05-19-2012, 02:58 PM | #1 |
Porterbuilt control arm help
I purchased some upper and lower control arms, Was putting everything back together on the front end but the upper control arms ended up hitting the stock upper crossmember that they bolt to. They are not able to fully seat aganist the bracket, there is those 1/2 thick spacers from the factory arms but that is still not enough. if I make a 1'' thick spacer will that effect the caster,camber? if it comes down to it I could shave some metal off the bracket, but I just had them powdercoated will post some pictures but need to go get a connecter for the phone to upload pictures. also the holes on the crossshafts on the porterbuilt arms seems a little large for the factory studs, is there a difference for the different years 67-72 73-87 cause i upgraded to 73-87 steering.
thanks in advance for any help |
05-19-2012, 04:38 PM | #2 | |
Re: Porterbuilt control arm help
480-326-6303 Nate Posted via Mobile Device
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
05-19-2012, 11:24 PM | #3 |
Any resolution on this, I'm about to install mine and hope to not have the same problem
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-19-2012, 11:31 PM | #4 |
He hasn't been in touch with me yet. Shouldn't be any thing to worry about. Hundreds of sets out there on factory cross members.
When its set up at proper alignment, the shaft should clear the gusset he's referring to. Nate Posted via Mobile Device
05-19-2012, 11:48 PM | #5 |
Ok thanks Nate, I'm a bit of a worrier lol. Hoping to install mine tomorrow.
05-20-2012, 02:32 AM | #6 |
I trust nate its rare when he makes a mistake but when he does he goes out of his way to fix it.
05-20-2012, 10:24 AM | #7 | |
There shouldn't be any issues at all. But if a concern ever arises, just get in touch and we will get ya taken care of! Nate
05-20-2012, 11:09 AM | #8 |
That's customer service right there!! What owner of a company would respond to a customer's concern at 6am (his time) on a Sunday!!
Posted via Mobile Device |
05-20-2012, 07:23 PM | #9 |
Hey thanks for the quick response, Been a little busy, blow up the tranny on the daily driver yesterday going to get the ball joint press, for the control arms. so have to put this on the back burner for a few days. Will phone in to you on monday, if you are open? cause it is a holiday here.
thanks Jonathan |
05-20-2012, 11:37 PM | #10 |
So here are some pictures of the arms. Thanks Jon
05-22-2012, 09:10 PM | #11 |
I ended up just shaving the gussets down to clear. Like they said on the phone all these trucks seem to have different deficiencies in different areas, sucks that they were just powdered coated. Had to touch them up but you can't tell unless you are few inches away. Over this little bump, on to the next few......(hundred) .I will say it is so nice working with new parts. Yet alone quality parts from Nate. Like putting the lower ball joint in was literally a five minute job for both.
01-10-2015, 08:28 PM | #12 |
I know this is an old thread but does anyone know if the highlighted area gets one of the washers that comes w/ the PBFAB upper control arm ?
84 step side 87 swb |
01-12-2015, 11:18 AM | #13 | |
The crush tube will bottom out on the machined collar of the shaft. Make sure the bushing shoulder seats against the outer edge of the control arm pivot tube (the machined sleeve that the bushing slides into) then tighten her down until the crush tube seats against the shaft. Fee free to send me an email with any questions! Tech@pbfab.com Nate
01-12-2015, 11:33 AM | #14 |
Customer service at it's best !! Thanks guys.
01-12-2015, 12:29 PM | #15 | |
Any torque specs for the bushing hardware?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-12-2015 at 12:36 PM. |
01-12-2015, 02:30 PM | #16 |
Zero lash (seat the crush tube) and 1/4 turn.
Nate
01-12-2015, 04:17 PM | #17 |
Thank you sir! That's about what I did.
They still moved (pivoted) freely so I thought I would verify just in case.
01-12-2015, 04:42 PM | #18 |
That's epic customer service.
I'll be saving my Canadian money to get some of their products. |
