Fabricate till you "puke"
help! front hubs ,02 silverado 2wd
Do the front hubs need a slide hammer to remove, or are they just rusted /stuck? I hate to fire the torch,& catch the grease on fire! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
laying low
![]() Join Date: Mar 2001
Re: help! front hubs ,02 silverado 2wd
The hub and bearings come as one unit. Once you remove the bolts the hub assembly should come right out by tapping from the rear of the knuckle. I guess you could rent an axle puller, slide hammer to yank it out.
Has more rust than truck...
3lb hammer to the edges of the wheel flange, a few taps on the spindle won't hurt ether.
Thanks guys.....looks like I need to rent the slide hammer! After the bolts came out, I thought I would "thump" it a couple times & be done (wrong)! If it takes heat, I guess that I will remove the spindles, & burn em outside
Ive done 6 or so sets of from hubs on 99-06 2wd trucks and Ive never came across one that was stuck in the spindle!
#6 | |
Will the hub turn on the spindle? If so I cannot see what is holding it in place.
Confirm you have removed the wheel, then taken the dust cap off, removed the cotter pin and removed the nut on the end of the spindle? I would also have removed the brake caliper before trying to remove the hub. Confirm by hub you mean the assemble that has the brake disk attached to it?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
#8 | |
#9 | |
Did you ever get if off?
Yes, its all back together now. It did require some heat & some heavy hammer action to remove the hubs tho! crazyL
