and epoxying studs in.
Clint
Old 04-14-2012, 04:49 PM   #143
madcow75
madcow75's Avatar
custom fabrication at it's finest. You are making alot of us jealous of rosources.
Old 04-19-2012, 12:29 PM   #144
woodwright
Enjoying left field
woodwright's Avatar
Did some swapping last week, and actually came out ahead. I traded a beat down 93 Suburban,
For a lifted K5 with a blown motor and brand new 35s.
Pulled the tires and traded it for a 64 chevyII.
Its got a straight 6 and powerglide and runs and drives pretty good. I'd like to put a 5 speed in it, new seats, a little body work and drive it.
Clint
Old 04-19-2012, 02:41 PM   #145
Dieselwrencher
Great trading and sweet work on the face plate! That is pretty dang cool!
Ryan
Old 04-20-2012, 12:43 AM   #146
woodwright
Enjoying left field
woodwright's Avatar
I got the knobs on and the faceplate finish sanded. brushed finish with 220 grit.
Its hard to see, but I used 4-40 brass bolts with countersunk heads to mount the face. I filed the heads down until they were smooth and then epoxied them into the face. I think when they tarnish and darken it'll look pretty cool. Kinda steampunkish. I'm gonna try to add a few more touches to the interior.
Heres the brains behind the operation.
Clint
Old 04-20-2012, 02:01 PM   #147
Dieselwrencher
That will look cool Clint! Nice looking, uh house horse?
Ryan
Old 04-20-2012, 04:06 PM   #148
woodwright
Enjoying left field
woodwright's Avatar
He's actually only about 65 lbs. He's boxer and healer. Good dog, dumb as a post.
Clint
Old 04-20-2012, 10:26 PM   #149
woodwright
Enjoying left field
woodwright's Avatar
Got everything mounted, and put in my glow plug button.
All I got left to do is add the colored plastic to the slots and holes. I've got a ton of plastic 1 gal. jugs. I'm gonna try to melt some down and tint it.
Clint
Old 04-20-2012, 11:46 PM   #150
Dieselwrencher
Good luck, I can't wait to see how that turns out. That could be a cool trick for lots of projects.
Ryan
