04-26-2012, 11:31 PM | #1 |
Newbee with some questions
Getting ready to buy a 63 C-10 short bed.First time owner of these trucks.. Not sure why these trucks are named different (fleetside,stepside). It already has been lowered front & rear and it has a disc brake 6 lug set up with new brake lines & hoses. My question is...I noticed some rot under one of the doors,I know no one makes replacement doors (except the skin) Id like to swap the door for a good used one....Is 63 the only year that will fit,or will other years fit too?..
04-27-2012, 12:31 AM | #2 |
Re: Newbee with some questions
I believe 63-66 should be the same. LMC truck has a LOT of parts for these trucks. You could build one from scratch from their catalog. Their prices seem to have gone up lately shipping up here to Canada but its always nice working with new parts if your budget allows.
Posted via Mobile Device |
04-27-2012, 12:41 AM | #3 | |
04-27-2012, 12:56 AM | #4 |
60-66 Nut
Welcome to the forum
The '60-'63 doors are interchangeable. If all you have is a small rust issue, I would just fix the door you have. There are some patch panels available for reapiring rusted doors. There are several vendors that have those, such as Mikes Bump and Grind, Top Banana Parts, Classic Parts, just to name a few. The chances of finding a better door are slim these days.
04-27-2012, 01:08 AM | #5 | |
the ones that are just a reg. bed are called "fleetside"
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
04-27-2012, 01:48 AM | #6 |
OK that clears that up thankyou...Can I ask....is it possible to put a step side bed on a fleetside truck? Is it a bolt up process?
04-27-2012, 01:51 AM | #7 | |
04-27-2012, 08:26 AM | #8 |
May not be a direct "bolt on" but swapping a fleet bed for a step, or visa versa is pretty straight forward. Main thing you gotta know is if its a short bed or long bed.....
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
04-27-2012, 11:34 AM | #9 |
I have to disagree with this. You cannot build a 60-66 from a parts catalog. Especially if your using Chinese reproduction parts that will not match up. Your best bet is to go OEM or NOS. Hit the scrap yards and craigslist up for parts. There are a ton of old parts out there for a margin of the cost of reproduction and the fitment issues are not there. The chinese reproductions are very poor quality and you will find alot of problems with alot of the parts. There are plenty of threads here to support this. The parts are overpriced and under quality. Sometimes they are your only option for some things. I would only suggest going to the catalogs for parts that are not obtainable or parts that are generic...ie...wiring, bed wood, etc...Do some research on what your looking for, hit up the classifieds. You will find alot of people only resort to the catalogs as a last resort. Also...60-63 cabs/doors are interchangeable and 64-66 cabs/doors are interchangeable.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-27-2012, 03:41 PM | #10 | |
04-27-2012, 04:48 PM | #11 |
Check The Champ, Demonstrator
This guy north of you has alot of trucks perhaps you could call him. LINK
http://67-72chevytrucks.com/vboard/s...hlight=picture |
04-27-2012, 09:24 PM | #12 | |
