Closed Thread
Old 08-09-2012, 07:40 PM   #1
VH Coachworks
VH Coachworks's Avatar
Lightbulb Pre-Order Sale: 1967-1972 Chevy Remote Power Door Lock Kit
Remote Power Door Lock Kit specifically designed for the 67-72 Chevrolet Trucks. This is NOT a universal kit, and comes with complete application specific directions. This kit comes completely wired, so no guess work for you! The only wires that you are required to hook up, is the 12V+ and ground wires. There are 2 input wires into the Receiver/Control module to allow you to add a inside power door lock switch if you so desire.
The complete kits come with the following:
  • Wireless Remote Key Fob
  • Receiver/Controller Module
  • 2 HD Solenoids
  • Application Specific Mounting Brackets
  • Complete Wiring Harness
  • 8 Rivets
  • 2 Control Rods
  • Rod Fasteners
****You can purchase an EXTRA KEY FOB at time of purchase for an additional $10.95***
Regular Retail Price: $79.95
Shipping: $9.95 via USPS Priority Mail (to the lower 48 states only)
$15.95 to Canada
Payment: PayPal or US Postal Money Order
To Order: Simply send us a PM with your PayPal address AND the part number of the Remote Power Door Lock Kit (Part #: RDL6772). And we'll send you an invoice via PayPal with the total! Also if you want an Extra Key Fob ($10.95) please note that in your PM
Thanks for looking and have a great day!!
VH Coachworks is offline
Old 08-09-2012, 07:53 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Pre-Order Sale: 1967-1972 Chevy Remote Power Door Lock Kit
I likey
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 08-09-2012, 10:51 PM   #3
jocko
jocko's Avatar
yeah, that's a nice setup and good price. what gets riveted to what during the install?
jocko is offline
Old 08-10-2012, 10:08 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
Will these work with Blazer doors?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline
Old 08-10-2012, 06:56 PM   #5
VH Coachworks
Hi, The rivets go thru the inside door skin to the backing plate on the solenoid.
Need to drill 1/8 holes for the rivets
The backing plate sits on the top of the inner brace, and the end goes tight
to the door edge, and it will be exactly in the right position so no guess work positioning it.
Tools needed to install inside door componants, are phillips screwdriver, needle nose pliers, hand riveter, 1/8 drill.
Hope this helps any other questions please feel free to ask.
Old 08-10-2012, 08:52 PM   #6
jocko
jocko's Avatar
got it, thanks!
jocko is offline
Old 08-10-2012, 09:23 PM   #7
VH Coachworks
I believe the door latches are the same on the 67-72 pickups, blazers & burbs, and GMC I don't know if the bracing inside the door is the same.
We used a pickup of ours to make this unit, so we know it fits the pickup.
WE do not have a blazer in this area to try it on, to check for fit.
If you would like I can send you the measurements, and you could measure yours. Thanks
Old 08-11-2012, 08:24 AM   #8
Steve Hafner
Steve Hafner's Avatar
Will all of the parts and wiring be hidden when installed ?
Will my original black "knobs" connect to this system ?
Thanks !!!
Steve Hafner is offline
Old 08-11-2012, 05:55 PM   #9
VH Coachworks
Thanks !!!
HI,
All the parts and wires are hidden inside the door, also the four rivets on each door are under the door panel.
Your original black knobs will stay on. The system connects to the bottom of
the rod your black knobs are on. When you use the remote your black knobs will go up when unlocked, and go down when locked.
Any more question please ask.
David
Old 08-12-2012, 08:06 PM   #10
VH Coachworks
Ttt
Old 08-13-2012, 07:22 PM   #11
VH Coachworks
Bump
Old 08-15-2012, 08:58 AM   #12
Lemield
Lemield's Avatar
PM Sent.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline
Old 08-15-2012, 10:15 AM   #13
Lee H
Lee H's Avatar
Does this system auto lock after the vehicle starts?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 08-15-2012, 05:59 PM   #14
VH Coachworks
Hi,
NO it does not auto lock, but that is something you could do. I think the newer trucks unlock when put them in park, and locks when you take them out of park.
We have tried to make our kit very easy to wire as it comes prewired, with only the + & - to hook up.
Old 08-15-2012, 09:09 PM   #15
jamie72
jamie72's Avatar
i plan on going with a kit like this,couple questions, how it the wire ran from the door to the fusebox? what is different from this kit and the on from lmc?
thanks..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline
Old 08-15-2012, 09:47 PM   #16
VH Coachworks
thanks..
HI,
The wires are ran Thur the door jam, just like for power windows, or door speakers etc.
To the best of my knowledge no one else has a kit made just for the 67 to 72 Chevy trucks. All others are universal if you read the description. Most universal 50.00 kits don't have wireless remotes. The 59 to 69.00 universal kits do have remotes
If you look at the pictures of universal kits, they have 2 straps with holes in, there is no way you can use these to mount the solenoids in a 67 to 72 chevy truck. Also these kits are not pre wired.
Our kits come pre wired except for the + & - No guessing where the wires go.
Our plated solenoids are made to line up exactly, by placing them on the window channel brace going to the inner door panel, and the outside door edge.
Hope I have answered your questions, if you have any more please feel free to ask.
David
Old 08-17-2012, 08:24 PM   #17
VH Coachworks
Bump
Old 08-17-2012, 10:13 PM   #18
gofast68c20
Do you have any installed pics?
gofast68c20 is offline
Old 08-17-2012, 10:16 PM   #19
gofast68c20
And how many remotes come with it?
Old 08-17-2012, 10:24 PM   #20
VH Coachworks
HI, I do not have any, but I can take one tomorrow if you would like.
What in particular would you like a picture of? Our directions will have
pictures of doing the installation and how it's done.
If you have any more questions please feel free to ask.
Old 08-17-2012, 10:26 PM   #21
gofast68c20
Just wondering about window clearance since I'm running one piece windows. They practically touch the latch when rolled down.
Old 08-17-2012, 10:51 PM   #22
VH Coachworks
There is quite a bit of room between the window channel and the solenoid, as the solenoid is to the rear, and to inner side of the door.
It does not come close to the glass when rolled down.
Old 08-18-2012, 12:42 AM   #23
mosesburb
I had a V-8
mosesburb's Avatar
This is very intruiging as I have this on a list of things I want to engineer for my Suburban. If I was doing it I would use oe GM solenoids, but for your price and statement of fitment, I am very willing to make exceptions on that. I do have a couple questions though. I noticed that one solenoid has two wires and the other has five. Is this system capable of unlocking one door and/or both doors like oe systems?? Can another solenoid be added for my third door?? I realize the mounting configuration for the third door is an unknown entity, but having to engineer one is much better than three. How do you recommend getting the wires to the doors?? What kind of conduit/tube is recommended for sealing the wires/holes in the pillar and door from the elelments?? How big is that remote??
I think that is all for now. Looks like a very nice setup.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline
Old 08-18-2012, 09:10 AM   #24
70sarver
70sarver's Avatar
Also interested in this for my suburban. My locks are a little stiff. Do you think your system will have the power to still work them?
70sarver is offline
Old 08-18-2012, 03:55 PM   #25
nlped
nlped's Avatar
Is it feasible to get a second remote (the picture only shows one)?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Closed Thread
