Old 07-14-2012, 06:53 PM   #1
blubird
anyone do a lsx swap with origianl 4 speed ?
has anyone here swapped in a lsx and used the original muncie or saginal 4 speed in here ?
blubird is offline   Reply With Quote
Old 07-14-2012, 07:31 PM   #2
whitels1
whitels1's Avatar
Re: anyone do a lsx swap with origianl 4 speed ?
I'm in the process, I have information in my swap thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=532351
whitels1 is offline   Reply With Quote
Old 07-14-2012, 07:39 PM   #3
blubird
is this dave ?
Old 07-15-2012, 02:01 AM   #4
whitels1
whitels1's Avatar
Originally Posted by blubird View Post
is this dave ?
Yeeeppp!
Old 07-15-2012, 09:24 AM   #5
crazy longhorn
Fabricate till you "puke"
Not to "hijack", but the questions are along the same line. I plan a 5.3 , also with a gen I trans & bell. Does that 1050 flywheel also fit an 11" clutch? Also, what did you use for flywheel & pressure plate bolts? BTW, that looks like a nice build you have going there crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-15-2012, 10:42 AM   #6
whitels1
whitels1's Avatar
I bolted my original 11-7/8 clutch to the NFW1050(had to remove the alignment pins) using my original clutch bolts, I believe they are the 3/8 shouldered bolts. I used LS1 flywheel bolts.
and thanks.
Old 07-15-2012, 02:21 PM   #7
crazy longhorn
and thanks.
Thanks, that gets me a couple more pcs to the puzzle crazyL
Old 07-17-2012, 05:22 PM   #8
blubird
Yeeeppp!
haha small world eh,this is Ali
Old 07-17-2012, 09:01 PM   #9
LEEVON
LEEVON's Avatar
I did it, check out my build thread linked below and this:
http://www.pirate4x4.com/forum/showt...1#post11161311
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-18-2012, 08:27 AM   #10
whitels1
whitels1's Avatar
Nice! I have you to thank, as your pirate build thread provided me with the essential clutch, flywheel, bearing information I needed.
