Old 05-04-2012, 01:32 PM   #1
72tutone
Opinions needed ECE Drop 2/4 or 4/6
Im in the market for an ECE kit. Im debating on whether to do a 2.5 spindle up front with a and 4" coil drop in the rear or a 4/6
Here is a pic of my rear. Sorry I dont have the front as the entire front clip is off the truck.
This is how the truck sits now. To my knowledge and im the 3rd owner after my dad handed it down, this hasnt been lowered at all. My guess is age old sagging as the truck sits somewhat level across it.
Tires are 235/75/15 with 6.5 rally's.
Anyone running the same size tired and the listed drops above? I have done several searches and cant really make up my mind.
72tutone is offline   Reply With Quote
Old 05-04-2012, 01:34 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Opinions needed ECE Drop 2/4 or 4/6
4/6 all the way, in the end I think you will be much happier.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 05-04-2012, 01:36 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
This is about a 5/7 drop.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 05-04-2012, 01:48 PM   #4
67anthony
I have a 4/6 i love it.
67anthony is offline   Reply With Quote
Old 05-04-2012, 01:54 PM   #5
72tutone
Are you guys replying have roughly the same size tires?
I want to be able to drive it, however I dont want a "slammed" look per say.
Missouri roads arent the greatest so if im too low, gonna have problems.
Another concern is long tube headers. 4/6 clear without any issues?
Old 05-04-2012, 02:02 PM   #6
JWall
Frequent Flyer
JWall's Avatar
235/70/15's on 4/6 drop
- Justin
1 Owner 1976 SWB
Old 05-04-2012, 02:09 PM   #7
72tutone
Trucks are looking great!
Jwall, what size rims are you running on those? Did you have to shave off your A-Arm? You running ECE Spindles as well?
Old 05-04-2012, 02:22 PM   #8
Dano69c10
Dano69c10's Avatar
4/6 will do the trick, 2/4 will leave you wanting to lower more...
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 05-04-2012, 02:29 PM   #9
original-71
///Relaxed Atmosphere
original-71's Avatar
4/6 has my vote and like stated above i want lower now
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 05-04-2012, 03:46 PM   #10
JWall
Frequent Flyer
JWall's Avatar
They were 15x8's.
I did trim the lower A-Arm.
Yes, I used all ECE parts.
That truck was 2/4 dropped when I got it & it just wasnt low enough.
- Justin
1 Owner 1976 SWB
Old 05-04-2012, 04:33 PM   #11
big_al_71
big_al_71's Avatar
2/4 is not nearly low enough and you will want more.. 4/6 is the way to go...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-04-2012, 05:04 PM   #12
CC69Rat
CC69Rat's Avatar
Shawn -- is your white truck notched at 5/7? How low can I take the GMC without a notch? I don't haul much of anything and I'm putting new wood in it soon, new strips, etc. So, I just won't be hauling refrigerators or anything. Is there any room left at all on a 7? Would you do 5" springs, 2" blocks? or 6/1 ? Are you guys running pinion shims at 6 / 7" rear drop?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-04-2012, 06:40 PM   #13
Southcity
Southcity's Avatar
I'm running something similar to the 2/4 drop you are considering, all ECE suspension components.
Front = 2.5" drop spindle + 1" lowering spring, 225/75/15 on 15x6.5
Rear = 4" drop springs, shock relocators, super track bar, 255/70/15 on 15x8
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 05-04-2012, 07:09 PM   #14
shawno72
C/10 junkie
shawno72's Avatar
Ok no pinion shims. What I have out back is no notch yet but will def need one at some point, bottoms out on the rubber bump stops over bumps. I did have to cut the stops in half though. Out back I have 5" springs with 1" blocks. I also have CPP deluxe track bar so the plates add 1/4" so its up to a 6 1/4". I wanted it a little lower so I added another 5/8" steel plate for a total of 6 7/8" drop. I have about 1" clearance between the axle tubes and the frame. Drive it everyday but it WILL need a notch at some point. If I had to do it over again I would go 5" springs with the 2" blocks. I also am running 15" wheels.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 05-04-2012, 07:11 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
Here is a couple more angles.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 08-07-2015, 07:41 PM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Attachment 918905
Attachment 918906
I like it a lot. I see 235/70/15's on 4/6 drop in my future.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-07-2015, 10:54 PM   #17
Jcfcamaro
Jcfcamaro's Avatar
Here's mine 4.5/6. 2.5 drop spindles. Little too low in the front. I'm going to put in 1in springs instead of the 2in shown.
Jcfcamaro is offline   Reply With Quote
Old 08-07-2015, 11:01 PM   #18
Jcfcamaro
Jcfcamaro's Avatar
Side view. Doesn't look too bad
Old 08-08-2015, 12:30 AM   #19
71CHEVYSHORTBED402
That looks beautiful Jcfcamaro........I can see why you'd want to lift a tad in front. Either way looks great.
Tony
Old 08-08-2015, 03:02 AM   #20
HeavyD
HeavyD's Avatar
Fwiw the roads up here are pretty bad, so I asked a local vendor (scotts super trucks) what I should buy and not have any issues with bottoming etc and they suggested 2-4 drop.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 01-06-2018, 03:01 PM   #21
Oldironracing
Oldironracing's Avatar
With the 4/6 drop did any of you have to alter the trailing arms or mounts any wat to get the right angles for rear end so no vibration
OLDIRONRACING
Oldironracing is offline   Reply With Quote
