Old 12-11-2011, 04:39 PM   #101
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 63-72 Chevy P/U Rear Shock Mount System
I think the patterns on the 'rails are different top to bottom, so you'd probably have to drill. Also have to think of carrier bearing mounting and e-brake cable pass-throughs...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-11-2011, 09:43 PM   #102
jbice70gmc
jbice70gmc's Avatar
Theres 2 rivets on the top and 3 on the bottom. I will probably just drill 2 extra holes and put three bolts on both sides. Looks like the drive shaft passage is the same either way. Striaght shaft no carrier. My cut outs for the exhaust on the one I have look kind of bad. I basicly cut diamonds out of them with a sawzall. Heres a pic. Does anyone think I haved damaged the strength of the crossmember. Just trying to make a good decision in preparing for the no limit shock relocators.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 01-17-2012, 10:39 AM   #103
sir_talk_alot
sir_talk_alot's Avatar
so outa curiousity, do i have to relocate my rear shocks with a 5" coil drop or can i get away with just using drop shocks?
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 01-17-2012, 12:18 PM   #104
robnolimit
robnolimit's Avatar
To go 5", 'drop shocks' will be down to appx 3 1/2" travel. (and laid over like crazy) thats 1 3/4" bump, and droop, from RH. Check into the shock relocators. BTW, try a 3" spring, and a 2" block. Your kidneys, and your girl's kidneys will thank you. Just because they sell 5" drop springs doesn't make them a good idea. - kinda like chain steering wheels.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-17-2012, 02:44 PM   #105
65Gregg
65Gregg's Avatar
What he said!!!
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-18-2012, 06:32 AM   #106
69vetteside
69vetteside's Avatar
rob is there enough room with this conversion to still have my 29" x 15.5" tyres,in the pic it seems pretty close to the axle centreline.
anyone bought a kit that is running a big rear wheel/tyre setup ?
69vetteside is offline   Reply With Quote
Old 01-18-2012, 12:28 PM   #107
robnolimit
robnolimit's Avatar
I am running 18 x 9, with a 6" backspack (really should be 4 3/4 to fit perf.), 275/40/18, there is still 4"+ from the tire to the shock. I don't see any problems.
Old 01-18-2012, 02:41 PM   #108
69vetteside
great i will get a set ,do you send to australia?
Old 01-18-2012, 04:22 PM   #109
robnolimit
robnolimit's Avatar
hey, we ship anywhere!!!
Old 02-01-2012, 08:48 AM   #110
68 Four on the Floor
68 Four on the Floor's Avatar
Good looking kit. Do these come powder coated or natural?
Last edited by 68 Four on the Floor; 02-01-2012 at 08:55 AM. Reason: stupidity on my part
68 Four on the Floor is offline   Reply With Quote
Old 02-01-2012, 11:38 AM   #111
robnolimit
robnolimit's Avatar
All the brackets are powder coated machine grey. They will fit with any of the aftermarket bolt-on C-notch kits.
Old 02-01-2012, 07:32 PM   #112
72chevy383
Rob,
I'd like to order kit 3GC-RR-100 & 3GC-RR-101 A. Also does the panhand clear after market covers? Mine sticks out farther than the stock?
Tom
72chevy383 is offline   Reply With Quote
Old 02-01-2012, 08:18 PM   #113
robnolimit
robnolimit's Avatar
Yes, the panhard should clear, we have 1 3/4" from the stock cover, but, if not, we will custom build you a bent bar at no extra cost, and swap with you.
Old 04-16-2012, 10:41 PM   #114
RdoubleU
RdoubleU's Avatar
Part of the assembly includes the 'Tie plates' that fit between the trailing arm and axle, and these also have the rear swaybar attachment points. The new rear swaybar kits will list at $239.00. .
Rob - any news on the rear swaybars coming out of production yet? I already have the rear shock re-locators and panhard bar just looking to tie it all together.
RdoubleU is offline   Reply With Quote
Old 04-17-2012, 07:10 AM   #115
Andy4639
Old member
Andy4639's Avatar
Truck info.
1971 LWB with about 5"-6" rear drop with helper air bags. No c-notch. Ride is fantastic now. I have the shock kit as you can see in the video. Thanks for a great product. I have 20" wheels 10" wide in rear.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-17-2012, 09:05 AM   #116
502ms
502ms's Avatar
Great looking product, Rob. My truck is bagged/4 link rear. I'd look into this for my next truck
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 04-17-2012, 12:07 PM   #117
robnolimit
robnolimit's Avatar
Cool video, how do you like those tires?
Old 04-17-2012, 04:56 PM   #118
Andy4639
Old member
Andy4639's Avatar
Wink Re: 63-72 Chevy P/U Rear Shock Mount System
Thanks,
the tires are OK I guess. It handles good. They are z rated so I want get much milage out of them they said. Going to swap the camera around tonight and do a straight ahead video.
Here's the front video.
Old 04-17-2012, 08:55 PM   #119
jayman68
Fun Stuff
jayman68's Avatar
Those tires will definately wear out fast with that much toe in.
Cool vid.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 04-18-2012, 12:47 PM   #120
sunk99
sunk99's Avatar
Would there be any differences in the part #'s for a 69 suburban with 3" springs and 2" blocks?
sunk99 is offline   Reply With Quote
Old 04-23-2012, 07:15 PM   #121
RdoubleU
RdoubleU's Avatar
Bump for rear swaybar status update
Old 04-24-2012, 11:40 AM   #122
robnolimit
robnolimit's Avatar
Same parts
Old 04-24-2012, 11:42 AM   #123
robnolimit
robnolimit's Avatar
We are finally finishing up, should have bars back next week to go to powder coating. Hoping for may 10th to be ready to ship.
Old 04-25-2012, 08:53 AM   #124
RdoubleU
RdoubleU's Avatar
Thanks Rob - Keep us posted, I'm sure your going to have a few orders come in quick
Old 04-26-2012, 01:06 AM   #125
Andy4639
Old member
Andy4639's Avatar
Cool Re: 63-72 Chevy P/U Rear Shock Mount System
RdoubleU,
was this you a couple of years ago at Year One car show in Braselton, GA.
If so we talked for awhile. I had my 07 Tahoe there and took it out on the road course.
