brake switch?
has anyone got any info or diagrams on how to wire the 4-pin brake switch up?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: brake switch?
If you need to know what pin on the PCM....I need to know what year PCM your using.
Re: brake switch?
my harness has a purple (brake signal tcc ground) wire thats supposed to go to a 12v (brakes not applied)?
Re: brake switch?
Hook the purple wire to the "to PCM" terminal of the brake switch.
Re: brake switch?
thanks....that seems simple enough......lol..do you have a part # for the switch?
![]() Join Date: Jul 2009
Re: brake switch?
Re: brake switch?
AC Delco part# D862C
6.0 powered square
Re: brake switch?
oh no I tcc wires backwards
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: brake switch?
thanks!....
Re: brake switch?
I cant get that pn#...so I got a ac#d850a
Has more rust than truck...
Re: brake switch?
Re: brake switch?
another question.....I have a orange wire for park/neutral, it says to ground (in park/neutral)....where does that go??
#13 | |
Re: brake switch?
Edit: as I was posting this, I remembered your truck isn't a 67-72. Some of the later trucks have a mechanical neutral safety switch, meaning that the key won't physically turn in any gear but park and neutral, it doesn't cut the electrical power to the starter solenoid. If this is how your column is, it will have a switch on the column, 2 wires will be for the back up lights, if it has another set, you could use them for your park/neutral switch. You'll have to check to be sure that they work that way on your year of truck, but I know that S-10's from at least '87-'94 are this way.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 04-23-2012 at 12:21 PM. |
Always a work in progress
Re: brake switch?
Do I need the TCC brake signal for a th350 w/ a non-lockup converter?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#15 | |
Re: brake switch?
#16 |
Re: brake switch?
my truck already has a 4 pin switch, but I changed it to the new one anyway...it already has four wires hooked up to it, so do I just tie into that last wire?
#17 | |
Re: brake switch?
The Pink wire will be the Ignition Hot...Leave it alone, Cut & splice onto the other wire. The polarity doesnt matter. |
#18 |
Re: brake switch?
86
#19 |
Re: brake switch?
mine has a light blue and brown wire....
#20 |
Re: brake switch?
From the diagrams I have The brown will be the power wire, The blue wire is the one you need to splice onto.
Verify power at the Brown wire with the key on. |
#21 |
Re: brake switch?
I was going to try that with a test light, but then I got sidetracked.....thanks alot man!
#22 |
Re: brake switch?
Any chance I could see how the switch is mounted? I'm trying to figure out how to fit it on an s10 brake pedal assembly in a '51.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
