Old 04-15-2012, 08:39 PM   #76
Rude Dude
Rude Dude's Avatar
Re: 56 Chev Garage build
A little update got a 327 large journal rebuilt from a friend of mine, it had power pack heads and right side blown head gasket, I found late camel hump heads and swapped them out with new gaskets and harmonic balancer. I also started to install bed wood, going to hide bed strip bolts that is why no holes in pictures stay tuned for that one. I also found another intake that was painted orange so I smoothed it out and it is going on 327 motor. The intake that is on it I am not happy with it from China and runners hit my valve covers Sucks. Sorry about the bad pictures my camera wont stay on even with new batteries had to revert to camera phone.
Rude Dude is offline   Reply With Quote
Old 04-15-2012, 08:45 PM   #77
Kim57
Kim57's Avatar
The bed wood looks nice.
I like the finned rocker covers.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-15-2012, 11:57 PM   #78
55Cameo
55Cameo's Avatar
Nice work. Subbed for ideas and progress
55Cameo is offline   Reply With Quote
Old 04-16-2012, 08:38 AM   #79
Red Foreman
Red Foreman's Avatar
The edelbrock c3bx is a good quality vintage intake let alone much cooler then the chinese junk anyway.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 05-20-2012, 11:03 AM   #80
Rude Dude
Rude Dude's Avatar
I started to run the front brake lines now that my engine was out, and looked at steering out of the firewall. I didn't like it at all so I had asked chuckdriver how much his was out out and used that as a base to cut mine down. Over all I cut roughly 8 inches off the main shaft and 5" out of the outer shaft. If you look at the inner shifter tube I just used a dremmel and ground the 3 spot welds and slid the bracket up the tube and welded the bracket on the outside made it a lot simpler than dissembling the whole colmn just to cut and re weld the inner tube. All I had to do then was to cut the end of tube.
Also I move the neutral safety switch up on the column so it can't be seen inside.
Old 05-20-2012, 11:16 AM   #81
Rude Dude
Rude Dude's Avatar
More tilt column pics mod, also a pic of inner shaft it was beveled welded and cromoly slide over weld and welded again. Can't be to safe once again thanks to Cuckdriver for the measurements!
Old 05-20-2012, 12:45 PM   #82
_Ogre
_Ogre's Avatar
nice work on the column mods
i like how you made it work instead of buying a new shiny aftermarket column
nice work on your upper radiator hose too
we shop at the same hose store
shop air compressor timer
Old 05-21-2012, 12:50 AM   #83
Kim57
Kim57's Avatar
Nice work on the column.
Kim
My build thread
Old 05-21-2012, 08:55 PM   #84
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome job Dude! Glad I was able to assist, but you deserve all the credit for pulling it off flawlessly!!
ChuckDriver is offline   Reply With Quote
Old 05-21-2012, 11:24 PM   #85
hammerdog57
hammerdog57's Avatar
Nice fab work on column. I took four inches off the outer housing on mine . But i am using stock shifter handle and wanted to get handle further away from dash. Where did you find the shifter handle etc.?
hammerdog57 is offline   Reply With Quote
Old 05-22-2012, 07:50 AM   #86
Rude Dude
Rude Dude's Avatar
Shifter Handle is part of the Van Column, I just took the plastic handle tip off and used a aluminum handle dress up kit.
Old 05-22-2012, 09:35 AM   #87
waybad
waybad's Avatar
great job
waybad is offline   Reply With Quote
Old 06-09-2012, 04:54 PM   #88
Rude Dude
Rude Dude's Avatar
re-assembled Tilt, new lower bearing, turn sidnal switch assembly and prepped and primed for paint, steering is nice and tight,got to windy to paint maybe tomorrow!
Old 06-09-2012, 05:01 PM   #89
Rude Dude
Rude Dude's Avatar
That stand is my cheapo 2 x 4 stud mount, I like it cause I can spin the coulmn to paint easy!
Old 06-09-2012, 08:03 PM   #90
Kim57
Kim57's Avatar
Looks good.
Nice idea on the paint stand.
Kim
My build thread
Old 06-09-2012, 08:22 PM   #91
ChuckDriver
Nice stand!!
Old 06-11-2012, 09:03 AM   #92
waybad
waybad's Avatar
cool!!!
Old 06-11-2012, 09:25 PM   #93
Rude Dude
Rude Dude's Avatar
It wasn't windy yesterday so painted the column no runs!
Old 06-11-2012, 09:45 PM   #94
Red Foreman
Good progress, I'm going to use your column stand idea!
My Build 56 GMC
Old 06-12-2012, 12:18 AM   #95
Kim57
Kim57's Avatar
It came out nice.
Kim
My build thread
Old 08-05-2012, 09:25 PM   #96
Rude Dude
Rude Dude's Avatar
Finally rubbed out the paint on the column it came out like glass, The drop for column was machined aluminum so I sanded it with 600 then 1500 grit sand paper and polished by hand. I painted the firewall it had one small run but I am happy with it remember it will be a daily driver can't get to fancy.
P.S. Excuse the quality of the pics still havent bought a new camera yet had to use the phone and it sucks!
Old 08-06-2012, 12:08 AM   #97
Kim57
Kim57's Avatar
Very shiny.
Kim
My build thread
Old 08-19-2012, 10:37 AM   #98
Rude Dude
Rude Dude's Avatar
I modified some 61 Imapla lenses to fit my truck tail light housings, Looks sweet but messy work!
Old 08-19-2012, 01:23 PM   #99
_Ogre
_Ogre's Avatar
looks good dude
Old 08-19-2012, 03:46 PM   #100
Kim57
Kim57's Avatar
Nice lights.
Kim
My build thread
