08-07-2012, 02:48 PM | #1 |
*^%#* Head Gasket!
Fired up the Blazer yesterday to go to work and noticed a nice cloud of white steam pouring from the driver side exhaust. It slowly when away as the truck warmed up, but I parked it until I can tear it down. Oil didn't have any water in it and water didn't have any oil, so I think a cracked block/head are not to blame. What a PITA though to pull the heads! It only appears to be leaking on the driver side head (I don't have a cross-over in my dual exhaust), but I will probably replace both head gaskets while I'm in there since I put them in at the same time about 10 year ago.
08-08-2012, 08:18 AM | #2 |
Re: *^%#* Head Gasket!
Good luck! I just got done doing a rebuild of my 383 in my Monte due to a flat cam, (lack of the zink additive) didn't know about that one.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
08-08-2012, 12:00 PM | #3 |
The same happened to my Blazer one year ago and it has done it one more time since. I only drive it around town an stay within 100 miles. Everything looks fine except for those two times. I am considering a ls conversion.
Pulatoy |
08-08-2012, 01:58 PM | #4 | |
I feel your pain
08-09-2012, 02:03 AM | #5 |
Recalculating.....
Quaker State Defy. They add the zinc to it.
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
08-09-2012, 07:58 AM | #6 |
Thanks, good to know!
08-09-2012, 02:41 PM | #7 |
Update: Pulled the heads and found the faulty gasket on #7 cylinder. I don't like doing all of the work to pull the heads, but I like being able to find the exact cause of the problem.
08-10-2012, 08:15 AM | #8 |
Any idea what caused it?
08-10-2012, 02:58 PM | #9 |
Bentblazer - not really sure of the cause. I installed the heads about 10 years ago when I had a valve job done with proper bolt torque and pattern. The damage occurred in a spot where the water jacket is very close to the cylinder bore on the firewall side of the #7 cylinder. It appears as though the steel ring in the gasket at the leaking spot has some rust damage, so the water has been working its way out for a while. I will be getting the heads and block checked for warps and have them decked if needed.
08-10-2012, 03:27 PM | #10 |
Moderator
Man that sucks Craig...but at least you found the problem, and know how to fix it. Glad it didn't happen at Brother's...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
