12-29-2010, 01:27 PM | #1 |
Task Force Interior Cab Corner Fill Template
A member ask for a copy of the template I made so I figured I may as well just post it in a thread. Attached are two files one 11x17 and a second that is (2) letter size with registration marks.
My notes are not to legible but the only clarification is at the part behind the door jamb the plate needs to be bent up over the brace. It's obvious when you look at it. This template is for the drivers side, it flips for the other side. I found that my two sides were slightly different and your truck may be too. Critical to me was to get the outside tight to the metal so go a little large and trim to fit. The inside over laps the floor by about an inch for the plug welds. I used 16 gauge metal, cut with a jig saw and fine tuned with a die grinder. On the corner side I spot welded it to the body, on the cab side I drilled holes and plug welded it to the floor. I then put a generioius bead of 3M Body Sealant around all the edges to seal it. I would not recommend a full weld at the exterior body line, you will warp the metal and push it out which will cause problems. Here is a photo of it installed too.
12-29-2010, 01:49 PM | #2 |
Re: Task Force Interior Cab Corner Fill Template
I had already planned on doing this one, so this helps that much more! Why recreate a design flaw??!!
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
12-29-2010, 05:36 PM | #3 |
Cool, thanks for posting OrrieG.
Kim |
12-29-2010, 08:27 PM | #4 |
Thank you for template much appreciated
12-29-2010, 09:41 PM | #5 |
A320 Pilot/USAF Retired
Wow! It looks identical to mine! Nice work.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-30-2010, 04:18 AM | #6 |
Cool, thanks. I remembered the original post and was planning on doing your mod. This makes it much easier.
Gotta love a community like this.
If the women don't find you handsome, they should at least find you handy... Red Green Keep your stick on the ice, Woodbutcher |
12-30-2010, 01:45 PM | #7 |
Great minds think alike! Or if we take long enough we stumble onto a solution to the challenge.
12-30-2010, 09:14 PM | #8 |
I tend to stumble a lot!!!!!
12-30-2010, 11:27 PM | #9 |
01-02-2011, 06:40 PM | #10 |
Thanks for the templates!!!
big help at just the right time into the build. thanks again! brian
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
07-30-2012, 03:07 PM | #11 |
thought i would revive a dead thread... does anyone know if the attachments are to scale? i am at work (away from my cab) and if dont get a response will just bring it home and test fit it, but i am near a friends machine shop and will drop the template off to him if they are already to scale
and regardless - Thanks Orrie!! i know its simple, but any time savings is appreciated in my book!!! |
08-01-2012, 12:34 PM | #12 |
The ones I email are. Send an email to reddogeb@yahoo.com and I will get them to you.
08-01-2012, 12:42 PM | #13 |
Thanks Orrie, but I already printed the 11x17 one and made sure printer didnt change scale, and it was darn close so I will just use those - Thanks again! this saved me some time!
08-01-2012, 11:33 PM | #14 |
Glad it worked out for you.
08-02-2012, 07:17 AM | #15 |
What is this for? Extra strength or just to make it look better?
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
08-02-2012, 02:37 PM | #16 |
