04-27-2012, 04:58 PM | #1 |
Junk Yartist
Service Engine Soon Light Ghost!
My 95 2-door Yukon has a SES light Ghost! Here is the scenario...
-Start truck -Drive Truck -After 1-3 minutes the SES light will come one for less than 30 seconds -Truck is ODB 1 and will not store a code! -tried driving with scanner hooked up -scanner shows no codes are stored EVEN WITH SES LIGHT ON!!!!! This happens 4 out of 5 times... it is not constant. Any Ideas? This may be a key to the ol' girl passing California Smog!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
04-27-2012, 06:31 PM | #2 |
Re: Service Engine Soon Light Ghost!
o2 sensors will do that garbage. check there good.
04-27-2012, 06:41 PM | #3 |
97' Tahoe 2dr/2wd
follow what ever advice that chevy tech gives you.....
hopefully he will see the thread and chime in.... if not, send him a PM |
04-27-2012, 09:51 PM | #4 |
Tommie – thank you for your vote of confidence.
jbclassis - Does the scanner show the system ever making it to closed loop operation? The computer could have failed and the system is running off the back-up in the PROM (MEM-CAL) As a test you could unplug the TPS and see if the computer is able to set a trouble code when there is a problem.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
04-27-2012, 11:12 PM | #5 | ||
Junk Yartist
I am going to replace the O2 anyway... I don't have a code for lean or rich, but I have not replaced it since I bought it in 05.
I unplugged the Computer controlled advance wire and it set the SES light, I unplugged the EGR solenoid and it set the light... is this what you are looking for, or does it specifically have to be the TPS?
04-28-2012, 10:13 AM | #6 | ||
Read the codes manually. Checking OBD1 computer codes without a scan tool. http://67-72chevytrucks.com/vboard/s...5&postcount=11 Quote:
Lets us know what codes you find.
04-28-2012, 12:04 PM | #7 |
Junk Yartist
And the lucky number is...
...13 O2 sensor circuit failed First thing I will be doing is replacing the o2 sensor then we will go from there.
02-25-2013, 02:23 PM | #8 |
My '92 does something similar, but I haven't checked the codes yet.
Start the truck, it runs like a top, after about 15 minutes of driving, the SES comes on and will sometimes stay on, sometimes go off. The truck doesn't seem to run any different and if I stop for even a minute, the light will reset and come back on later, maybe. Sounds like it might be something like o2 or EGR type sensor, I will run the codes when I get home.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
12-22-2013, 02:33 AM | #9 |
Check the "Testing the O2 sensor" videos on you tube. You can test the O2 sensor on the car with a digital voltmeter and a wire probe.
12-24-2013, 11:29 AM | #10 |
I am waiting for another TBI for my '88 5.7..... The shaft is a tad loose causing a vacuum leak. The engine runs a bit rich due to the leak, and a slight rise in RPM causing the SES to turn on / off. The leak has been there for a while, but I didn't notice, because the rise was slight and I got used to the idle, not realizing the RPM change.
No codes. |
12-27-2013, 12:32 PM | #11 |
Vac leak maybe? That truck was designed to run on gas, at the pump you get anything but that. Carbon deposits make it worse. Maybe some non ethanol gas for a tank or so and steam out the carbon with water(better than seafoam) and possibly se if symptoms change? Wouldnt really cost anything and worth a try?
