Re: 81 K5 "Arctic Blaze" H.O. 5.3 / SM465 swap
Made some more progress today, decided to work on the fuel pump and wiring.
What I'm using to pull this off. ![]() ![]() This is the vetteworks pump ring, I would suggest not using the aircraft bolts supplied with the kit, because the first time you have to change your pump this might happen, only all of them broke! Looks like I'll be removing the ring and installing some different studs.... ![]() ![]() Module assy is plenty tall enough for the stock tank. ![]() ![]() ![]() Feels like the further I get to the finish line, the longer everything takes! |
