Old 03-12-2012, 12:33 AM   #126
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Br3w City's Project omgwtfbbq
Another nice ass day outside, so hit the garage hard. HARD. Seats came back out so I can coat the rails, and access the nasty carpet.
Pulled out the crap trim piece (I have replacements) and exposing the rust on the rocker and portion of the floor.
Carpet up, the passenger side looks like the better of the two, but the drivers foot area (thankfully all before the cab support, which although crusty is very solid.
With all the carpet out, the overall floor is dang solid, with all the mounts in decent shape, despite being a bit crusted.
Time for the door to come off
Using the trusty prybar, we found the boundaries of the rust, as well as some filler, from some point before.
Since the cab mounts were solid and staying in place, and the inner rockers were to remain in place, there was no real structural risk to the cab. We did some measurements and verified along the way, but there was no change. We started by trimming out the rusted section of flooring, keeping overall patch size to a minimum.
Moved on to the rocker, starting at the seam in the rear and doing 1/2 of the rocker at a time. This allowed me to seperate the skin from the inner portion and retain the factory seam the best I could. It also allowed me to gauge the condition of the inner rocker and keep and eye on its integrity.
With it all the way up, we could test fit the rocker and determine the final shape of the drivers floor patch. Should get to that this week, and get it all welded up so I can move onto the other side.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-12-2012, 10:52 AM   #127
scotts62
One day...
scotts62's Avatar
Getting there, looks good!
Scott
93 crew cab build
Project 62
Old 03-14-2012, 03:57 AM   #128
C@rnut001
I really like your truck and what you are doing to it. Hope you get a job soon so that you can do more to it. Your progress is looking really good. It is amazing what a carpet will hide....keep up the great work!
C@rnut001 is offline   Reply With Quote
Old 03-14-2012, 09:56 AM   #129
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the floor. I just went through this on my cab. I know exactly what you are up against.
Keep it up.
Old 03-15-2012, 01:11 AM   #130
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ya the floor had some surprises, but it wasn't all that bad. I knew what i was getting into to a certain extent, just never got around to it last season. As for the job...things are developing. Hopefully the newest prospect will afford a move to a 12 month car season-state, as well as some industry hookups...and lets say its LSx specific.
Laying out some more of the patch panels.
The rot
Then some welding....
and welding
and....welding
Not bad
I didn't have a patch for this part, so my bro decided that it was time to hand form some sheet metal. My dumbass also forgot to switch my welder back to DCEP (i had put it to DCEN to burn out the roll of free wire that came with it)...I just could NOT figure out why my welds were coming out so BIG....a complete lack of current will do that. You can see the bead gets smaller about half way up, where it was corrected. I have to grind all the welds flat anyway, so I'm sure that one will have some re-welding in areas.
We don't have a workshop, or forming tools...but we do have some hammer and dollies...which we left at the other garage. So we beat the bastard with a framing hammer on a brick. I think he did pretty damn good. There is one more little patch on this side before the rocker gets its final fitment and finish welding.
Old 03-15-2012, 08:20 AM   #131
mcbassin
Still Learning
mcbassin's Avatar
Good job fitting the patch and custom forming on the smaller patch. Loads of fun doing rust repair. Looks like you have the left side under control. How's the pass side?
Old 03-15-2012, 01:08 PM   #132
McMurphy
McMurphy's Avatar
Ok, when I started this very same repair, I thought I was doing something wrong, or my patch panel was misshapen somehow because I got this gap at the forward edge at the firewall.
I see now that you did too, so all is well in my little world, I know now that I will just have to make a small triangle patch to go in there.
I paintshopped your pic with an arrow to show exactly what I am blathering about.
Looking good man!!
I am right behind you on this part.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-15-2012, 01:29 PM   #133
62 Barnfind
62 Barnfind's Avatar
Truck looks good. I also have been replacing my rockers and door skins. I bought the truck thinking it didn't have much rust. Well, it is in the doors, left side rocker, cab corners and bed. You are doing a good job! Check out my build page!
62 Barnfind is offline   Reply With Quote
Old 03-15-2012, 01:56 PM   #134
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks for the comments guys.
McMurphy, that patch confused me also. I don't know why they didn't cut it to fit the seam, instead it angles toward the floor. I have a leftover piece of patch from the fender, which has a nice seam already pressed in it. I'm going to tweak that to fit, so hopefully I can keep the seam in a stock place.
We've only looked at the passenger side briefly, as it was the cleaner of the two. The driver side is easiest to access in my garage, and were gonna finish it before flipping her around for the other side.
Old 03-17-2012, 01:36 AM   #135
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Some weight reduction?
More welding and patching and welding and patching. Drivers floor is all done, and the rocker is back on.
Old 03-17-2012, 11:35 AM   #136
66ChevyMax
66ChevyMax's Avatar
Nice work and thanks for all the great pics
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-17-2012, 05:40 PM   #137
shrunken66stroker
shrunken66stroker's Avatar
The truck's looking good. How's the welding tan on your legs?
shrunken66stroker is offline   Reply With Quote
Old 03-17-2012, 11:46 PM   #138
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hahah, I don't have any tattoo's on my legs so I don't care about protecting them. Plus half of the one already has skin burned off it. Its not TOO bad, the part that usually gets me is when I get some sparks that shoot off down my sock!
Old 03-18-2012, 04:22 PM   #139
McMurphy
McMurphy's Avatar
Had a drop of slag do that, right into the top of my shoe. Got a scar there now.
I need more long sleeve shirts to weld in though, got done one day, had sun burn on my right upper arm the next day from welding. Guys at work could not believe it LOL
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-18-2012, 05:49 PM   #140
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thats why I rock the HALF JACKET!
Seriously, everyone looks awesome welding in workout shorts and a bright green canvas half jacket.
Even better when I weld shirtless, half jacket only.
Old 03-18-2012, 11:48 PM   #141
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Got a question... how did you hook up your floor shifter to the 4L80e? Can you post a few pics? Thanks!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-19-2012, 01:19 AM   #142
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
What exactly do you need a pic of? It was in there from the 700r4, same one you use for the 4l80e
Old 03-19-2012, 02:02 PM   #143
68GMCCustom
OH. Wasn't sure if my cable operated shifter would work on the 4L80e. Got a shot of your linkage at the side of the 4L80e?
Kurt -
Old 03-19-2012, 04:25 PM   #144
McMurphy
McMurphy's Avatar
I just finished my rockers this weekend.
I have a patch at the gas pedal base that I am going to redo, then a tranny access door where someone chopped the hump up for a shifter still to do then I am done with floor metal working.
Are you going to coat your floor with anything?
I am thinking herculiner (because I can roll it on) then deadner, then carpet.
I like the RaptorCoat stuff some of the guys here are using, but I dont have a spray gun ...... hmmmmmm ....... yet !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-20-2012, 03:39 AM   #145
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Im down in SoCal for the week, so no progress will be coming. I'm going to be peel 'n' sticking the floor then covering with the foil/foam matting then a custom carpet I'll be making myself, to extend over the back gas tank portion and up the back wall.
Old 03-20-2012, 04:03 PM   #146
McMurphy
McMurphy's Avatar
Carpet going up the back wall sounds cool.... Hope you post lots of pics, I want to see your peel and stick.
Have fun in SoCal... still 4feet of snow on the gound here.... Le'Sigh
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-28-2012, 07:49 PM   #147
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
SoCal was most excellent, it was a bit cooler than usual, but still VERY nice during the day.
I'm sitting on edge waiting for some information before I can post more on what and why.
Hoping to get the passenger side worked on this weekend, so I can start looking at the carpet.
My brother decided we should do a headliner out of the matching door/seat vinyl, anyone know where I can find the cardboard base to wrap a headliner? I thought those existed at one point.
Old 04-06-2012, 12:47 AM   #148
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not a "truck" update...but a "me" update. I'm signing my contracts, as I finally got a job! Not only that, in about 4 months I should be moving to SoCal, to work as contributing editor. Those of you that read LsxTv, Street Legal TV and the like will get to hear my inane ramblings about things. It should also mean nice exposure, and ideally some "comp'd" parts from sponsors. Obviously I'm happy.
If weather is ok here I'll be starting on the other side of the floor, but knowing the forecast I'll be doing a gun build or two. We shall see.
Old 04-06-2012, 01:48 AM   #149
Captainfab
60-66 Nut
Glad to hear you got a job, and a cool one at that!
Moving to SoCal is going to be a bit of a trip.
Old 04-06-2012, 11:24 AM   #150
68GMCCustom
WOW....what a "dream job". Congrats!!!
No doubt you'll be able to get your truck involved in various projects...netting you some free hardware. I'm jealous!
Kurt -
