Old 03-25-2012, 09:35 PM   #1
mcbassin
Still Learning
mcbassin's Avatar
Original Bucket seats installation????
I'm trying to drill the holes in my cab for original bucket seats. I'm looking for some pictures of the braces and alignment of the seats. Anyone document their installation? I have the material to make the braces but would kinda like to see some originals.
Are the outside front holes used on LH and RH seat mounts? Thanks
Old 03-25-2012, 10:30 PM   #2
mcbassin
Still Learning
mcbassin's Avatar
Re: Original Bucket seats installation????
Here are some pictures of what I'm looking at.
Notice that the seats are touching the center console on the sides with
the bolts in the outer stock bench seat holes.
Old 03-25-2012, 10:37 PM   #3
jocko
jocko's Avatar
subscribed. Always thought they used the same holes as the bench seat - so, therefore, I have no clue.
Old 03-25-2012, 10:45 PM   #4
mcbassin
Still Learning
mcbassin's Avatar
I have always thought that too but, it just doesn't look right. The driver side inside mount hits the tranny tunnel raised area before the bolt will fit in the hole too. I can force it in there but it's tight.
Old 03-25-2012, 11:07 PM   #5
71 super
71 super's Avatar
if you look there are dimples in non bucket seat floors for bucket seat location. There are also dimples in the center floor pan for the console as well. The only direct bolt in is the the buddy bucket seats, all others must be drilled to fit.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-25-2012, 11:19 PM   #6
FirstOwner69
FirstOwner69's Avatar
I don't have my cab here to confirm this, but it appears that the dimples refered to are visible in a couple of your pictures outboard of the seat brackets. Looks like 1/2"-3/4" out from the existing holes. This is consistent with where my original buckets were mounted from the factory.
FirstOwner69 is offline   Reply With Quote
Old 03-25-2012, 11:37 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
I found two dimples for the console caddy corner from each other. I saw one in the rear on the driver side that looked like it might be close to what I need. So basically, no matter what the bench seat cabs will need all the holes drilled?
Any chance any of you experts have some pictures of your original buckets or a measurement from the seat bracket to the center edge of the radius?
Old 03-25-2012, 11:39 PM   #8
mcbassin
Still Learning
mcbassin's Avatar
You may be right. There are some dimples that look like spot welds. Any chance you have any pictures of your seats in relation to the console from an overhead view like looking through the back window or windshield? I would like to see what the gaps are between the seats and the console. thanks
These look like dimples in the picture here:
Old 03-26-2012, 12:08 AM   #9
FirstOwner69
Those are the ones I was referring to. I don't have any pictures that would help, and the truck is currently disassembled and 2000 miles away. If you can wait about 3 weeks I can get pics. However, I estimate the seats are about 3/8"-1/2" away from the console. I have some shots with the seats installed but from a 45 degree angle... not much help.
Old 03-26-2012, 12:20 AM   #10
mcbassin
Still Learning
mcbassin's Avatar
Thanks for the offer, I appreciate all the info I get from guys on this board. I have never installed these so I kinda want it to be right. I already drilled the pass. side. But I'm pretty sure they are wrong. I can't wait 3 weeks but thanks anyway. I have seen some 45 and side shots and you really can't see the gaps or lack of. thanks
Old 03-26-2012, 12:56 AM   #11
FirstOwner69
I found this old thread http://67-72chevytrucks.com/vboard/s...d.php?t=352079
Perhaps post 8 will help. I'm still searching for others.
Jim
Old 03-26-2012, 01:37 AM   #12
FirstOwner69
Here's another thread http://67-72chevytrucks.com/vboard/s...d.php?t=367549
Old 03-26-2012, 04:53 AM   #13
Classic Bowties
Always on the hunt...
Hi Mike, I have owned decent share of these trucks over the years and done a few 69-72 truck bench to bucket conversions in them years and have not came across any floor pans having the dimples already in place for drilling the bucket seat mounting bolt holes, maybe that was a regional/plant type of deal. I'll give this a shot to the best of my knowledge, when using the 69-72 truck bucket bracket setups and when going into an original bench seat truck cab, there is only one hole of the eight in the bench cab floor pan that's already in the correct place and that you are going to use when bolting the bucket mounts in. The one bolt hole (only one in correct location) that you should use is the RH fwd. most outer bolt hole, so it would be the pass. side fixed mounted bucket fwd. RH bolt, you will need to drill the other eleven mounting bolt holes. I have had these pictures of an OE option #A50 bucket seat floor pan that were taken for another member and then stuck away in a saved folder, not sure if they will help you dimensionally as they don't have any measurements but the pics do highlight all twelve of the bucket seat bracket mounting bolt holes and they also show how the factory used pan head filler screws to plug the other bench seat mounting bolt holes. The bottom view pictures highlight the factory added bucket seat cab only floor cross support & extra bracing. Hope this post and pics can get ya headed in the right direction, Mel.
Classic Bowties is offline   Reply With Quote
Old 03-26-2012, 04:57 AM   #14
Classic Bowties
Last five B/S floor pan pics...
Old 03-26-2012, 08:26 AM   #15
mcbassin
Still Learning
mcbassin's Avatar
Mel,
Thank you so much. This is exactly the information I was looking for. What you are saying is my pass. side holes I already drilled are in the right position. I only used the outer front hole and then marked the other three with it bolted down in that one hole. I'm assuming the driver side mount setup is wider becaus the outer holes need to go outward about 3/4-1" in your picture. Do you happen to know what the gap was at the center console between the seats on both sides? Also, when you installed these buckets on bench trucks did you fabricate that front brace that runs across the bottom of the rib at the front mounting position? thanks for the help.
Old 03-26-2012, 09:38 AM   #16
Lee H
Lee H's Avatar
My 72 had these dimples, once drilled my buckets and console fit right in.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-27-2012, 12:33 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
Okay, I bit the bullet and went with Mel's suggestion from the original bucket seat floor pan. Although I didn't build the brace that ties the two sides together I did make some braces from some old ball bearing drawer slides. They are the exact thickness and near the same width and depth. Here are the pictures of what I did in case someone else can use it. If you look at the pictures, you'll notice I moved the driver side hole pattern outward 3/4". this made the two seats the same distance from the edge of the seat to the door opening symetrical. It also made it where the driver side seat isn't bound up against the console.
Old 03-27-2012, 12:35 AM   #18
mcbassin
Still Learning
mcbassin's Avatar
More pictures
Old 03-27-2012, 01:09 AM   #19
jocko
jocko's Avatar
very helpful - thanks for posting (everyone) - answers some questions I've had for a while also.
The pics are worth a thousand words, as they say...
Old 03-27-2012, 02:06 AM   #20
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Another great post to keep seeing I'm 90% sure I'm getting buckets and console for Pinky.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-27-2012, 07:57 AM   #21
lolife99
67-72 parts collector,…
lolife99's Avatar
Great work on the underside reinforcements!
Keith
Convert to disc brakes.
Old 03-27-2012, 08:48 AM   #22
mcbassin
Still Learning
mcbassin's Avatar
Thanks Keith.
Thanks to all you guys the helped me figure this out. That's the stuff that makes this board great
Old 03-27-2012, 01:15 PM   #23
Classic Bowties
Originally Posted by mcbassin View Post
Mel,
You are welcome and I am always glad to help out, as far as using the whole bucket floor pan or just removing and then adding the OE bucket cross support and braces to the original bench seat floor pan, I have done it both ways and in the end prefer the second method. You did a good job on building your bucket brace setup, that under shot looks better than most of the bucket converted trucks running around these days. Now tell me this, just yesterday I took a closer look at five different 71/72 cabs and seen NO dimples for drilling the bucket seat mounting bolt holes, I have three factory bucket floor pans here on hand and know where the said missing dimples should be, I did see some spot weld marks present but no dimples pertaining to any sort of a drill pattern, did your floor pan have the above described dimples where you ended up drilling the other eleven holes? Mel
Old 03-27-2012, 02:30 PM   #24
tkeduk8r
tkeduk8r's Avatar
Great thread!!! Been looking for this info layed out like this for a long time. Im wondering if there would be a market for a kit that would supply the tabs, cross support, and paper template for the conversion???? I dont have the manufacturing capability to make the parts (press brakes are way to cheap) but if someone does maybe might be an opportunity.
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 03-27-2012, 04:21 PM   #25
68 TT
Still plays with trucks
68 TT's Avatar
Nice work Mike. Very clean.
I would add a cross support similar to stock.
I am concerned the center of the floor isn't designed for the load of the central seat mounts and would stretch out or crack over time if left unsupported.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
