Old 04-22-2012, 10:28 AM   #1
Notch1988
Notch1988's Avatar
Question Rear mount tank vs rear cross sill?
On the really low trucks that are putting in rear mount tanks, I assume the tank is sitting higher than the frame and interferes with the rear cross sill. What are you guys doing to mount the back of the bed / modify the cross sill?
Pics are worth a thousand words...
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 04-26-2012, 07:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Rear mount tank vs rear cross sill?
Anyone?
Keith
Convert to disc brakes.
Old 04-27-2012, 01:57 AM   #3
andrewmp6
If you haven't bought a tank look at http://www.porterbuiltfabrication.co...quipped-Trucks
Old 04-27-2012, 02:09 AM   #4
shawno72
C/10 junkie
shawno72's Avatar
Subscribed
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-27-2012, 05:19 PM   #5
Pro Performance
Pro Performance's Avatar
Boyd Welding makes some nice aluminum tanks. Not that the Porterbuilt isn't, as I offer that as well, but the Boyd is a little more affordable depending on your budget. The Boyd tank hangs down below the frame rail about 2.5", but this can be modified if you want it tucked up higher. Just need to adjust the size of the tank and/or clearance the bed brace. You end up seeing about 1.5" of the tank when you are standing behind a lowered truck.
As they come, it doesn't require any cutting of the bed or anything, and is a bolt-in deal. Just depends if you go with the bed fill version or side fill.
Hope this info helps.
Boyd Tanks - $349 (carb version)
Pro Performance is offline   Reply With Quote
Old 04-27-2012, 09:41 PM   #6
Notch1988
Notch1988's Avatar
As a few have mentioned the Porterbuilt tank, his is a prime example of a tank that would require modifying the rear cross sill. Just wondering what people have done...
Link to my build:
My GMC Project
Old 04-28-2012, 01:57 AM   #7
andrewmp6
I think nates comes with the rear cross member bar shown if not he sells them.
Old 05-01-2012, 04:14 AM   #8
502ms
502ms's Avatar
Is there another option to this for those of us with rear, frame mounted air tanks? I have a 5 gallon air tank in the rear, and two compressors in front of that, plus my horns. Is there a tank that could be mounted in the bed? I know I can do a fuel cell in the bed, but I want something more secure and safe. PS - I have a stepper.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 05-01-2012, 09:27 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
A popular option is to raise the entire bed floor so that sits several inches higher, clearing the tank and other components that have been packaged underneath.
Not everybody likes the raised floor look, and if you didn't want to go that route, your stuck cutting the cross sills for clearance.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-01-2012, 10:03 AM   #10
Notch1988
Notch1988's Avatar
Nate
I understand raising the bed floor, but whether you do or don't you still have to attach the bed to the frame at the same level as a stock cross sill to maintain body lines. Just wondering what guys are doing at the back when "stuff" is in the way...
Link to my build:
My GMC Project
Old 05-01-2012, 10:11 AM   #11
PBFAB.COM
PBFAB.COM's Avatar
Our tank does not interfere with the rear most cross brace for the bed.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-01-2012, 11:36 AM   #12
Notch1988
Notch1988's Avatar
Maybe I'm missing something, but I'm pretty sure my rear cross brace runs right around where your second bolt hole is from the front. I don't see how I could set my bed down without it sitting on the gas tank.
Link to my build:
My GMC Project
Old 05-01-2012, 11:45 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
I thought we were talking about the rear most cross-brace where the bed bolts to the rear of the frame.... this does not come in contact with our tank.
From there forward.... it's another story.
I guess I am not quite clear on what information you are looking for. In order to run a tank that has 15+ gallon capacity, and have adquate ground clearance on a truck that is capable of laying frame... Some trimming will be needed.
I will check back in later today and see if I can offer any more suggestions/information.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-01-2012, 12:16 PM   #14
lolife99
lolife99's Avatar
Nate is talking about the "frame" crossmember.
I assume you are talking about the "bed floor" crossmember.
Do you have a wood floor or a metal floor?
Like Nate said,... your going to have to modify the bed crossmember at the very minimum.
(Or even raise the entire floor).
It all depends how high your tank is above the frame rail.
Keith
Old 05-01-2012, 12:20 PM   #15
lolife99
lolife99's Avatar
The factory blazer tanks will work back there,... but not on trucks that lay frame.
(unless raised above the frame rails)
5/7 static dropped trucks and bagged trucks with air bags installed in place of the stock coil springs can utilize the blazer tanks in the stock location.
Keith
Old 05-01-2012, 12:33 PM   #16
Notch1988
Notch1988's Avatar
Yes the cross sill on the bed floor of a 63-66 truck with a wood bed. I fully understand that the cross sill will need to be modified, that was the whole point of this thread from the beginning LOL... to see what guys have done to support the bed / how they modified it.
Link to my build:
My GMC Project
