05-30-2012, 04:06 PM | #1 |
how to remove the rear window
hey guys I have a 72 gmc i need to remove the rear window and i dont want to break it is there any threads or can someone point me in the right direction thanks
05-30-2012, 05:16 PM | #2 |
The Older Generation
Re: how to remove the rear window
to the board...
Does your rear window have the stainless trim around it? Quite a few of the guys and gals just cut the rubber around the glass and order a new Precison brand replacement rubber seal. If it has the trim you have to be careful which seal you get as there are two different ones. I have taken them out without cutting the seal and re-used them but it is not the easiest thing to do. LockDoc
05-30-2012, 07:09 PM | #3 |
It's like changing a bicycle tire. You do it from the inside with two flat & thin prying tools...like screw drivers or whatever. I start in a bottom corner.
05-31-2012, 12:10 AM | #4 |
I just did it at the junkyard with a putty knife and the Bic pens I found in the cab. Like Spec stated, the inside is what you work on. The lower corner was a real pain, but once it was freed, it all came out nice. I was able to save the gasket as it was more pliable than mine. It went in my flat bed just fine as well. Now to find a windshield.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
05-31-2012, 06:01 PM | #5 |
Can you remove a windsheild using the same method, and still save the gasket?
05-31-2012, 06:06 PM | #6 |
Is there an existing thread for this? A link maybe?
Calder |
05-31-2012, 06:11 PM | #7 |
C/10 junkie
subscribed
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
05-31-2012, 08:47 PM | #8 |
I've used this method a few times. The rubber seal has to be fairly pliable and it has to be warm out. (or use a heat gun to warm up the rubber) http://67-72chevytrucks.com/vboard/s...d.php?t=210843 LockDoc
05-31-2012, 08:58 PM | #9 | |
As far as the black glass goes, it's really easy. I personally wouldn't worry about the seal because you should replace it anyways. Just get a razor blade and cut the seal perpendicular to the window. Even though the seal is one piece, it will kind of tear out in layers. Once you get the outside layer off to where the window frame is exposed, you should be able to just give it a slight push and it will come right out. |
06-01-2012, 12:31 AM | #10 |
Thanks for the windshield schooling Doc. I will try it.
06-01-2012, 09:16 AM | #11 |
No problem, hope it works for you. Anyone who tries it let us know if it works for you and if it doesn't, what the problem was... Thanks. LockDoc
06-01-2012, 11:02 AM | #12 |
SUbscribed
Posted via Mobile Device |
06-01-2012, 11:26 AM | #13 |
I've found that if the rubber is stiff and hard you may as well just cut it and be done with it. I'll try Loc Doc's method when I change windshields in the 71 as the rubber is only two years old.
06-01-2012, 11:59 AM | #14 |
i removed my rear window just two weeks ago, i took some time with removing the trim, started with the corners, took out the lh and rh trim and put some rope on the inside and little by little it popped out, UGH the rust plus old stiff rubber. not cool but hey its done.
06-04-2012, 11:25 AM | #15 |
thanks for all the tips im gonna try and remove mine tonight i was at two different shows over the weekend and only saw one gmc but a ton of chevys I cant wait to have mine done
08-01-2021, 04:04 PM | #16 |
Old thread, but it helped me out so thanks LockDoc!
On my 71, I used this method to remove both rear window and windshield without cutting the gaskets. My gaskets were pretty pliable (likely not original to the truck). I had an old Craftsman wet/dry vac I was tossing and cut the round power cord from it. Forced that behind the gasket from inside across the top and down the sides. You can actually force it far enough to go between the gasket and the top of the pinch weld lip, which holds the inside of the gasket away from the inside cab sheetmetal. From there it was just a little persuasion with the flat of my hand to get an upper corner moving out. Might have to use your fingers right in the top corner of the gasket to help it start while pushing the glass with your other hand. After that, easy to get the rest of the top loose.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
08-01-2021, 08:41 PM | #17 |
Wow! Glad it is still helping people. I have used that method on two or three other trucks since I posted it. I had one that had a lot of sealer used on it and it wouldn't work on it. LockDoc
08-01-2021, 09:38 PM | #18 |
These nylon sticks help a lot when pulling glass
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
08-01-2021, 10:56 PM | #19 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-02-2021, 10:13 AM | #20 | |
My statement "two different ones" was referring to trim or no trim.... The rubber seals are different on the two, so you have to make sure you get the correct seal. LockDoc
08-03-2021, 07:42 PM | #21 |
Sub'd. Good info!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
08-03-2021, 07:47 PM | #22 |
I don't think trying to save the gasket is worth the risk of cracking the glass. I would not miss the opportunity to install newer rubber anytime I had glass out. I keep cars forever though.
