Old 05-02-2012, 12:58 AM   #1
Kim57
Kim57's Avatar
Fuel Pump ?
I'm putting a LS2 in my project.
What is the best external fuel pump and filter to use?
Do I need to do anything special as there is no return line from the engine back to the tank?
This is all new to me and I don't want to screw it up.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-02-2012, 08:29 AM   #2
Notch1988
Notch1988's Avatar
Re: Fuel Pump ?
Run an external 255lph Walbro pump and get a filter/regulator for a 99-04 Corvette.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 05-02-2012, 12:03 PM   #3
6.0 1955
Re: Fuel Pump ?
The corvette filter/regulator has a return line built in. So you will have to run return line back to the tank. But the walboro and vette filter works good as stated above.
6.0 1955 is offline   Reply With Quote
Old 05-02-2012, 12:15 PM   #4
henry3rd
Re: Fuel Pump ?
I am about to cross this bridge as well. What filter do you guys recommend
if you have a return style fuel rail ? Also are you running a filter before the pump or just after?
Thanks.
henry3rd is offline   Reply With Quote
Old 05-02-2012, 03:59 PM   #5
Kim57
Kim57's Avatar
Re: Fuel Pump ?
Thanks for the info guys I appreciate it.
Kim
My build thread
Old 05-02-2012, 07:22 PM   #6
mooseknuckles
mooseknuckles's Avatar
Re: Fuel Pump ?
whalbro 255 and wix 33737
mooseknuckles is offline   Reply With Quote
Old 05-02-2012, 07:49 PM   #7
Kim57
Kim57's Avatar
Re: Fuel Pump ?
Thanks for the pics mooseknuckles.
Kim
My build thread
Old 05-02-2012, 10:24 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Fuel Pump ?
Hey that resembles my setup! My Vette/Wix filter/reg is on the inside tho. I like your fuel pump brackets better...had to make mine from scratch and that's all I had. Guess I could trim it tho.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-02-2012, 11:49 PM   #9
Kim57
Kim57's Avatar
Re: Fuel Pump ?
Is that a second filter that's on your frame?
Kim
My build thread
Old 05-03-2012, 12:56 PM   #10
68GMCCustom
Re: Fuel Pump ?
there's a big Trick Flow aluminum canister pre-filter, then the Walbro pump, then and a Vette filter/regulator with a return line. Just filtering before the pump to keep it clean and the filter/regulator setup takes care of the fuel pressure and provides the return path...and post-filter capability. overkill????
Kurt -
Old 05-03-2012, 04:19 PM   #11
Kim57
Kim57's Avatar
Re: Fuel Pump ?
Thanks.
Kim
My build thread
Old 05-04-2012, 08:42 AM   #12
Shon
Re: Fuel Pump ?
Ebay E2000 pump here with said vette filter/reg and I run a filter before the pump too.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 05-04-2012, 06:03 PM   #13
Pzary3233
Re: Fuel Pump ?
Correct, about the easiest way to regulate fuel pressure with an LSx swap. That is unless you have a 5.3 where the fuel is regulated on the fuel rail.
Thanks.
If it's an aftermarket billet rail, run the vette filter and cap off one end of your fuel rail. If it is a stock rail, run the return line back to the tank.
'55 3200 283 4 speed
'68 Pontiac Firebird Poncho powered with a 6 speed
Pzary3233 is offline   Reply With Quote
Old 05-17-2012, 10:10 PM   #14
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Fuel Pump ?
Hey Guys,
I am haven't been able to confirm the correct fitting needed for the out flow to the motor side of the filter. I had thought it was a 3/8" outlet. Is this it by chance?
http://www.summitracing.com/parts/RUS-640940/
RCC
BigShoe24 is offline   Reply With Quote
Old 05-21-2012, 12:05 PM   #15
vannatta20
vannatta20's Avatar
Re: Fuel Pump ?
Are the external pumps known to last long?
vannatta20 is offline   Reply With Quote
Old 05-21-2012, 12:44 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel Pump ?
too broad of a question. Short answer is yes, they work fine and if setup correctly there should be no issues with them lasting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-21-2012, 06:10 PM   #17
mooseknuckles
Re: Fuel Pump ?
Originally Posted by BigShoe24 View Post
Hey Guys,
looks like the same one I got....3/8" efi quick connect to -6an
Old 05-21-2012, 06:14 PM   #18
mooseknuckles
Re: Fuel Pump ?
my whalbro pump is at the back of the cab...should I move it closer to the tank??...I've heard of these pumps being better "pushers" than "pullers"?....
Old 05-21-2012, 06:33 PM   #19
68GMCCustom
Re: Fuel Pump ?
external pump should be as close to the tank as possible....yes better pushers.
Kurt -
Old 05-21-2012, 08:45 PM   #20
awhite4557
awhite4557's Avatar
Re: Fuel Pump ?
If you use any quick connect fittings, make sure you get the newer ones that have the C-clip instead of the plastic retainer, the ones with the plastic retainer have been known to come off under preasure. Heres the link to a post I did about the fittings http://67-72chevytrucks.com/vboard/s...d.php?t=502781
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2002 Winnebego Class A MH Ford E-550 Chassis V-10
2005 Dodge Ram 2500 5.9 Cummins
2008 GMC Denali
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 05-21-2012, 10:22 PM   #21
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Fuel Pump ?
Awesome, order yesterday. Thanks Moose
RCC
