07-16-2012, 11:57 PM | #26 |
Re: Project Family Chummins
i know a guy who did this kinda swap on a nbs burb using the front frame of the cummins with the back half of burb frame he had about 8 inches of body lift he said but the truck is kinda a hack job the way it looks your gonna make yours looke awesome cant wait to see the finish project
IM ONLY 18 AND LOVIN IT IF MUD AINT FLYIN YOU AINT TRYIN! 1badgmc- Just think. Someone worked hard to make it look that bad. 1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945 1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873 1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build 1998 GMC K-1500 ECSB 305 auto partd truck 1999 GMC K2500 suburban 350 4x4 Dads project 1981 Corvette 350 auto Also Dads project 1989 Corvette 350 auto ^^ 1998 GMC K1500 ecsb 305 auto Brothers project |
07-17-2012, 08:29 AM | #27 |
Still Learning
Very good progress. Looks like you have your hands full again
07-18-2012, 05:42 AM | #28 |
Still plays with trucks
The Permatex hand cleaner that comes in the blue & white tubs at the auto parts store works miracles on greasy carpet.
http://www.oreillyauto.com/site/c/de...x+hand+cleaner
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-25-2012, 06:39 PM | #29 |
I got the carpet out and did some power washing and it looks like i should still be able to use the carpet. Its not perfect by any means, but good enough for now, especially with little kids.
When i pulled the carpet I did find some rust. I'm guessing the A/C was leaking water inside at one point, soaking the carpet padding, and then rusting out the floor below. I also got the passenger side doors off: I also got a few interior parts from jtj143. Got a center console, overhead console, dash bezel, and a few other little things. |
07-25-2012, 10:32 PM | #30 |
6>8 Plugless........
Keep up the good work. When you cut the dodge frame to lengthen it, I recommend boxing it while you have it open. These frames like to flex while in stock form and crack in front of the rear axle.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-25-2012, 11:40 PM | #31 | |
tonight's progress: I had noticed quite a bit of gear lube on the concrete under the dodge, so the other day I crawled under there and determined that the transfer case was leaking around the output shaft. I went to the parts store and got the appropriate output shaft seal and fluid. However, the fluid that is required for the transfer case is ATF. The fluid on the ground was NOT atf. So a little reading on the cummins forum, and found that sometime the tranny output shaft seal will leak and will appear as though the TC is leaking. It sure looked like to me though, that the transfer case was leaking. So tonight I start tearing it apart. First I drop the driveshaft, one of the ujoint cap pops off as I'm taking it off, and there is a thick paste and a needle missing. So I will be replacing that. When I pull the drive shaft out of the TC, sure enough: gear lube comes out. I try to pull the two piece TC output shaft cover as a unit with no luck. So I have to pull off the first cover, then remove a snap ring, and then remove the second one. The lock ring was a PITA since there wasn't the little holes to put the lock ring pliers into, but I managed to get it out. Then slid the 2nd cover off. I started to clean it all up in the parts washer. I'm going to go ahead and replace that rear output shaft bearing that is in the second cover since I"m there and have potentially damaged it with the water/solvent in the parts washer. Nothing real exciting, but a little work that will make the truck a little more reliable in the end. |
07-25-2012, 11:57 PM | #32 |
I'm in to watch
07-25-2012, 11:59 PM | #33 |
it always sucks having to go behind someone that does half azzed work. but it sounds like you are making an effort to do it right and with pride. keep up the good work!
I'd Rather Push My Than Drive A Floppy Ol' Ford 1988 GMC Sierra SLE, 2 door, shortbed (Ol' Blue) (http://67-72chevytrucks.com/vboard/s...d.php?t=528216) 1995 GMC Sierra SLT Z71, ext-cab, long bed (The Beast) (http://67-72chevytrucks.com/vboard/s...d.php?t=531244) 1996 Chevrolet Tahoe LT, 4 door grocery getter (Mama's Ride) |
07-26-2012, 12:03 AM | #34 |
Tot Roddin'
Digging the new project.
I'll be keeping an eye on this.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-26-2012, 06:54 PM | #35 |
Just an FYI, if there was gear lube in your tcase, I'd pull it off the trans, seperate the 2 case halves, clean and inspect it. These tcases have an oil pump in them located on the back of the main shaft just under the 2nd cover you removed, also known as the speedometer gear housing. Those pumps will get damaged and wipe out a tcase from gear lube beeing ran in it. It isn't much more work to get the tcase off and the parts are rather cheap for them. If you need parts for it, let me know. I can get you the parts and have them drop shipped to you.
07-27-2012, 08:33 PM | #36 |
Went to the salvage yard today to look for a clutch pedal with no luck (anyone have one) but I did manage to score a homelink garage door opener piece that goes into the overhead console. Figured $10 was a pretty fair price considering a new garage door opener is $30
07-28-2012, 11:54 PM | #37 |
This is going to be a sweeet build.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
07-29-2012, 11:03 PM | #38 |
Got some work done today.
On the Dodge, I got the transfer case put back together. It took way too long, it was a PITA. The new bearing was maybe 1/16" too thick and I couldn't get the snap ring back on, so I ended up putting the old bearing in. There is nothing wrong with it, but would have liked to put a new one in while I was there. Then I got to the rear u-joint and the bolts were rounded off enough that I couldn't get them tightened down, and then couldn't get them back out. So, I had to cut the bolts off and go get a new u-joint strap "kit" The whole thing turned out in to a big time waster. Hopefully it doesn't leak any more though Then I moved on to the crew cab. I removed the bumper, grill, core support, front fenders, and then started on disconnecting the engine. I have just a few more things to disconnect and the engine will be ready to pull. Oh yeah, I was wrenching this whole time in the garage while it was 106 outside. It sure is nice having an A/C unit in the garage, thought its not really big enough to keep up. By the time I quit for the day it was about 82 (was about 72 this morning). I can't complain much
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 07-29-2012 at 11:09 PM. |
07-30-2012, 11:44 PM | #39 |
I think the cover needs to be on the 68 back there! Looks like shes gettin dusty!
That 454 is calling my name...
07-31-2012, 11:34 AM | #40 |
It's for sale, come over and get it! 410 ft lbs of torque ar ar ar (in the voice of tim taylor)
07-31-2012, 07:30 PM | #41 |
I'm betting that 82* air felt good when you came in from out side though! Sounds like you made nice progress.
07-31-2012, 09:22 PM | #42 |
i'll have to ask my uncle if he has a clutch pedal laying aroud for your build.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
08-01-2012, 12:59 PM | #43 |
that would be great!
08-02-2012, 08:27 AM | #44 |
talked to him yesterday and no luck on the clutch pedal. i will keep an eye out for you though.
08-02-2012, 03:22 PM | #45 |
We have one we modified to put in a 88 V30. I can check to see if it can be used for an original application again if you want?
08-02-2012, 06:21 PM | #46 |
I'm watching this one. And I'm jelly of your cooled garage. Mine is running about 115 degrees with no breeze in the heat of the day right now. I worked for 1.5 hours the other day, started to get a headache and went in to shower up. I had lost a bona-fide 5 lbs in that short time, despite loading up on water. Hard to get anything done like that!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
08-05-2012, 11:19 PM | #47 |
I got the engine pulled:
My next step is to build a dolly for the cab. I bought some large pnuematic casters from harbor freight the other day |
08-12-2012, 01:02 PM | #48 |
I spent a few hours the last week working on the wiring. I separated the engine wiring harness from the cab and fuse block wiring. In all it took me about 4 hrs to separate and label everything.
Then I built the dolly for the cab. Then I got to lifting the cab off the frame. I figured the center of gravity would be towards the front, so I put the cherry picker through the front door. I used a couple of rachet straps from the door hinges to lift from. And then set it down on the dolly. The dolly worked out OK, except the tires don't hold air real well, and then don't rotate real easily, but they'll work for now. Then I took the bed off. I had to remove the gooseneck plate first and then lifted it off. The height of my ceiling was really giving me fits getting it off. I had to take the tires off and drop the frame to get the bed up and over the frame. |
08-13-2012, 01:17 AM | #49 |
Nice work man!
08-13-2012, 07:02 AM | #50 |
high-Tech Red Neck
Man great build, I am going to throw a strong suggestion at you however. DONT DITCH YOUR CHEVY FRAME!!!
Auto world in great falls Montana makes all the stuff you need to BOLT that Cummins right into your truck. As well you can get a kid to put leaf springs in the front, then all you will have to do is chop off the coil buckets and weld some plate in their place. This is much less labor intensive than trying to stretch that dodge frame then trying to build all the frame mounts to match. THE GMT 400 is a great truck. You are going to love it when you get done. Also you can get the fuel level sender for a 6.5 diesel truck that will replace the in tank pump and be guaranteed to work with your Chevy gauges. If you need any help sourcing the parts drop me a line. I will be watching your build for sure, I think it is going to be a great truck done right.
"He used to be a pretty nice feller, now he's a welder!" |
