#26 |
Re: Hood & fender emblems
heres ones i got 1963 c10 fender emblem and not sure on the years of the gmc but its the v6 hood emblem:
![]() heres some measurements 1963 c10 has two mounting screws with a measurement of 2 3/8 ![]() gmc v6 hood emblem has a guide pin and one mounting screw measures 1 5/8 and a part number 2419879 stamped on it ![]() then I also have a cowl extension from a 1962 c10 with measurements for the holes hooking the straight hood side to the holes is 2 7/16 and then 7 11/16 ![]() then for the first hole measuring up from the crown for the first hole closest to the hood is 1" ![]() then the second hole closest to the door is 1 7/8 ![]()
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 06-13-2012 at 02:15 PM. |
#27 |
Cool. Im trying to put as much info on as I can about the emblems and the measurements are great. This thread should help some people with what they are looking for. It also backs up the OEM vs. repop issue. The reissue stuff is nice, but its not quite the same. If you've got factory #'s that'll help also. There seem to be a couple of variants on the GMC v6 emblems. If anybody can help identify the differences in the years it would be great.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#28 |
Found this thread to 1963 c10 fender emblem location in the FAQ section herers the link:
http://67-72chevytrucks.com/vboard/s...d.php?t=459944
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#29 |
Ill post it here also. Fender emblem mounting location for 63 chevy
#30 |
Also...not quite trucks, but here are the corvair greenbriar emblems. If anybody can help ID the years, it'd probably help somebody out. The one on the brown & white truck is on a 62, but Im not sure what years it'd cover.
#31 | |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
'60 - '61 GMC's had the round emblem, and '62 - '66 had the other one. |
#32 |
Ok, great. Thanks for the help. Were just trying to inform and Im self educating on this thread. I had an emblem question from a guy a week ago and couldnt answer it, so I figured by starting the thread that we would get to the bottom of it. Ive actually seen a couple of new emblems I hadn't seen before. I have a picture of another Viking emblem somewhere....but have close to 5000 pics archived.
#33 |
Have since found out that was used until at least 65 as seen in the pic
#34 |
GMC's n H.D.'s too!
It's a great idea for a thread! Thanks!
#35 |
1965 c-60 emblems GM part # 3855098
#36 |
Ok, GMC guys...which way or ways was correct for this emblem? I know that it was 60 & 61, but I have found them 3 different color schemes and all have the same GM part # 2392804
#37 |
GMC's n H.D.'s too!
As far as I know the '60 - '61's never came in all white.
The Chrome one should have the same color pattern as the red, white, and blue one, except that the white areas are chrome. The Custom Cab's are the ones that came with the chrome emblems. Everything else came with the white... or so I have read. LOL |
#38 |
1961 crewcab
here is a spartan emblem from a coe-64, but same as the 60 big truck.
also a 62 40 series
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#39 |
1961 crewcab
66 custom camper:
64 30 series
#40 |
1961 crewcab
#42 |
#43 |
#44 |
#45 |
#46 |
#47 |
http://67-72chevytrucks.com/vboard/a...1&d=1339604123
it will be centred on the panel just a bit up from that bend as in the picture ![]() By rondavid at 2011-01-25 ron |
#48 |
This thread has turned out more informative than I thought. Keep them coming.
#49 |
GMC's n H.D.'s too!
I can post some pictures of the fender hole measurements for my '60 GMC this weekend.
#50 |
Thatd be great.
