02-17-2011, 12:13 AM | #1 |
Polock07
Project: ROGUE GMC
After Six months and countless hours researching online, i have finally acquired the necessary items to hopefully build a 1-ton quad cab 1969 GMC. The last part, a 1969 suburban i dragged into my garage this weekend after i put a coat of sealer on the bed, fenders and hood for the project, so i could move them outside. The search for parts is over; now the real work begins
02-17-2011, 12:20 AM | #2 |
Re: Project: ROGUE GMC
well sounds like a great build gotta love 4 doors!
02-22-2011, 12:54 AM | #3 |
Polock07
Project: ROGUE GMC
finished cleaning out the suburban, found out it was my brother buddy from high school rig, explains all the dents in the back, its time to preform some civil war surgery and take off the back with a sawzall
02-22-2011, 01:07 AM | #4 |
Rick its only a 3 door!
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
02-22-2011, 01:07 AM | #5 |
i hate to see you hack that suburban up man there to cooool....
02-22-2011, 01:44 AM | #6 |
x2, but it just makes them even more unique and worth more the less of them their are
02-22-2011, 01:47 AM | #7 |
good Point!
02-22-2011, 01:55 AM | #8 |
yup. oh well, at least i already have mine
02-22-2011, 02:10 AM | #9 |
not to many suburbans left in Wisconsin.....
03-04-2011, 11:54 AM | #10 |
Polock07
I felt bad about chopping up the suburban those things are great, but the back was in horrible shape and "you got to break a few eggs to make an omelet".
spent the weekend pulling the axles off a 1 ton, two dana 60 should fit my project nice. got a little further on combining the two cabs the right side looks pretty straight forward its the drivers side that i'm still working out, the want to make it a four door is there, next week is dead week then finals week so not going to get much done, but spring break should be able to makeup time |
03-16-2011, 10:57 PM | #11 |
Polock07
Started working on the fourth door this weekend was able to get all the sheet metal off with no damage to it so hopefully i can turn it into the fourth door skin
03-27-2011, 04:10 PM | #12 |
Polock07
started attaching the back of the cab today, once it all lines up the welding will begin
03-27-2011, 04:16 PM | #13 |
Cant wait to see this one done!
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
04-24-2012, 01:20 PM | #14 |
Polock07
Well finally starting to look like a four door, went to scrap yard and found a GMC front clip and a roof that's in good shape for the front of the roof, issues going to be connecting the back to the front and making the inside look stock.
finally decided on a 12 valve cummins turbo diesel, manual, figured i'd set the crew cab on the dodge frame and move body mounts to fit. but that's a ways off still need to finish roof and build fourth door and alter third door |
04-24-2012, 02:56 PM | #15 |
Nice build! Looking forward to more pictures.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-24-2012, 03:25 PM | #16 |
should be sweet
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
04-24-2012, 09:19 PM | #17 |
I am wanting to do the same thing with my 67. So you have me hooked, I be here until the end. Looks good so far
07-01-2012, 12:51 PM | #18 |
Polock07
having an issues getting door to line up, decided to use a cab top to get the roof right inside and outside, but having an issue lining up the gap between the door and windshield, if you can see it in the picture it looks like it starts then starts to go off at an angle. the original looks angled to me too. all the other gaps around the door look good, uniform through out and same measurements throughout. the angle is off by less than a half degree from the original angle so i'm at a loss on how to get that upper corner down to fit and get the gap aligned?
